FastFloridian Posted September 9 Author Share Posted September 9 9 hours ago, 74_5.0L_Z said: Hopefully you are converting to all SAE / AN brake fittings. It's a real pain to have a mix of metric and SAE. I routed my brake lines inside the cabin to get the brake lines away from heat. I'm running a Wilwood Tandem Master Cylinder (7/8" bore) and use a proportioning valve installed on the drive shaft tunnel. Honestly not sure yet on fittings. I’ve only done caliper swaps, this is the most comprehensive brake system overhaul I’ve done. Gonna see what I’ve got to work with and go from there, wish me luck 😅 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted September 20 Author Share Posted September 20 Got a little bit of time in the garage today. Got most of the front brake plumbing done, just waiting on the lines I ordered for the master cylinders. Also ordered this steering column mounted lights/turn signal switch and relay set. Will help with the wiring as I’ve tossed everything out. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted September 28 Author Share Posted September 28 Got the complete rear end dropped today. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted September 29 Author Share Posted September 29 (edited) Got a few goodies today, first I found a cool bracket that can allow me to use a hydraulic set up for the clutch, it’ll let me get rid of the weird mechanical set up someone rigged up. Second was an impulse buy, while getting the turn signal/light switch and relay they had this emergency power stop button and solenoid. Edited September 30 by FastFloridian 1 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted September 30 Share Posted September 30 I like the external slave cylinder. You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers. I'm using a Tilton hydraulic throw-out bearing. Works great and doesn't take up space in the driveshaft tunnel. The downside is that if it leaks then you have to remove the transmission to fix it... 1 Quote Link to comment Share on other sites More sharing options...
jhm Posted September 30 Share Posted September 30 14 hours ago, FastFloridian said: it’ll let me get rid of the weird mechanical set up someone rigged up. Wow, that's like something out of a Rube Goldberg cartoon! Great progress you're making....keep the updates coming!! 👍 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Tuesday at 10:28 PM Author Share Posted Tuesday at 10:28 PM 9 hours ago, 74_5.0L_Z said: I like the external slave cylinder. You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers. I'm using a Tilton hydraulic throw-out bearing. Works great and doesn't take up space in the driveshaft tunnel. The downside is that if it leaks then you have to remove the transmission to fix it... Good point, we’ll see when I get it together on fitment, looks like a good option if this doesn’t work. Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Tuesday at 11:45 PM Author Share Posted Tuesday at 11:45 PM 9 hours ago, jhm said: Wow, that's like something out of a Rube Goldberg cartoon! Great progress you're making....keep the updates coming!! 👍 Thanks, will do. I’m hoping to get a good amount done this weekend, and my apex rear suspension kit should be coming in soon. 1 Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted Wednesday at 01:01 PM Share Posted Wednesday at 01:01 PM When are you hoping to get this car on track? I'm hoping to do an SCCA track day at Sebring in February. It would be nice to see you guys there. 2 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Wednesday at 01:36 PM Author Share Posted Wednesday at 01:36 PM (edited) 1 hour ago, 74_5.0L_Z said: When are you hoping to get this car on track? I'm hoping to do an SCCA track day at Sebring in February. It would be nice to see you guys there. I’m shooting to have it ready by about this time next year, 2 years from when I bought it, so the 240Z won’t be ready. But I am planning to do Sebring a few times January through April, probably in my 370Z (I’ve taken my Tesla there a few times too). I’ve never done an SCCA track day, I’ve always gone there with Chin. Let me know if you sign up, I’ll look into it. I would love to see your car and get some ideas tips to finishing mine. Edited Wednesday at 02:31 PM by FastFloridian Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted Saturday at 08:31 PM Author Share Posted Saturday at 08:31 PM Got the electric power steering installed. You have to the-use original shaft that ties into the steering rack, was a huge PIA to get out of the upper universal joint and into the new one. Got brake pads in, ordered some brake fluid. Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted 6 hours ago Share Posted 6 hours ago Just looking at the picture that you posted of your steering shaft, it looks like the u-joints aren't phased correctly. It may be an optical illusion from the angle of the picture. 1 1 Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted 3 hours ago Author Share Posted 3 hours ago (edited) 3 hours ago, 74_5.0L_Z said: Just looking at the picture that you posted of your steering shaft, it looks like the u-joints aren't phased correctly. It may be an optical illusion from the angle of the picture. You are 100% correct, thanks for pointing that out. You don’t know what you don’t know. The new steering kit lets you attach the u-joint in any configuration, I wasn’t even thinking there was a right and wrong way to install them. Quick google search and see what you mean and how to align them properly. Glad to be able to fix now, rather than find out later, love everyone’s help on this forum. Edited 3 hours ago by FastFloridian 1 Quote Link to comment Share on other sites More sharing options...
