inline6
5 hours ago, HowlerMonkey said:
Once they tighten down the valve cover bolts or cam housing bolts, enough pressure is generated to blow out where the hole ends leaving quarter sized 10mm wedge shaped chunks of cylinder head that eventually find their way to between the cam and a cam following cup.
It only takes a little bit of oil to cause disaster.
Bizarre.  So, assembly lube inside the bolt holes... (e.g. mains and rods), causing hydro-lock.  Yeah, hadn't thought of that.
  • 1 year later...
I have finally switched my focus to getting this car running again.  This weekend I painted the engine block of the new replacement engine.  I was hoping to get it in the car, but various things slowed down my progress.  I thought I had a pilot bushing on hand, but couldn't find it.  So, a trip to the store for that...  Couldn't find the torque spec for the ARP flywheel bolts and wasted time looking for that.  Little things like that eat time.
Anyway, a few pics:
IMG_20250615_113515.jpg.dd6ded17ab034f1034e1ec55dec96e39.jpg  IMG_20250615_114023.jpg.b78e81a5bb38609cebedba6b56edecc2.jpg  IMG_20250615_114029.jpg.e87f0f348bb7d1b83df9b35ba22826fc.jpg
IMG_20250615_114209.jpg.97aa05822dd5af75c77606b8779a1982.jpg  IMG_20250615_114244.jpg.d9a3d4c024b1d116e4ea750441c7fc39.jpg  IMG_20250615_114439.jpg.7dda6c0f14fcdcd6c214990dd15e9173.jpg
With the back plate, flywheel, disc, and pressure plate now on, I am about ready to put the engine in.  I think I will strip and repaint the motor mounts first.  Then, I'll put the engine in and start the work to mount the oil tank for the dry sump.  I will likely need to cut some of the inner fender well on the right side.
I don't like going that route on my "early" Z, but I dislike blown motors more.
Edited by inline6
  • Like 2
The Rebello/BHD damper single groove pulley was made to tame the V07 Diesel stroker crank.  I have one.  works well.  Make sure you blow out the holes before putting the bolts back in, it almost looks like the threads are galled from foreign matter being in the holes when you assembled it.
The cam should be able to be heated and straightened by a machine shop.
I put the engine in the car last weekend.  This weekend I am doing a lot of staring at it and thinking.  I need to figure out how and where to route all of the oiling lines.  And I need to figure out what to do for a radiator and cooling fan as the Griffin I bought is 3" thick and is awfully close to the crank dampener bolt.
Those are the immediate concerns.  I still have to wire up and install a set of Speedhut gauges, drain and flush the gas tank and lines, and a bunch of other stuff before I can attempt to start the new engine.
Going to put the tank about here:
Have to cut sheet metal here to get the tank low enough to fit under the hood:
IMG_20250628_124934.jpg.971c95f4f8faf4008490ad0c42e9a1fd.jpg  IMG_20250628_164202.jpg.019838d8477e9369d92aaeb8bc5a5e51.jpg  IMG_20250628_171826.jpg.b0e2a1d28fabe0597f0f29e2bdff9dce.jpg
Pump and custom mount:
IMG_20250628_124918.jpg.942a292ef7fb2250339e3b84f6b9a485.jpg  IMG_20250628_160219.jpg.ae798228567a894a48a2af2161893eb6.jpg  IMG_20250628_160234.jpg.e78ae5e3ccf1046b24187a9b2dbe2962.jpg
There is a good amount of space under the pan.  I will route the two pan scavenge lines under here to the bottom two fitting on the pump.
IMG_20250628_171706.jpg.a9040dc23cc1d1f9ff2ad9b1d6d7e37a.jpg  IMG_20250628_171716.jpg.2f320d039b4b0eadb0a675883d592991.jpg  IMG_20250628_171735.jpg.8f50be0044efff6c94d4ec63fe979142.jpg
I can clock the bottom of the tank about 90 degrees to get the bottom fitting pointed towards the left side, and then I might be able to run a line from there, across the top of the transmission bell housing to the left side of the engine compartment, and run it along the frame rail to the front of the pump.
Radiator situation - Griffin set in place in first pic is very close to the crank and oil pump shaft.  The Stealth Conversions radiator is much thinner, but even some the 14" Spal would be a tight fit.  And when I was last at the track with this radiator, the temp gauge indicated slightly elevated temperatures from normal.
