fusion Posted February 14, 2021 Share Posted February 14, 2021 (edited) I am going bumperless in the rear and am shaving the roll pan on my 280z. I know the large holes can be filled in with sheet metal and welded. What about the recessed areas and threaded holes? See picture. For area 1, what have people done? I was thinking of getting set screws in the threaded holes and welding closed. But what about the large recess? I really don't want to fill it in with Bondo. Maybe just fill in the threaded holes and leave the area recessed? Same questions for area 2. Pictures would be really nice. Thanks Edited February 14, 2021 by fusion Quote Link to comment Share on other sites More sharing options...
ZHoob2004 Posted February 17, 2021 Share Posted February 17, 2021 I haven't done this myself, but I think that your best bet is to cut a piece of steel a little larger than the base of the recess such that it sits flush on the low side and rides up the edge on the high side, then weld it in and fill the remaining gap. Quote Link to comment Share on other sites More sharing options...
grannyknot Posted February 18, 2021 Share Posted February 18, 2021 On 2/14/2021 at 4:50 PM, fusion said: I was thinking of getting set screws in the threaded holes and welding closed. But what about the large recess? I really don't want to fill it in with Bondo. Maybe just fill in the threaded holes and leave the area recessed? Since there will always be a next owner at some point that might want to go back to bumpers you could just squirt some sealant in the holes then add little filler to smooth it out. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted February 19, 2021 Share Posted February 19, 2021 I'll echo what grannyknot said. As for the indent in the middle, I would leave it, and just smooth it out. It'll add a bit of visual interest to the otherwise smooth rear end, I find a totally plain/smoothed out rear end on these cars doesn't look great, too much space with not enough going on. Also not really keen on the idea of smoothing that bit out by just welding in more metal - seems like an opportunity for a moisture trap to create rust to me. Quote Link to comment Share on other sites More sharing options...
Sanchez Posted February 20, 2021 Share Posted February 20, 2021 If you plan on selling your car then for sure follow @grannyknot advice. Next owner may decide they want a bumper. If it’s going to be your life long car than smooth it and make it how you want it. I agree with @rturbo 930that a totally shaved and smooth roll pan looks a little plain. My plan for my roll pan is to make it from a new sheet of metal and have a buddy use his CNC machine to smoothly cut out the letters “DATSUN” in the back and put a lighted backing behind it to give it some character. But I don’t plan on selling my Z until it becomes impossible for me to drive. Quote Link to comment Share on other sites More sharing options...
Tha Driver Posted Monday at 07:56 AM Share Posted Monday at 07:56 AM Cut out the indented areas & fabricate new sheetmetal to fill the holes. Personally I like the smooth look. 😎 1 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted Thursday at 04:56 PM Share Posted Thursday at 04:56 PM The two areas "1" are a great place to attach tow hooks. 2 Quote Link to comment Share on other sites More sharing options...
Apex Posted 12 hours ago Share Posted 12 hours ago @74_5.0L_Z what wheels are those? Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted 10 hours ago Share Posted 10 hours ago They are Spinwerkes series 82. Unfortunately they are no longer available. I bought them around 2007. 15x10 and weigh 12 lbs Quote Link to comment Share on other sites More sharing options...
