5/8th bolt option for spindle pin replacement
The main reason folks started using 5/8 bolts DECADES ago was to fit .625" ID rod ends on the tubular or modified stock LCAs. If you are not using rod ends and/or not racing, there's no benefit from using a 5/8 bolt in place of the spindle pin, IMHO.
  On 3/5/2014 at 3:00 PM, johnc said:
The main reason folks started using 5/8 bolts DECADES ago was to fit .625" ID rod ends on the tubular or modified stock LCAs. If you are not using rod ends and/or not racing, there's not benefit from using a 5/8 bolt in place of the spindle pin, OTHER THAN maintaining your sanity should a spindle pin decide it wants to stay in its home.
Fixed it :D
  • 1 year later...
  • 1 year later...
  • 4 weeks later...
  • 4 weeks later...