IMG_20250628_172037.jpg.a726eb4de8f8d5385cc358a833e78260.jpg  IMG_20250628_180252.jpg.46a397d9aeff1a9c454f37b1489ef2b5.jpg  IMG_20250628_182109.jpg.430e837ad245fbb003d86780a08d6ec1.jpg
So, I'd prefer not to put that radiator back in this car for that reason.  It was fine though for all use except track sessions in the August heat in Atlanta.  I had no shrouding and a stock clutch fan (plastic) when it was last installed.
After lots of measuring and thinking, I ordered another Griffin radiator and two 10" Spal fans.  This radiator is a bit wider and the same height as the other Griffin I bought years ago.  However, the core has two 1" wide tubes instead of the two 1.25" wide tubes.  Thus, the core is a bit thinner and that helps provide a bit more room for the fans.  Being a bit wider, the two 10" fans fit better as well.  Here are some pics:
IMG_20250701_190700.jpg.e4531e7380146d76ab4d273e1ca20466.jpg  IMG_20250701_190708.jpg.566c81e5ecd88e0a8f47555e5c3cc3da.jpg  IMG_20250701_185949.jpg.730b9e8e55f1b6f8443d44f0013e22bd.jpg
I will mount the fans at the top as shown.  This will put the fans above the oil pump shaft and crankshaft dampener bolt.  I will probably shorten the oil pump shaft, as the extra length is not needed for this application.
IMG_20250701_190002.jpg.07992da9ac3a6fc78d1e6cff3e4de120.jpg  IMG_20250701_190009.jpg.48823f7d2520006c077ba395c1fa46b4.jpg  IMG_20250701_190023.jpg.9ff7658ebabf7c038761a0ea98c81579.jpg
The bottom edge of the radiator aligns with the bottom edge of this blue painter's tape.  The side tanks fit just inside the stock radiator mount bolt locations:
IMG_20250629_160832.jpg.58261626fb5e0edc28da1998921b7438.jpg  IMG_20250701_190725.jpg.a96473c63f0946fb022558c2dfa3e2dd.jpg  IMG_20250701_190739.jpg.5f318eb781922a87eaabaa939fc75973.jpg
I am very pleased with this combination from a fit standpoint.   Each fan is rated at 802 CFM.  I repeatedly came across information where the CFM was higher when they were used in pairs in combination with shrouding.  So, I plan to add some shrouding as well as some directing panels on the front to improve total CFM.  I won't be able to measure it, but I think bumping the total up to 2000, an amount that should be good for a 6 cylinder engine, should be possible.
Next, I will figure out how to mount the radiator, and wire up the fans.
Progress today was slow because I ran into some further complications with adding a shroud along with the fans and radiator.  Adding a shroud to my plan has made things more difficult.
After much thought, I measured out and bent up a custom shroud.  At the top, the shroud is spaced 1" from the fins.  At the bottom, it is spaced only 1/4" from the fins.  This was done to get a bit more clearance.  So, it angles a bit from top to bottom.  Additionally, I had to offset the fans so the top edge of them sits above the top edge of the shroud.  This allowed me to get clearance at the oil pump belt.  To cover the area where the fan extends above the shroud, I made a little aluminum extension.  I plan to weld it to the shroud at the top.  I will make another for the second fan and weld it in as well.  At the lower part of the shroud, I will install some rubber flaps of some sort so that area will not just be a wall where air can't get through the radiator.
IMG_20250712_175709.jpg.0d4675709d304238f202ebcdf6bbbe17.jpg  IMG_20250712_162836.jpg.2bef6b418bc324a4c7c9e9ce353b0add.jpg  IMG_20250712_162812.jpg.167e798513653ec4cf23d66846503d3f.jpg
IMG_20250712_185708.jpg.9d65ad5603e45fa5355331aedd5021ab.jpg  IMG_20250712_185658.jpg.bec68e9dec52ab1c55595e77ec21992f.jpg  IMG_20250712_185637.jpg.3bdb598b99a280f7ee34066f6d4d57dc.jpg
IMG_20250712_185626.jpg.bad03210a021524730d12c56b277ab41.jpg  IMG_20250712_162459.jpg.0165268e2d8ef66a665aeccc21a7b722.jpg  IMG_20250712_162533.jpg.dce910db278e3d9cedfc9e0702759067.jpg
IMG_20250712_162632.jpg.390a8061c0135d568078606612bf6570.jpg  IMG_20250712_163005.jpg.3e13ca0b5b42e758a16a2b264f47cb7a.jpg  IMG_20250712_162431.jpg.3cc5a7ab95681e49e84e45a9d600e0d6.jpg
I am going to replace the studs in the water pump (that hold on the pulley) with bolts instead.  That will add about 3/16" more clearance to the fan.  Additionally, I think I will need to put a strap on the inside of the shroud to strengthen it at the middle - this will be my attempt to keep it from getting pushed back (flexing) at high speed, and moving the fans closer to the rotating parts of the engine.
