FastFloridian Posted September 9 Author Share Posted September 9 9 hours ago, 74_5.0L_Z said: Hopefully you are converting to all SAE / AN brake fittings. It's a real pain to have a mix of metric and SAE. I routed my brake lines inside the cabin to get the brake lines away from heat. I'm running a Wilwood Tandem Master Cylinder (7/8" bore) and use a proportioning valve installed on the drive shaft tunnel. Honestly not sure yet on fittings. I’ve only done caliper swaps, this is the most comprehensive brake system overhaul I’ve done. Gonna see what I’ve got to work with and go from there, wish me luck 😅 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted September 20 Author Share Posted September 20 Got a little bit of time in the garage today. Got most of the front brake plumbing done, just waiting on the lines I ordered for the master cylinders. Also ordered this steering column mounted lights/turn signal switch and relay set. Will help with the wiring as I’ve tossed everything out. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Sunday at 05:58 PM Author Share Posted Sunday at 05:58 PM Got the complete rear end dropped today. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Monday at 11:03 PM Author Share Posted Monday at 11:03 PM (edited) Got a few goodies today, first I found a cool bracket that can allow me to use a hydraulic set up for the clutch, it’ll let me get rid of the weird mechanical set up someone rigged up. Second was an impulse buy, while getting the turn signal/light switch and relay they had this emergency power stop button and solenoid. Edited 18 hours ago by FastFloridian 1 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted 15 hours ago Share Posted 15 hours ago I like the external slave cylinder. You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers. I'm using a Tilton hydraulic throw-out bearing. Works great and doesn't take up space in the driveshaft tunnel. The downside is that if it leaks then you have to remove the transmission to fix it... 1 Quote Link to comment Share on other sites More sharing options...
jhm Posted 13 hours ago Share Posted 13 hours ago 14 hours ago, FastFloridian said: it’ll let me get rid of the weird mechanical set up someone rigged up. Wow, that's like something out of a Rube Goldberg cartoon! Great progress you're making....keep the updates coming!! 👍 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted 5 hours ago Author Share Posted 5 hours ago 9 hours ago, 74_5.0L_Z said: I like the external slave cylinder. You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers. I'm using a Tilton hydraulic throw-out bearing. Works great and doesn't take up space in the driveshaft tunnel. The downside is that if it leaks then you have to remove the transmission to fix it... Good point, we’ll see when I get it together on fitment, looks like a good option if this doesn’t work. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted 3 hours ago Author Share Posted 3 hours ago 9 hours ago, jhm said: Wow, that's like something out of a Rube Goldberg cartoon! Great progress you're making....keep the updates coming!! 👍 Thanks, will do. I’m hoping to get a good amount done this weekend, and my apex rear suspension kit should be coming in soon. Quote Link to comment Share on other sites More sharing options...
