Dual Wideband O2 Sensors
Ben280
Little about my setup for background, and those not familiar with my build. MS3.57 with the MS3x board for heaps of outputs. OER 45mm ITB's, Kameari intake, high comp Rebello engine.
My new (to me) header is a Pace Setter 3-2 style that has 2 O2 sensor bungs right before the merge meaning I can pick a side and run 1 sensor, OR get all fancy and run 2, keeping track on 1/2/3 OR 4/5/6. I'm on more of a budget now than I used to be, and I'm wondering if anybody can help me justify running dual widebands, rather than a single. I'm thinking it would be helpful to keep tabs on all the cylinders, sort of a "more you know" philosophy, particularly if the ITB's start to drift out of trim. I'm also thinking that the ITB's shouldn't drift too much since everything is running off the megasquirt, rather than trying to line up a bunch of carbs.
Input and experience appreciated!
Not sure about the benefits, other than being able to see two halves instead of one whole.  With old carbs that might be somewhat useful when troubleshooting issues and balancing, but as you said, with new ITB's that are in spec and controlled by a reliable ECU it would likely be overkill.
If it were me, I'd probably just plug both of the existing 02 bungs, and place one further down the line after the marge and call it a day...
I've thought of going the same route , but I run dual pipes.
Pros: redundancy - sensors do go bad , this would be a back up.
Troubleshooting - one more tool
Tuning- what if you want to run 5&6 a bit richer based on detonation issues - separate sensors would help verify
More gauges in the cockpit to impress friends !!
Cons - more money and more wiring
Edited by madkaw
If it was carbeurated and you could get the paired cylinders then it might be useful to tune the carbs.
For EFI it depends on your fuel control. I think my MS3.57 only has two channels for fuel although I don't recall if you can run them independently. I seem to recall a setting like that for things like V engines or dual injectors so it may be available. So if you did split the channels for 123, 456 then you could basically monitor the fuel and trim the fuel and treat the car like it has two 3 cylinders in regards to fuel.
Downfall would be if you wanted the most out of it you would have to look at two logs and tune two maps basically, then run two O2 sensors. If you wanted to keep track of them that would also be two wideband o2 gauges as well.
Lots of good ideas in here guys, thanks! Money and wires are definitely issues to concern myself with. I've got a PLX SM-AFR and an Innovative LC-2 at my disposal, just need to decide if the data I can get is something I'll use, or if it's a case of "more for more's sake".
Jacky4566- Was looking at the Spartan 2's they seem like a great deal, particularly when you don't need anything crazy! Wish I saw them before I bought my LC-2 last year =( Not a street car anymore, so frankly, fuel economy is the last thing on my mind, but full lean conditions tend to yield the most power. They are best before they blow philosophy.
Seattlejester- with the MS3X I get 8 injector and coil drivers, so if I had a cam signal I could run full sequential. As is I just have crank trigger signal so I have to run batch fire and wasted spark. The MS3x board has an input for a 2nd wideband as well, so I can look at a single log for everything!
Madkaw- the OERs are pretty nice so far, I'm updating my build thread with the past 6 months of progress, including ITB setup!
Instead of multiple O 2 sensors you could use electronic Pyro's in each exhausts header.  Much easier to hook up with auxilary inputs in a stand alone than WB controllers. Most Dyno shops have test headers for engines with individual Pyro's. Nascar, WEC and F1 engines all are tested with individual Pyro's per exhaust port. I've seen video's of Renault V8 and  V10 F1 engines on the Dyno, and they only used 1 WB O2 sensor per bank, FWIW
These days F1 engines are  using Turbulent Jet Ignition.  Big hush hush stuff. Main reason why Mercedes has had such a dominant engine the last few years.
http://www.enginelabs.com/news/f1-tech-what-is-turbulent-jet-ignition/
Chickenman, good call with the pyros! That's on the list for sure, but it is a pretty expensive piece of kit to add. Good reminder, and easy to hook up through CANBUS.
I'm going into the dyno in a week, I'll keep everybody posted with what happens, and if the tuner has opinions!