Edited by inline6
Another weekend of work has gone by, with my efforts spent on mounting the radiator.  Time spent thinking of bracket design was more than I would have preferred.  However, I did come up with something that will work well.
Had I to do it again from scratch, I would use thicker sheet metal.  What I have done here instead is fabricate up some brackets using some .032" (.8 mm) sheet.  After test fitting them, I found it necessary to double up the part that bolts to the lower box channel of the radiator support.  For the lower bolt hole in the bracket, I installed a rivet nut in the frame.  For the upper hole (drilled after mounting the brackets using a bolt in the lower hole), I drilled through where the back face of the lower frame is spot welded to the front U section and used 6 mm x 1 mm bolts, washers and nuts.  Being two layers thick at that part of the original frame box, it is pretty solid there.
IMG_20250719_220044.jpg.2ab04d53d3a87384879e815b784a6d9c.jpg  IMG_20250720_124703.jpg.33907143f950d865f1aa50a15e268005.jpg  IMG_20250720_124633.jpg.30cc9f21e36cf49f17d8d5fab2fcc819.jpg
The lower brackets will handle the weight of a full radiator as well as g forces from bumps and braking.
IMG_20250720_124715.jpg.9e8cb3ddbf55b20ad7ce91de2906ace7.jpg  IMG_20250720_124902.jpg.c3883f36c11d1a894172439f1d3fd632.jpg  IMG_20250720_131537.jpg.2fe3bf8f76717dd07206ad61214be460.jpg
The rubber cushions support the radiator from the underside.  To keep the radiator from shifting forward and back, or left and right, I came up with the idea to attach these brackets with holes that positively locate on the rubber mounts.
IMG_20250720_144104.jpg.2100efca63e16c17843c14be001c7ac6.jpg  IMG_20250720_160342.jpg.81a4f1ec1f2d39252d6586addebb72e8.jpg  IMG_20250720_160350.jpg.2075de6a354616d0e161a6e825532f9c.jpg
Even with a lot of care when taking measurements, I ended up with holes needing to be offset toward the front instead of centered.  Oh well.
With this set of pictures showing the single top mount bracket, you can see a bit better how this design works.  The bracket with the hole is 1/8" thick aluminum.  That is riveted to the U channel at the top of the radiator.  Another bracket which will bolt to the radiator support using an already existing welded in nut (7 mm with 1 mm thread), has a third rubber bumper bolted to it.  This bumper positively locates the radiator via the hole in the bracket which is riveted to the radiator.  The bumper in this upper bracket sandwiches the radiator (between the two lower bumpers and the upper bumper).  I have also made the upper bracket with a rear, downturned flange.  I will glue a piece of rubber insulator inside the back lip of this upper bracket.  This will prevent the radiator from moving backward, as it might otherwise when the car is at high speed and air is pressing hard against the front of the radiator.
IMG_20250720_171621.jpg.27ec725e76b45115dee9c43e499adc15.jpg  IMG_20250720_171639.jpg.cc5a55b78d55cd9d39ba5b75a8356a9b.jpg  IMG_20250720_171646.jpg.7e4c5c839e5682d49fe69fef070b6907.jpg
I may need to come up with a similar type of flange to add at the bottom of the radiator for the same functionality.  My clearances are so tight at between the fans and the front of the engine, that I need to ensure no rearward movement of the radiator can occur.
