inline6
5 hours ago, HowlerMonkey said:
Once they tighten down the valve cover bolts or cam housing bolts, enough pressure is generated to blow out where the hole ends leaving quarter sized 10mm wedge shaped chunks of cylinder head that eventually find their way to between the cam and a cam following cup.
It only takes a little bit of oil to cause disaster.
Bizarre.  So, assembly lube inside the bolt holes... (e.g. mains and rods), causing hydro-lock.  Yeah, hadn't thought of that.
  • 1 year later...
Posted (edited)
I have finally switched my focus to getting this car running again.  This weekend I painted the engine block of the new replacement engine.  I was hoping to get it in the car, but various things slowed down my progress.  I thought I had a pilot bushing on hand, but couldn't find it.  So, a trip to the store for that...  Couldn't find the torque spec for the ARP flywheel bolts and wasted time looking for that.  Little things like that eat time.
Anyway, a few pics:
IMG_20250615_113515.jpg.dd6ded17ab034f1034e1ec55dec96e39.jpg  IMG_20250615_114023.jpg.b78e81a5bb38609cebedba6b56edecc2.jpg  IMG_20250615_114029.jpg.e87f0f348bb7d1b83df9b35ba22826fc.jpg
IMG_20250615_114209.jpg.97aa05822dd5af75c77606b8779a1982.jpg  IMG_20250615_114244.jpg.d9a3d4c024b1d116e4ea750441c7fc39.jpg  IMG_20250615_114439.jpg.7dda6c0f14fcdcd6c214990dd15e9173.jpg
With the back plate, flywheel, disc, and pressure plate now on, I am about ready to put the engine in.  I think I will strip and repaint the motor mounts first.  Then, I'll put the engine in and start the work to mount the oil tank for the dry sump.  I will likely need to cut some of the inner fender well on the right side.
I don't like going that route on my "early" Z, but I dislike blown motors more.
Edited by inline6
  • Like 2
The Rebello/BHD damper single groove pulley was made to tame the V07 Diesel stroker crank.  I have one.  works well.  Make sure you blow out the holes before putting the bolts back in, it almost looks like the threads are galled from foreign matter being in the holes when you assembled it.
The cam should be able to be heated and straightened by a machine shop.
I put the engine in the car last weekend.  This weekend I am doing a lot of staring at it and thinking.  I need to figure out how and where to route all of the oiling lines.  And I need to figure out what to do for a radiator and cooling fan as the Griffin I bought is 3" thick and is awfully close to the crank dampener bolt.
Those are the immediate concerns.  I still have to wire up and install a set of Speedhut gauges, drain and flush the gas tank and lines, and a bunch of other stuff before I can attempt to start the new engine.
Going to put the tank about here:
Have to cut sheet metal here to get the tank low enough to fit under the hood:
IMG_20250628_124934.jpg.971c95f4f8faf4008490ad0c42e9a1fd.jpg  IMG_20250628_164202.jpg.019838d8477e9369d92aaeb8bc5a5e51.jpg  IMG_20250628_171826.jpg.b0e2a1d28fabe0597f0f29e2bdff9dce.jpg
Pump and custom mount:
IMG_20250628_124918.jpg.942a292ef7fb2250339e3b84f6b9a485.jpg  IMG_20250628_160219.jpg.ae798228567a894a48a2af2161893eb6.jpg  IMG_20250628_160234.jpg.e78ae5e3ccf1046b24187a9b2dbe2962.jpg
There is a good amount of space under the pan.  I will route the two pan scavenge lines under here to the bottom two fitting on the pump.
IMG_20250628_171706.jpg.a9040dc23cc1d1f9ff2ad9b1d6d7e37a.jpg  IMG_20250628_171716.jpg.2f320d039b4b0eadb0a675883d592991.jpg  IMG_20250628_171735.jpg.8f50be0044efff6c94d4ec63fe979142.jpg
I can clock the bottom of the tank about 90 degrees to get the bottom fitting pointed towards the left side, and then I might be able to run a line from there, across the top of the transmission bell housing to the left side of the engine compartment, and run it along the frame rail to the front of the pump.
Radiator situation - Griffin set in place in first pic is very close to the crank and oil pump shaft.  The Stealth Conversions radiator is much thinner, but even some the 14" Spal would be a tight fit.  And when I was last at the track with this radiator, the temp gauge indicated slightly elevated temperatures from normal.
IMG_20250628_172037.jpg.a726eb4de8f8d5385cc358a833e78260.jpg  IMG_20250628_180252.jpg.46a397d9aeff1a9c454f37b1489ef2b5.jpg  IMG_20250628_182109.jpg.430e837ad245fbb003d86780a08d6ec1.jpg
So, I'd prefer not to put that radiator back in this car for that reason.  It was fine though for all use except track sessions in the August heat in Atlanta.  I had no shrouding and a stock clutch fan (plastic) when it was last installed.
