theczechone Posted April 10, 2017 Share Posted April 10, 2017 (edited) Anyone used this stuff before? https://www.summitracing.com/parts/sft-insul1/overview/ I ended up removing the tar and the original "horse hair" insulation out need something to replace it. Seems that the reviews are good and price is low. Edited April 10, 2017 by theczechone Quote Link to comment Share on other sites More sharing options...
Zetsaz Posted April 10, 2017 Share Posted April 10, 2017 Your link sent me to a VigLink Shopping page for some reason. I'm in for info regardless, but I thought that link problem was fixed a while back. Had to go find the stuff you were talking about myself. Soffseal Sound Deadeners INSUL1? Quote Link to comment Share on other sites More sharing options...
theczechone Posted April 10, 2017 Author Share Posted April 10, 2017 Not sure why that happened but yes soffseal sound deadener Quote Link to comment Share on other sites More sharing options...
Neverdone Posted April 10, 2017 Share Posted April 10, 2017 I was planning on using this https://www.amazon.com/Noico-deadening-automotive-Insulation-dampening/dp/B00URUIKAK Noico 80 insulation (google it if the link doesn't work) It sticks pretty well to things and isn't very expensive either. Quote Link to comment Share on other sites More sharing options...
Greeko Posted April 10, 2017 Share Posted April 10, 2017 I used the Noico 80Ml product for my entire vehicle. It works really well and is a great value!!~ Quote Link to comment Share on other sites More sharing options...
theczechone Posted April 10, 2017 Author Share Posted April 10, 2017 i like the noico! one thing i was worried about with the soffseal is how thick it was 3/8" also how well would the vinyl stick to it. noico seems like a better option Quote Link to comment Share on other sites More sharing options...
walkerbk Posted April 10, 2017 Share Posted April 10, 2017 Get this stuff from home depot. They only sell it online and it is the same as the automotive material http://m.homedepot.com/p/UltraTouch-48-in-x-6-ft-Radiant-Barrier-30000-11406/100656748?MERCH=REC-_-PIPHorizontal1-2-_-NA-_-100656748-_-N Quote Link to comment Share on other sites More sharing options...
grannyknot Posted April 10, 2017 Share Posted April 10, 2017 Those all look like good products but just one of them is not going to do the job of the original tar mats and the felt insulation. They both do different jobs, the tar mat keeps the large areas of sheet metal from resonating and vibrating, the insulation muffles sound and insulates from the heat of the engine and exhaust system. You should use a sticky tar or butyl mat on the metal just the way Nissan did then one of those insulations glued on top of the mat. That thin insulation that comes on the bottom of the carpet kits doesn't do much of anything, these are rattlely old cars and can use some extra help to keep the sqeaks down. Quote Link to comment Share on other sites More sharing options...
ritrebor Posted April 10, 2017 Share Posted April 10, 2017 I used RAAMaudio mat in my Z. Not the cheapest but I am satisfied with the results. Was easy to install and seems to make it quieter, but my car is loud anyway. http://www.raamaudio.com/ ritrebor Quote Link to comment Share on other sites More sharing options...
Aero Z Posted April 11, 2017 Share Posted April 11, 2017 On 4/10/2017 at 11:00 PM, ritrebor said: I used RAAMaudio mat in my Z. Not the cheapest but I am satisfied with the results. Was easy to install and seems to make it quieter, but my car is loud anyway. http://www.raamaudio.com/ ritrebor I used the same mat material and put a layer of their Ensolite foam on top of that. I put it down when redoing the car so no way to compare to not having it there. Seems like it does really well. Both seem very good quality and were cheaper than the inflated prices of dynamat etc. Also the seller is very good...or at least was years ago. Quote Link to comment Share on other sites More sharing options...
theczechone Posted April 11, 2017 Author Share Posted April 11, 2017 (edited) grannyknot, you make a good point, however, i'd hope we had advanced a bit since the 70s. I deally i would like to put just one product down. Maybe the best way to approach this would be to: 1) do so driving with no insulation at all (record the noise) 2) add the tar such as noico or raamat (record the noise) 3) if needed add foam or other style insulation (record the noise) yay for experiments, now someone come help me finish my floors so i can do this lol Edited April 11, 2017 by theczechone Quote Link to comment Share on other sites More sharing options...