Edited by inline6
Today, I turned my attention to mounting the oil tank.  Like the radiator, getting it to fit is quite a challenge.  When placed against the firewall, the mounting brackets interfere with the brake and clutch hard lines, and the raised "ribs" in the firewall panel.  I could space it out from the firewall, and still mount it there, but I came up with an alternative that I like.  It will allow me to mount the tank far enough from the firewall to avoid wiring and hard lines and "ribs".  I will be fabricating a mounting bracket which will connect diagonally from the firewall to the right inner fender.  The final location of the tank will be just low enough to keep the filler cap from hitting the hood, and the drain will be located a couple of inches above the frame rail.
IMG_20250726_182033.jpg.abbec858c1ff4a156777acc5cad0ea41.jpg  IMG_20250726_181941.jpg.de5c3af788732315fdd5cd161c072acf.jpg  IMG_20250726_175233.jpg.fcfa5b69b3a43e68ccd507400582278c.jpg
IMG_20250726_175248.jpg.935fbce8b77eb3d786b2879ca3def737.jpg  IMG_20250726_175258.jpg.bcbe161ff251b695d0aa18d2e4f0f8e6.jpg  IMG_20250726_175309.jpg.48df2532078699f61a2397cea2364839.jpg
Additionally, I purchased a Braille battery which is much smaller than the original.  I will make and weld in a steel platform for it that will be similar to how it was done originally by Nissan.  It will be a smaller platform, of course, but I will weld it to the inner fender in two locations and not to the firewall.
IMG_20250726_181807.jpg.0ce754c71b7408f2c83138ba8054d954.jpg  IMG_20250726_182018.jpg.d04cc82d88b83ab3d69c2e463cbdcb7f.jpg  IMG_20250726_181818.jpg.d2e0f644219b8cd62edb13767b1ba15e.jpg
At the top and bottom of the oil tank mounting bracket, I will put a 90 degree bend to add rigidity.  I have some 1/8" thick 6061 aluminum I will use.  Additionally, I have some aluminum angle.  I may reinforce the top edge of the mounting plate with some of that.  The bracket will be mounting to the firewall with two bolts (a reinforcement plate will be on the backside of the firewall), and to the front inner fender with two bolts.
I may tie into the top edge of the oil mounting bracket in some way... to secure the battery in place.  I want to be able to remove the battery without having to dismount the tank.  So, that will be guiding my design effort for what I come up with to secure the battery in place.
Edited by inline6
I'd suggest a flat metal bracket that bolts (rivnuts) to the inner fender and goes over the top of the battery and has a small jog bend to capture the side and then bolts to the upper angle of the drysump tank bracket.  And maybe some aluminum angle riveted to the bottom to keep the battery from shifting.
After several weeks of various distractions, I was able to commit a bunch of hours to working on the "track car" this weekend.  I recently purchased some nice tools to make fabrication projects easier.  Here are some pics of tools:  :)
And with those on hand, I was able to make a nice battery tray for the new Braille battery.  The spot welder I bought several years ago was awesome to use as well.
I, am very happy with how this part came out, even if it did take me about 9 hours to make it (!)
I still have to design a battery clamp down mechanism to hold the battery to this new tray, so I will work on that soon.  With the battery tray temporarily in place, I again mounted the dry sump tank, and started figuring out all the fittings I will need for the lines for the dry sump system.  I plan to order those soon and then mock up some hoses.
  • Like 1
This past weekend I made some more progress.  I worked on cutting the right inner wheel house, made two new panels, and welded them into place.  I used thin cardboard to make templates for the two replacement panels.  After tack welding the lower panel in place, I made the second, upper panel.
IMG_20251013_150005.jpg.f146d7a94eb3f10503b48ca03110f3be.jpg  IMG_20251013_150017.jpg.e66eeb4f509b2f822941e82d7819a8b6.jpg  IMG_20251013_150040.jpg.3a4042f5bdf168657b58555f16b7ce1f.jpg
IMG_20251013_150056.jpg.0a3f9dcaeefec9d80bf0d193d08224d0.jpg  IMG_20251013_153139.jpg.89ced5058bac6b821ecba5f8eca367ca.jpg  IMG_20251013_165920.jpg.24e0395bd78175a44fbe11116a208110.jpg
I checked tire clearance, and then finished welding them in.  I think my welding regulator is inaccurate.  I was getting some contaminated welds until I bumped the gauge up to 27 psi (I have always used 20).  Once I bumped the pressure up, the welds got a lot better.
