Richard Oben Posted May 3, 2020 Share Posted May 3, 2020 Not sure if it applies but other companies sell a dial up down kit for EPS. R Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted May 3, 2020 Author Share Posted May 3, 2020 Hi Richard, I know the kit you are talking about, I am sure it is a great kit. The reason I went with this kit was the compact size, speed sensing is more in line with modern electric power steering in cars. Having the VSS signal from the LS2 made the hook up very simple. I hope to test drive today. Pete Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted May 4, 2020 Author Share Posted May 4, 2020 I tested the EPS kit today on mountain roads and freeway driving. The kit performed fantastic, on the freeway not overly to much assist, Actually felt like a modern day sports car. Driving on mountain roads the car felt very stable. Parking the car can be done with one hand just like my Honda. I have to say the car is much more enjoyable to drive with power steering then with manual steering. The EPS kit was very easy to install and worked as promised. Pete Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted May 4, 2020 Share Posted May 4, 2020 Do you believe you lost any of the raw / connected to the road feeling of manual steering? When you say it feels like a modern day sports car, my concern is that a lot of newer sports cars feel a bit disconnected / mushy, particularly at low speed and sharp cornering. Roughly how long would you say the full install took? Did you ever get an answer back on the offset on the steering rod? Quote Link to comment Share on other sites More sharing options...
mrk3cobra Posted May 4, 2020 Author Share Posted May 4, 2020 I did the install over a few days. You should be able to install in less then 4 hours, depends if you need to hunt down the tach and speedo wires. I am very critical on the instillation so I take a little more time to make sure everything is how I want it. If the engine is out it would make the install a little easier. I did the install by my self, if you have a helper it would be easier. I do not feel like I am disconnected from the road at speed. The steering is definitely easier under around 30MPH. At speeds under 10MPH it definitely feels a lot different then manual steering. The EPS kit does not offset the steering shaft on the 240Z only on the 280Z. I received an extra firewall bracket that I will make my own offset. Quote Link to comment Share on other sites More sharing options...
YZFMax Posted May 11, 2020 Share Posted May 11, 2020 I recently installed the power steering kit, one of the best mods to date. The car is much more drivable now, and have no issues at highway speeds. I ended up using the GPS sensor instead of the speedo potentiometer that came with the kit. Had no issues with the fitment on my 260z (uses the same unit as the 280z), it lined up perfectly in the location of the manual rack. As for the tach wire, I made a splice and attached it to the red/black wire on the tach itself. The signal is basically used to tell the unit when to turn off after the car has been turned off, so it doesn't drain the battery. Quote Link to comment Share on other sites More sharing options...
EF Ian Posted May 13, 2020 Share Posted May 13, 2020 Great stuff. Glad it seems a good system. I'm not sure I need it but want to have the option for it in the future. Quote Link to comment Share on other sites More sharing options...
LooseRocks Posted May 13, 2020 Share Posted May 13, 2020 They've been out of stock for some time now. Not sure how much of an "option" it will be going forward. That's always the issue with after market parts for ancient cars. Sometimes companies just stop doing what they do. Hopefully it's just a carona supply chain issue or just waiting on another batch to be built. Quote Link to comment Share on other sites More sharing options...
EF Ian Posted May 16, 2020 Share Posted May 16, 2020 Its not too hard to make a kit up yourself using a motor from a corsa. That said for less hassle I'd rather buy one already complete. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted August 11, 2020 Share Posted August 11, 2020 I bought the kit and will be installing it shortly along with a new brake MC. I have a VG30 and plenty of clearance (I think), so should be "easy". Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted August 22, 2020 Share Posted August 22, 2020 Clearance on the 280Z seems worse, like it's clocked differently. I tried sitting in it and hitting the clutch though and in my brief test it wasn't an issue. Just have to wire it up now. I don't have the GPS sensor, but I do have a Speedhut GPS tach. It currently has an analog 0-5v speed output I had Speedhut modify for me, that I'm not using. I wonder if they can modify it to be a digital/tick or whatever the EPS needs. In any case wiring looks simple, but I'm going to clean up some crap from my EMS I left in here for the past 10 years while-I'm-at-it. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted August 24, 2020 Share Posted August 24, 2020 (edited) I wired it up temporarily to test. Not sure why there's both an IGN and "Engine RPM" (tach) hookup. I tried without the tach wire, and it seemed to cut in-and-out of assist. Put both to a spare IGN wire and it works much better. Did seem a bit finicky rotating the hub with my hand, but I'll have to put a real steering wheel on it to be sure. Edited August 24, 2020 by BLOZ UP Quote Link to comment Share on other sites More sharing options...