After lots of measuring and thinking, I ordered another Griffin radiator and two 10" Spal fans.  This radiator is a bit wider and the same height as the other Griffin I bought years ago.  However, the core has two 1" wide tubes instead of the two 1.25" wide tubes.  Thus, the core is a bit thinner and that helps provide a bit more room for the fans.  Being a bit wider, the two 10" fans fit better as well.  Here are some pics:
IMG_20250701_190700.jpg.e4531e7380146d76ab4d273e1ca20466.jpg  IMG_20250701_190708.jpg.566c81e5ecd88e0a8f47555e5c3cc3da.jpg  IMG_20250701_185949.jpg.730b9e8e55f1b6f8443d44f0013e22bd.jpg
I will mount the fans at the top as shown.  This will put the fans above the oil pump shaft and crankshaft dampener bolt.  I will probably shorten the oil pump shaft, as the extra length is not needed for this application.
IMG_20250701_190002.jpg.07992da9ac3a6fc78d1e6cff3e4de120.jpg  IMG_20250701_190009.jpg.48823f7d2520006c077ba395c1fa46b4.jpg  IMG_20250701_190023.jpg.9ff7658ebabf7c038761a0ea98c81579.jpg
The bottom edge of the radiator aligns with the bottom edge of this blue painter's tape.  The side tanks fit just inside the stock radiator mount bolt locations:
IMG_20250629_160832.jpg.58261626fb5e0edc28da1998921b7438.jpg  IMG_20250701_190725.jpg.a96473c63f0946fb022558c2dfa3e2dd.jpg  IMG_20250701_190739.jpg.5f318eb781922a87eaabaa939fc75973.jpg
I am very pleased with this combination from a fit standpoint.   Each fan is rated at 802 CFM.  I repeatedly came across information where the CFM was higher when they were used in pairs in combination with shrouding.  So, I plan to add some shrouding as well as some directing panels on the front to improve total CFM.  I won't be able to measure it, but I think bumping the total up to 2000, an amount that should be good for a 6 cylinder engine, should be possible.
Next, I will figure out how to mount the radiator, and wire up the fans.
Posted (edited)
Progress today was slow because I ran into some further complications with adding a shroud along with the fans and radiator.  Adding a shroud to my plan has made things more difficult.
After much thought, I measured out and bent up a custom shroud.  At the top, the shroud is spaced 1" from the fins.  At the bottom, it is spaced only 1/4" from the fins.  This was done to get a bit more clearance.  So, it angles a bit from top to bottom.  Additionally, I had to offset the fans so the top edge of them sits above the top edge of the shroud.  This allowed me to get clearance at the oil pump belt.  To cover the area where the fan extends above the shroud, I made a little aluminum extension.  I plan to weld it to the shroud at the top.  I will make another for the second fan and weld it in as well.  At the lower part of the shroud, I will install some rubber flaps of some sort so that area will not just be a wall where air can't get through the radiator.
IMG_20250712_175709.jpg.0d4675709d304238f202ebcdf6bbbe17.jpg  IMG_20250712_162836.jpg.2bef6b418bc324a4c7c9e9ce353b0add.jpg  IMG_20250712_162812.jpg.167e798513653ec4cf23d66846503d3f.jpg
IMG_20250712_185708.jpg.9d65ad5603e45fa5355331aedd5021ab.jpg  IMG_20250712_185658.jpg.bec68e9dec52ab1c55595e77ec21992f.jpg  IMG_20250712_185637.jpg.3bdb598b99a280f7ee34066f6d4d57dc.jpg
IMG_20250712_185626.jpg.bad03210a021524730d12c56b277ab41.jpg  IMG_20250712_162459.jpg.0165268e2d8ef66a665aeccc21a7b722.jpg  IMG_20250712_162533.jpg.dce910db278e3d9cedfc9e0702759067.jpg
IMG_20250712_162632.jpg.390a8061c0135d568078606612bf6570.jpg  IMG_20250712_163005.jpg.3e13ca0b5b42e758a16a2b264f47cb7a.jpg  IMG_20250712_162431.jpg.3cc5a7ab95681e49e84e45a9d600e0d6.jpg
I am going to replace the studs in the water pump (that hold on the pulley) with bolts instead.  That will add about 3/16" more clearance to the fan.  Additionally, I think I will need to put a strap on the inside of the shroud to strengthen it at the middle - this will be my attempt to keep it from getting pushed back (flexing) at high speed, and moving the fans closer to the rotating parts of the engine.
Edited by inline6
Posted (edited)
Another weekend of work has gone by, with my efforts spent on mounting the radiator.  Time spent thinking of bracket design was more than I would have preferred.  However, I did come up with something that will work well.
Had I to do it again from scratch, I would use thicker sheet metal.  What I have done here instead is fabricate up some brackets using some .032" (.8 mm) sheet.  After test fitting them, I found it necessary to double up the part that bolts to the lower box channel of the radiator support.  For the lower bolt hole in the bracket, I installed a rivet nut in the frame.  For the upper hole (drilled after mounting the brackets using a bolt in the lower hole), I drilled through where the back face of the lower frame is spot welded to the front U section and used 6 mm x 1 mm bolts, washers and nuts.  Being two layers thick at that part of the original frame box, it is pretty solid there.