IMG_20251013_181747.jpg.6c58b891d736f37a2ebf227db550d5d4.jpg  IMG_20251013_181807.jpg.263cb2d4524b5f3f904d89e58028e19d.jpg  IMG_20251013_183008.jpg.37b45b71f3bff7af152e0d4e2ba6bf95.jpg
IMG_20251013_183014.jpg.c1cd009cb914828bd08a4412f2fe7341.jpg  IMG_20251013_183051.jpg.eed18a44dec731be7ab3c7b5070b1553.jpg  IMG_20251013_183110.jpg.33416c8fedbfe817d4b0b4ee0403fd7e.jpg
Metal fabrication like this always takes me a long time to do.  I am glad this part of the work behind me now.
I ordered a remote filter assembly and mount, and a breather tank this week end.  They should be here in a few days.  Then I should be able to finish up my order for XRP fittings for the entire oil system.  I plan to buy the fittings and install them all so I can check/set orientation.  Then I will buy some corrugated pool hose for the purposes of mocking up the lines.  I will cut it to fit for each hose assembly, and then mark the hose and fittings to "clock" them in the correct orientation.  Finally, I will box all of them up and ship them off to have an XRP distributor install Pro Plus Xtreme hoses with crimp on fittings.
Next up is the oil filter remote mount.  I fabricated an aluminum bracket to attach the mount to the right inner wheel house.  On the 46 BRE Z, the mount is on the inside of the strut tower.  I wanted it to be a bit more forward in the engine compartment, as I think that facilitates a slightly better routing of the line from the "out" of the remote mount to the input on the engine block.  Essentially the line just needs to turn 90 degrees to go into the block, plus some angle to handle the height difference.  Here are some pics from various angles.
IMG_20251017_191324.jpg.3d711f6c2c0b9ea3bff19b113048940e.jpg  IMG_20251017_191311.jpg.968fd34d1f66498ece204de671d8889e.jpg  IMG_20251017_191340.jpg.17d1bb00db673ff3df35a108bc1c7509.jpg
IMG_20251017_191400.jpg.a5f279b6c5e822369e23fa7718cb2f9d.jpg  IMG_20251017_191407.jpg.0e71b3fc0cacf02f01a1555580cd7a75.jpg  IMG_20251017_191429.jpg.1382767240887ddcce1eaabba66647fd.jpg
I am planning on running the supply and scavenge lines across the front of the engine at the front "cover plate" location, where I am running a Kaminari timing chain tensioner.
I could fabricate a bracket to mount the oil filter more vertical than I have done here, but I chose this angle to keep the outlet tangential to the shock tower innermost surface.  I plan to secure the hose with a rubber lined "P clamp" at the shock tower and then bend the hose for a straight (ish) run to the block.  I also am thinking that angling the oil filter out like this will allow me to run the scavenge line between the wheel house and the filter (in the gap that exists) and secure the scavenge line also to the shock tower with a P clamp.  If the oil filter was vertical instead, the scavenge line would have to pass by the filter on the other side, where it would be free floating - not as easily secured.
That is my thinking anyway.  I have never run lines like this for a dry sump system.  So, doing what I think is best.
Edited by inline6
Next up, is mounting the the breather reservoir.  Things are tight... very tight.  But I think this location will work.
IMG_20251018_155711.jpg.3007c79ada67e8ef3aecebf2ae572501.jpg  IMG_20251018_155741.jpg.020edc2007888b9b12dbd7e05853ef1f.jpg  IMG_20251018_155758.jpg.1254d401865ef44580fc0230af5afd99.jpg
IMG_20251018_155816.jpg.796fbc21cb8e4c1e8b2259154026b28d.jpg  IMG_20251018_155833.jpg.f58c5cca21366292d335cc8df18383b9.jpg
I was able to use a simple "L" shaped bracket, bolted to the top flange of the bracket I used to mount the tank.  It wasn't very rigid... until I tied it into the vertical steel panel that drops down from the inner fender support.  Now, the main panel (and breather tank bracket) is secured on three of the four sides.  I am pleased with the result.
I just need to tweak the mounting tab locations every so slightly to get everything vertically set at the proper angle - it is a shade off at the moment.  Though a pain, I can remove the battery without disturbing any of the oil system.  This was one of my requirements when coming up with mounting the brackets.