YZFMax Posted August 24, 2020 Share Posted August 24, 2020 2 minutes ago, BLOZ UP said: I wired it up temporarily to test. Not sure why there's both an IGN and "Engine RPM" (tach) hookup. I tried without the tach wire, and it seemed to cut in-and-out of assist. Put both to a spare IGN wire and it works much better. Did seem a bit finicky rotating the hub with my hand, but I'll have to put a real steering wheel on it to be sure. The tach wire is used to give the signal to the power steering unit to turn the unit off when the car is turned off. This is what was explained to me when I asked Silvermine this question. I'm assuming IGN would be used to power the internal relay in the unit? So you would need both of them to be wired in correctly. As per my pic above, I tapped into the back of the tach gauge to get the RPM signal. It all worked out for me very well. Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted August 27, 2020 Share Posted August 27, 2020 I definitely need to tinker with my tach and vss wire on my install as well. I hooked them up _I think_ the same way mrk3cobra did, who reported great success with it. In my case, I "feel" like the steering is much too loose at speed. I expected EPS to basically 'turn off' above around 30-40 mph. I wired a kill switch into mine, and it feels drastically different at driving speeds if I fully disable it. I was hoping for a much more progressive feel with EPS across all driving speeds, but again currently it feels like vss is being under-utilized or not utilized at all. I'll probably try adding a 'kill switch' to that wire as well and see how it behaves if I kill that wire while driving, and see if it makes any difference at all. If not, I may ping Silvermine and see if there's a way to tweak the EPS to provide less assist across the board. I absolutely love it at parking lot speeds, but it feels too jittery and active to me at driving speeds so far. Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted September 24, 2020 Share Posted September 24, 2020 After installing the steering wheel it works great (in my garage, anyway haven't been able to drive it due to brake issues). I still have the tach and ign wires both connected to an ignition source. I'm guessing it needed the steering wheel to correctly sense torque, as you'll generate much smoother/consistent torque with the wheel over trying to crank the hub like I was. There's an autox this weekend that I think the car is ready for so ill report back. Quote Link to comment Share on other sites More sharing options...
BrandenZ Posted September 28, 2020 Share Posted September 28, 2020 How'd the autox go? What are your thoughts having now driven the car, presumably in street and racing conditions? I still need to do electrical checks on mine, as personally I feel like I have way more assist than I'd like at speed. I've gotten to where I flip the kill switch over 20mph or so... Quote Link to comment Share on other sites More sharing options...
Nigel Posted December 28, 2024 Share Posted December 28, 2024 On 8/24/2020 at 3:48 PM, YZFMax said: The tach wire is used to give the signal to the power steering unit to turn the unit off when the car is turned off. This is what was explained to me when I asked Silvermine this question. I'm assuming IGN would be used to power the internal relay in the unit? So you would need both of them to be wired in correctly. As per my pic above, I tapped into the back of the tach gauge to get the RPM signal. It all worked out for me very well. I'm installing this kit in my Z right now, and that explanation for the RPM wire doesn't make sense to me. The White wire that connects to an IGN hot source should serve that purpose, and I bench tested mine with a DC power supply that provides a current draw reading and sure enough, current draw goes to zero when the White wire is disconnected from power. I have seen that some EPAS ECUs require an RPM signal to enable the system so that it's not active when the ignition is on but the engine is off. That way, you can't put a potentially big electrical load on the system when the engine isn't running. However, that doesn't seem to be the case with the Silvermine ECU. The system is enabled and active as soon the White wire is powered. Perhaps the ECU manufacturer disabled that RPM function but left the RPM input wire for whatever reason. A friend of mine suggested that the RPM input may be a backup of sorts if the speed input is lost, but I tested that and RPM doesn't appear to have any effect on steering effort when there's no speed input. Has anyone found a conclusive explanation for the function of the RPM wire on this system? I'd prefer to avoid connecting wires that I don't have to. Nigel 1 Quote Link to comment Share on other sites More sharing options...
YZFMax Posted December 30, 2024 Share Posted December 30, 2024 On 12/28/2024 at 10:40 AM, Nigel said: I'm installing this kit in my Z right now, and that explanation for the RPM wire doesn't make sense to me. The White wire that connects to an IGN hot source should serve that purpose, and I bench tested mine with a DC power supply that provides a current draw reading and sure enough, current draw goes to zero when the White wire is disconnected from power. I have seen that some EPAS ECUs require an RPM signal to enable the system so that it's not active when the ignition is on but the engine is off. That way, you can't put a potentially big electrical load on the system when the engine isn't running. However, that doesn't seem to be the case with the Silvermine ECU. The system is enabled and active as soon the White wire is powered. Perhaps the ECU manufacturer disabled that RPM function but left the RPM input wire for whatever reason. A friend of mine suggested that the RPM input may be a backup of sorts if the speed input is lost, but I tested that and RPM doesn't appear to have any effect on steering effort when there's no speed input. Has anyone found a conclusive explanation for the function of the RPM wire on this system? I'd prefer to avoid connecting wires that I don't have to. Nigel Agreed, using the IGN would make sense and that is why I was also a bit confused, thus asking Silvermine the question. I did end up wiring it up as per their response. I've been using this for since I installed it back in 2020 and had no issues. Quote Link to comment Share on other sites More sharing options...
