9 hours ago, 74_5.0L_Z said:
Hopefully you are converting to all SAE / AN brake fittings.
It's a real pain to have a mix of metric and SAE.
I routed my brake lines inside the cabin to get the brake lines away from heat.
I'm running a Wilwood Tandem Master Cylinder (7/8" bore) and use a proportioning valve installed on the drive shaft tunnel.
Honestly not sure yet on fittings. I’ve only done caliper swaps, this is the most comprehensive brake system overhaul I’ve done. Gonna see what I’ve got to work with and go from there, wish me luck 😅
Got a little bit of time in the garage today. Got most of the front brake plumbing done, just waiting on the lines I ordered for the master cylinders. Also ordered this steering column mounted lights/turn signal switch and relay set. Will help with the wiring as I’ve tossed everything out.
Got a few goodies today, first I found a cool bracket that can allow me to use a hydraulic set up for the clutch, it’ll let me get rid of the weird mechanical set up someone rigged up. Second was an impulse buy, while getting the turn signal/light switch and relay they had this emergency power stop button and solenoid.
Edited by FastFloridian
  • Like 1
I like the external slave cylinder.  You may have to clearance the driveshaft tunnel a bit, and it will create another obstacle to routing headers.
I'm using a Tilton hydraulic throw-out bearing.  Works great and doesn't take up space in the driveshaft tunnel.  The downside is that if it leaks then you have to remove the transmission to fix it...
  • Thanks 1
Wow, that's like something out of a Rube Goldberg cartoon!  Great progress you're making....keep the updates coming!!  👍
  • Like 1
Good point, we’ll see when I get it together on fitment, looks like a good option if this doesn’t work.
Thanks, will do. I’m hoping to get a good amount done this weekend, and my apex rear suspension kit should be coming in soon.
  • Like 1
Posted (edited)
1 hour ago, 74_5.0L_Z said:
When are you hoping to get this car on track?  I'm hoping to do an SCCA track day at Sebring in February.  It would be nice to see you guys there.
I’m shooting to have it ready by about this time next year, 2 years from when I bought it, so the 240Z won’t be ready. But I am planning to do Sebring a few times January through April, probably in my 370Z (I’ve taken my Tesla there a few times too).  I’ve never done an SCCA track day, I’ve always gone there with Chin. Let me know if you sign up, I’ll look into it. I would love to see your car and get some ideas tips to finishing mine.
Got the electric power steering installed. You have to the-use original shaft that ties into the steering rack, was a huge PIA to get out of the upper universal joint and into the new one. Got brake pads in, ordered some brake fluid.
Posted (edited)
3 hours ago, 74_5.0L_Z said:
Just looking at the picture that you posted of your steering shaft, it looks like the u-joints aren't phased correctly.  It may be an optical illusion from the angle of the picture.
You are 100% correct, thanks for pointing that out. You don’t know what you don’t know. The new steering kit lets you attach the u-joint in any configuration, I wasn’t even thinking there was a right and wrong way to install them. Quick google search and see what you mean and how to align them properly. Glad to be able to fix now, rather than find out later, love everyone’s help on this forum.
  • Like 1
I’m curious as to how the electric steering kit will hold up and what you think of it. No power steering isn’t that bad but it might be a nice upgrade down the line. Please keep us up to date once you have the car driving.
Will do. I’m going to go with some wide wheels and tires up front, somewhere between 305s up to 325s. With all that rubber the power steering will be a huge help.
  • Like 1
Got a few small projects done. Got rid of the weird clutch pedal contraction. Ordered a brake pedal to be my clutch pedal. Had to trim it down as it was for an automatic. Welded on the side clip for the clutch slave cylinder and took all the pedals out and painted. Also cleaned the underside some more, I want to get that painted soon.