Now, it is time to finalize the order for the fittings.
Final oil breather tank location and clocking.  I will route a short hose from the tank vent out (red cap) to the black male AN fitting on the breather.  The other fitting opening on the breather will be routed to the valve cover later.
The hose in the picture is some kind of "pool" related hose.  It is made out of plastic/vinyl with one coil wire in it.  The ID is about the same as the AN fittings.  I have one for -12 AN and one for -16 AN.  I just heat the end up a bit with a heat gun and quickly push it into place on the fitting.  It is working nicely to create "mock-up" lines.  Two scavenge lines from the ARE pan to the pump:
IMG_20251031_133825.jpg.e8f706972349463ce491c1e5c0d85a76.jpg  IMG_20251031_133840.jpg.3a0345ab6af1deded4ad0883b61b8ae9.jpg  IMG_20251031_133937.jpg.7836c5558985652c3e86d3a244076432.jpg
A special short 90 degree -12 AN was needed at the bottom of the tank.  Tank clearance with all of it's surroundings is tight. Routing of two lines across the front of the engine...
IMG_20251031_134259.jpg.1c88c7e6ab034a41a804c739a133d024.jpg  IMG_20251031_134358.jpg.8c5c5043ca047492dcdbbce032374d96.jpg  IMG_20251101_173755.jpg.f8afd4eab860092b9358c33431a96337.jpg
it took a while, but I finally thought up the idea to fabricate a plate for use as a securing point for P clamps to hold the lines securely.  I used some dowels to space the plate away from the head and Kameari chain tensioner.  I may shorten these a bit.
IMG_20251101_173749.jpg.786eac399aea094eca995b825a523698.jpg  IMG_20251101_180907.jpg.1037ef5ee9b70e635a19480a42268230.jpg  IMG_20251101_180929.jpg.7cbd58bc83a9d56b373eb43550391262.jpg
The routing of the lines (one is -16 AN size and one is -12 AN) across the front of the engine - the lines are safely out of the way of the water pump pulley.  I need to buy a longer bolt for the corner of the remote filter to secure another P clamp here (first pic).
IMG_20251101_181005.jpg.a0c8e7304df94a5a12bb01bcb570d655.jpg  IMG_20251101_181051.jpg.0953f047bd307e7d2cc89c7c5a0e203c.jpg  IMG_20251101_181145.jpg.7903b23c41a7c6566d8e5425eb898193.jpg
You may have noticed that I fabricated another remote filter mounting bracket.  This one changes the angle of the oil filter so it is more vertical than the prior one.  I did this when I realized that the -12 AN outlet doesn't need to pass close by the strut tower - instead, it goes directly to the original filter mounting location on the engine block.  I previously was thinking it needed to go to the tank and was planning to secure the line with a P clamp to the tower.  I put a stock lower radiator hose in place to check the situation out.  Removal of the filter will not be difficult.
IMG_20251101_181228.jpg.beebfbff4f4280073c115b42ba15abab.jpg  IMG_20251101_182533.jpg.e93ba82c9d48e87de24e16ef865a3f37.jpg  IMG_20251101_182518.jpg.78051d96782cd4462063c4c4687087d7.jpg
As you can see in the last picture, I will have to modify the radiator coolant outlet somewhat.  I won't be able to use the stock hose as is either.  So, I need to figure out how to proceed to resolve this issue.  I likely will remove the pipe outlet from the radiator, and modify it (or buy another) and weld it back to the radiator, changing the angle in the process.  An "L" shaped tube with the same diameter as the stock hose would be a good solution here.
It seems there isn't much activity on this forum vs. about 10 years ago.  I guess not as many of these cars are still being modified now.
Anyway, an update on some progress.  The pool hose I am using here is just for mock up purposes. It has the right ID to fit tightly on the fittings.  I just heat up the the hose (a plastic/vinyl material of some sort) and then slide on the fitting.  I believe this is helping to establish the actual hose lengths I need as well as "clocking" or indexing the fittings to the hose.
Additionally, though I did not plan it this way originally, I came up with a great design for securing the battery to the tray... and made this upper battery mount bracket in such a way as to tie in to the bracket that I made to mount the oil tank in the car.   The upper bracket I made today not only clamps the battery in place, but also ties into the oil tank bracket and the engine compartment panel, triangulating everything.  This design makes the mounting for the tank very rigid.