IMG_20250719_220044.jpg.2ab04d53d3a87384879e815b784a6d9c.jpg  IMG_20250720_124703.jpg.33907143f950d865f1aa50a15e268005.jpg  IMG_20250720_124633.jpg.30cc9f21e36cf49f17d8d5fab2fcc819.jpg
The lower brackets will handle the weight of a full radiator as well as g forces from bumps and braking.
IMG_20250720_124715.jpg.9e8cb3ddbf55b20ad7ce91de2906ace7.jpg  IMG_20250720_124902.jpg.c3883f36c11d1a894172439f1d3fd632.jpg  IMG_20250720_131537.jpg.2fe3bf8f76717dd07206ad61214be460.jpg
The rubber cushions support the radiator from the underside.  To keep the radiator from shifting forward and back, or left and right, I came up with the idea to attach these brackets with holes that positively locate on the rubber mounts.
IMG_20250720_144104.jpg.2100efca63e16c17843c14be001c7ac6.jpg  IMG_20250720_160342.jpg.81a4f1ec1f2d39252d6586addebb72e8.jpg  IMG_20250720_160350.jpg.2075de6a354616d0e161a6e825532f9c.jpg
Even with a lot of care when taking measurements, I ended up with holes needing to be offset toward the front instead of centered.  Oh well.
With this set of pictures showing the single top mount bracket, you can see a bit better how this design works.  The bracket with the hole is 1/8" thick aluminum.  That is riveted to the U channel at the top of the radiator.  Another bracket which will bolt to the radiator support using an already existing welded in nut (7 mm with 1 mm thread), has a third rubber bumper bolted to it.  This bumper positively locates the radiator via the hole in the bracket which is riveted to the radiator.  The bumper in this upper bracket sandwiches the radiator (between the two lower bumpers and the upper bumper).  I have also made the upper bracket with a rear, downturned flange.  I will glue a piece of rubber insulator inside the back lip of this upper bracket.  This will prevent the radiator from moving backward, as it might otherwise when the car is at high speed and air is pressing hard against the front of the radiator.
IMG_20250720_171621.jpg.27ec725e76b45115dee9c43e499adc15.jpg  IMG_20250720_171639.jpg.cc5a55b78d55cd9d39ba5b75a8356a9b.jpg  IMG_20250720_171646.jpg.7e4c5c839e5682d49fe69fef070b6907.jpg
I may need to come up with a similar type of flange to add at the bottom of the radiator for the same functionality.  My clearances are so tight at between the fans and the front of the engine, that I need to ensure no rearward movement of the radiator can occur.
Edited by inline6
Today, I turned my attention to mounting the oil tank.  Like the radiator, getting it to fit is quite a challenge.  When placed against the firewall, the mounting brackets interfere with the brake and clutch hard lines, and the raised "ribs" in the firewall panel.  I could space it out from the firewall, and still mount it there, but I came up with an alternative that I like.  It will allow me to mount the tank far enough from the firewall to avoid wiring and hard lines and "ribs".  I will be fabricating a mounting bracket which will connect diagonally from the firewall to the right inner fender.  The final location of the tank will be just low enough to keep the filler cap from hitting the hood, and the drain will be located a couple of inches above the frame rail.
IMG_20250726_182033.jpg.abbec858c1ff4a156777acc5cad0ea41.jpg  IMG_20250726_181941.jpg.de5c3af788732315fdd5cd161c072acf.jpg  IMG_20250726_175233.jpg.fcfa5b69b3a43e68ccd507400582278c.jpg
IMG_20250726_175248.jpg.935fbce8b77eb3d786b2879ca3def737.jpg  IMG_20250726_175258.jpg.bcbe161ff251b695d0aa18d2e4f0f8e6.jpg  IMG_20250726_175309.jpg.48df2532078699f61a2397cea2364839.jpg
Additionally, I purchased a Braille battery which is much smaller than the original.  I will make and weld in a steel platform for it that will be similar to how it was done originally by Nissan.  It will be a smaller platform, of course, but I will weld it to the inner fender in two locations and not to the firewall.
IMG_20250726_181807.jpg.0ce754c71b7408f2c83138ba8054d954.jpg  IMG_20250726_182018.jpg.d04cc82d88b83ab3d69c2e463cbdcb7f.jpg  IMG_20250726_181818.jpg.d2e0f644219b8cd62edb13767b1ba15e.jpg
At the top and bottom of the oil tank mounting bracket, I will put a 90 degree bend to add rigidity.  I have some 1/8" thick 6061 aluminum I will use.  Additionally, I have some aluminum angle.  I may reinforce the top edge of the mounting plate with some of that.  The bracket will be mounting to the firewall with two bolts (a reinforcement plate will be on the backside of the firewall), and to the front inner fender with two bolts.
I may tie into the top edge of the oil mounting bracket in some way... to secure the battery in place.  I want to be able to remove the battery without having to dismount the tank.  So, that will be guiding my design effort for what I come up with to secure the battery in place.
Edited by inline6
