Kad77 Posted March 16 Share Posted March 16 I have a 1978 Datsun 280z. I rebuilt the engine last year. Removed the fuel injection and installed 240z SU carburetors. The car starts and runs great, I typically use it as a daily driver. The only problem I have, is that I hardly ever rev it above 4000 rpms. I watch videos of people driving Zs and they always take it up to 5000 or even 6000 rpms. But for my Z there seems to be no additional power or acceleration above 4000rpms. There doesn't seem to be any stumbles or misfires, it just seems like the power is flat above 4000 rpms. I thought Zs had power all the way to the yellow line. I've never driven another Z besides mine, so I do not know for sure. Any advice is appreciated! Thanks in advance! 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted March 16 Share Posted March 16 IGNITION. Check your timing. Disconnect and plug the vacuum advance. Shoot for 18-20 degrees advance at idle. Have you sync'd the carbs? are oyu getting any popping if you rev to 4000 and let off the gas and down shift? If it is a lean condition, you may need some "SM" carb needles. Quote Link to comment Share on other sites More sharing options...
Kad77 Posted March 16 Author Share Posted March 16 Thanks for the reply! So I just set the timing yesterday. Since I currently have a tank of 87 octane in the car, I set the timing to stock 10* BTDC. Once I'm through this tank of gas, I'll fill up with 91 octane and advance the timing. There was some backfire and popping on deceleration. So yesterday I pulled the plugs and there were a little white. So it was in fact running a little lean. I richened the carburetors a little by turning the adjustment on the bottom of the carburetors. This seemed to help with the popping. It now decelerates without popping, or at least significantly less popping. I synced the carbs when I first rebuild the engine. I've checked them once since then and there were still synced. Any further advice is greatly appreciated! 1 Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted March 16 Share Posted March 16 Will the engine rev to 6000 rpm when there's no load on it? Years ago I was driving my 71 on I-5 when I found the engine wouldn't go any faster than 4000 rpm. I kicked in the clutch and found it would rev to 6000 but under a load it wouldn't go past 4000. The problem turned out to be a partially plugged fuel filter. 1 Quote Link to comment Share on other sites More sharing options...
Kad77 Posted March 17 Author Share Posted March 17 Thanks for the reply! Yes, my engine will rev to 6000 when not underload. But it still feels like flat power after 4000. While driving, it will I've revved it to 5500, but above 4000, there is just no acceleration. I've got brand new fuel filters on mine as well. The old ones were definitely clogged. Any advice is appreciated! Quote Link to comment Share on other sites More sharing options...
A to Z Posted Monday at 06:30 PM Share Posted Monday at 06:30 PM what elevation are you at? The stock SU needles are a compromise between power and emissions to a point. "SM" needles are a performance needle set. they give more fuel at higher RPM's. Being a L28 engine, it IS larger than the factory L24 engines these carbs were intended for and that may be at least some of the cause if not THE cause. When installing the needles there is a process to make sure they are installed just right. I would recommend some SM needles. Try "Z Car Depot". Did your setup ever pull to 6K or has it always been like this? Quote Link to comment Share on other sites More sharing options...
Kad77 Posted Monday at 07:10 PM Author Share Posted Monday at 07:10 PM I'm in Salt Lake City, Utah. So around 4000-5000ft elevation. The car has always been like this since I rebuilt the engine. Prior to the rebuild, the car did not run. I bought the car non running, and had to rebuild the engine after realizing it was toast. Thanks! Any advice is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
NewZed Posted Tuesday at 06:12 PM Share Posted Tuesday at 06:12 PM Probably worth your time to study up on how the SU's work. They're not your Dad's Buick's carburetor. Air flow is controlled by vacuum. Seems like your "suction pistons" might not be rising fully, choking off air flow. This from the 1973 Engine Fuel chapter - Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted Thursday at 12:50 AM Share Posted Thursday at 12:50 AM Check the banjo filters where the fuel enters the float bowls. Then I'd do a fuel pressure and volume test. The symptoms all relate to a lack of fuel. Quote Link to comment Share on other sites More sharing options...
NewZed Posted Thursday at 07:39 PM Share Posted Thursday at 07:39 PM Clogged exhaust system comes to mind also. Especially if it has a catalytic converter. 1 Quote Link to comment Share on other sites More sharing options...