I still have a bit to figure out with regard to mounting the forward most part of the bracket that I made today to go on top of the battery.
I think I may cut a plate like this red outline and rivet it to the upper battery bracket.  This panel will sit atop of the angle piece that presently holds the breather tank in position.  Then the two bolts (within the red outline representing the new panel) will join all three layers.
The result here is that the triangulation appears to substantially strengthen the tank bracket.  I won't have issues with the weight of the oil in the tank causing the brackets to bend/fatigue.
  • Like 1
@tube80z - so I have done what you suggested here:
On 8/8/2025 at 7:50 PM, tube80z said:
I'd suggest a flat metal bracket that bolts (riv-nuts) to the inner fender and goes over the top of the battery and has a small jog bend to capture the side and then bolts to the upper angle of the dry sump tank bracket.  And maybe some aluminum angle riveted to the bottom to keep the battery from shifting.
I put lips on the battery tray to keep the battery from shifting at the bottom:
The battery hold down "plate" has a couple of jog bends to capture the angled bracket that the tank mounts to.  I just need to secure this plate I made (what I was referring to with the red outline above) to the main plate to finish this up.
Edited by inline6
  • Like 1
Your work looks great. There isn't as much activity here anymore, but some of us are still watching closely.
I really like the battery bracket. The more spread out the support is, the more secure you can make the battery without damaging it. I've always disliked the common OEM-style hold down bar.
  • Thanks 1
I switched gears a bit this weekend.  I have started working on mounting the SpeedHut gauges I bought several years ago (during a Black Friday sale).
At the block, I installed this distribution block.  Pretty cool that it has 1/8 BSPT male threads to go into the block, and 4, 1/8 NPT outlets (and one 1/8 BSPT outlet). The black, 90 swivel in the picture is going to supply oil directly to the cam spray bar.
IMG_20251119_180149.jpg.7b706909cbf6ef64247738fece5a52ee.jpg  IMG_20251119_180752.jpg.b286bb6fb3dde238a360c63db37ec3a7.jpg
Pictures from my engine builder when he was making the spray bar and fitting it to the engine:
spraybarconnected.jpg.11ccff088733a8464b2a812cb079191a.jpg spraybarcomplete.jpg.d525762a9d08fc8fd189553f4124a971.jpg
Getting the speedometer and tack mounted... has been very involved.  I wish I could say it wasn't a difficult job, but the problem with adaptors that are available is they compromise the look of the finished installation.  I like the look of the polished aluminum bezels that I chose.  And to get them to show somewhat properly, I had to modify the stock pods a ton.  For the first one, I bought some pvc pieces Home Depot.  I had to whittle them down to nearly nothing and glue them to what remained of the pod plastic housing.  It's not worth describing how I did it as there has to be a better way.  For the second one, I was able to repurpose some of what I cut off from the first pod... but still not easy, and not worth sharing what I did specifically, as no one would want to spend the amount of time and effort I did here.  Anyway, I hope to finish mounting the gauges in the dash (removed from the car yesterday) today.
IMG_20251122_123349.jpg.918cc319936ec1fdd410a1547e65c06d.jpg  IMG_20251122_123502.jpg.0e9cdcd170a78369fd1d11cb872b5c33.jpg  IMG_20251122_123707.jpg.93f372362420b7ebb5ea56fcc5461e84.jpg
Because the new gauges are much shallower, I needed to make a sheet metal bracket to support them from behind.  The only way I could think of to do that was to make a large ring to go around the OD of the gauge (the speed hut gauges mount using a large trim ring).  To the flimsy ring I made, I spot welded another bracket I made.  I was able to bend each of the edges of this part about 45 degrees using my metal brake which added some rigidity.  The final thing I need to do is drill holes and mount some threaded studs.  When done, I will be able to secure the gauges to the dash using the stock mounting locations and hardware.
IMG_20251122_173915.jpg.6f3b9d7ebc9c7287703acb9dbc494c03.jpg  IMG_20251122_173906.jpg.b5a551e830a56b29dd4af64cdcb891c4.jpg
The new gauges will not sit as far back in the dash.  Again, due to their OD and fitting to the stock pod, I moved them forward a bit to get the bezel visible - this depth is where they look best.
Edited by inline6
