PLEASE HELP, rear brake conversion issue
Hi folks,
I bought this kit off of a member on here a month or so back, and finaly got to the point on my build to start putting it together. I got the caliper brackets and calipers from said member, 280zx calipers to be exact, with the intention of mounting them to my rear uprights using the included brackets.
As you can see in the pictures, while using a 280zx caliper, and the included bracket, the caliper is far to close to the rotor, in fact, its an interference of about 1/8 of an inch. Beyond that, the casting for the caliper, where the brake line attaches, interferes with the bracket...... safe to say this bracket is not intended for this caliper at all.
Has anyone seen this setup before and can you please lend me some opinion on the situation. does the fabled maxima caliper have a very similar bolt spacing to this? Am I actually in possession of the maxima-to-300zx rear brake bracket ?  I also tried mounting the bracket the other way, to see if i had it backwards, then the rotor wouldn't fit.... also pictured.
Edited by Blob1620
Close maybe, at least on names.  Maxima calipers, 300ZX rotors, on the Z cars.  Scroll down here - http://www.californiadatsun.com/brakes/brake-conversion-upgrade-kits/  The KE is there, and the shapes look similar.
This guy used to be Datsun Parts LLC.  Changed the name.  Same parts, same guy, though.
  On 5/24/2015 at 5:42 PM, casper9182 said:
Just an idea... Flip the bracket around?
I tried that, it resulted in the last of the four pictures. rotor wouldn't even go on.
  On 5/24/2015 at 8:23 PM, Hypertek said:
I dont know which bracket you have. I got the maxima bracket on mine running the maxima calipers, with z31 rear brake rotor.
Thanks for the pictures, my brackets seem to have a different offset and bolt pattern from what I've been seeing with the maxima caliper trick. I think the bracket may be corect for these calipers, but perhaps needs a different rotor to make it work..... just a matter of WHICH rotor.
The bracket does look similar, but seems to have FAR less offset. That's what leads me to believe I have the correct bracket for the calipers, but perhaps the wrong rotors.
Edited by Blob1620
  • 3 weeks later...
So, I tried contacting the manufacturer of the kit, only to get a scolding for buying something used and no real support on figuring out what I needed to make it work. Offered to make me a very good deal, and sell me a new kit for retail :P
After playing around, noticed it needed the other generation 280zx rotors, got my old ones sent back to the manufacturer, and got the other generation rotors, and they don't fit ether. Offset and bolt pattern is wrong for maxima caliper, so thats not the answer ether...... I'm truly lost.
It appears they could work, but the inside of the rotor hat hits the corners of the bracket. fabricator in me wants to just grind the bracket, engineer in me want so know why this is happening when i apparently have all the right parts now that the kit was designed around.
The engineer in you should take some measurements and post them.  Maybe somebody out there will do the same.  Be more precise than "about 1/8 of an inch".  Look back at your posts and you'll see that there is nothing there that can help anybody help you.  No numbers.  The brackets all look similar.  Your measurement tool and technique in the last picture is terrible.
Miles,
Yes, the difference between the two generation rear brakes is what led me down the rotor rabbit whole. I assumed i had the right calipers, as they came with it, but that now looks to be untrue. I now have first generation (79-81) calipers, rotors, and pads. This is yeilding the current interference problem, between the rotor and caliper bracket.
Based on what I saw from the first set of rotors, i may need second gen (82-end) 280zx calipers and rotors to make it work.
Its obvious I dont have a bracket intended for the maxima trick, as the maxima calipers are threaded, and the bolt is retained by threading into the mount on the kit I have. lts not a 240sx kit ether, as (a quick call to autozone to thank for this info) those calipers are 4 1/4" hole to hole And my brackets are 3 5/8" hole to hole....
So it looks like back to second gen rotors :-/ and finding second gen calipers. It would be nice if anone has them sitting around that I could get the bolt hole width measurement from.
Thanks all for helping with my headache!
Well, I had a really long flight to poke around the interweb and look into this more. Its seems the offset of the later 280zx caliper (although I couldn't find an exact measurement) combined with the later rotor would solve this issue. So, i have one caliper and one rotor on the way. stay tuned.
That bracket looks a lot like the brackets I got off eBay.  My kit specifies Maxima calipers and late 280ZX rotors.  I have not installed it yet, but I have mocked it up on the bench with a spare strut and it all fits together well.
SleeperZ
Are the brackets threaded? Because all the maxima calipers Ive seen are threaded requiring the bracket to be an open bore. That to me means they arent what works on mine, since mine ARE threaded.
I got a late caliper today, but it didnt have the slider bracket, which was aggrivating because thats how it bolts on... I seem to be on The right path with that though.
Does anyone have any late (81-82) 280zx calipers? Also, anyone want to buy a complete set of brand new rear brakes for an early one? Ive attached a picture, its all brand new and ready to go, Haha! :o)
Edited by Blob1620
hmmm, there's a 280zx specialist down here who told me that the early and late 280zx rear brakes are interchangeable, as long as you do everything. Calipers, rotors and pads that is. Seeing as my brackets are threaded, and maxima calipers are threaded for mounting, and all my stuff seems to line up except the rotors hitting the bracket, I'm inclined to believe they will work based on his expertise.
I may be putting my foot in my mouth, but i found a yard with some later calipers and I'll find out tomorrow if they'll work.
Out of curiosity, are the z32 rear calipers supposed to work with the same mount and caliper as the maxima setup?
Thanks for all the help folks, I know this is a seemingly hopeless endeavor.
They are not interchangeable, The control arms has welded on mounting ears. The early style has them closer together, so you can't just take a late model caliper and bolt it to the control arm.
They are interchangeable if you take the control arm, but you CAN NOT bolt late model calipers to an early style control arm or vice cersa.
Edit: Yes the z32 calipers have the same bolt spacing as the maxima rear calipers and s13/s14 240sx rear calipers. Spacing between the rotor and caliper will be a different issue.
Edited by BluDestiny
Well, I saw that at the parts yard today. This leaves me with the idea that this is an incorrectly built bracket, that was indeed intended to use early 280zx calipers and rotors. And it was discovered that they didn't fit, and just sold off.....
as annoying as that notion may be, I've decided that I'm done wasting my time on this, and saw some z32 calipers at the yard. I got them, and now I'm going to just build my own bracket like I should have done in the first place.
Thanks everyone for trying to assist me!
