Kad77 Posted March 16 Share Posted March 16 I have a 1978 Datsun 280z. I rebuilt the engine last year. Removed the fuel injection and installed 240z SU carburetors. The car starts and runs great, I typically use it as a daily driver. The only problem I have, is that I hardly ever rev it above 4000 rpms. I watch videos of people driving Zs and they always take it up to 5000 or even 6000 rpms. But for my Z there seems to be no additional power or acceleration above 4000rpms. There doesn't seem to be any stumbles or misfires, it just seems like the power is flat above 4000 rpms. I thought Zs had power all the way to the yellow line. I've never driven another Z besides mine, so I do not know for sure. Any advice is appreciated! Thanks in advance! 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted March 16 Share Posted March 16 IGNITION. Check your timing. Disconnect and plug the vacuum advance. Shoot for 18-20 degrees advance at idle. Have you sync'd the carbs? are oyu getting any popping if you rev to 4000 and let off the gas and down shift? If it is a lean condition, you may need some "SM" carb needles. Quote Link to comment Share on other sites More sharing options...
Kad77 Posted March 16 Author Share Posted March 16 Thanks for the reply! So I just set the timing yesterday. Since I currently have a tank of 87 octane in the car, I set the timing to stock 10* BTDC. Once I'm through this tank of gas, I'll fill up with 91 octane and advance the timing. There was some backfire and popping on deceleration. So yesterday I pulled the plugs and there were a little white. So it was in fact running a little lean. I richened the carburetors a little by turning the adjustment on the bottom of the carburetors. This seemed to help with the popping. It now decelerates without popping, or at least significantly less popping. I synced the carbs when I first rebuild the engine. I've checked them once since then and there were still synced. Any further advice is greatly appreciated! 1 Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted March 16 Share Posted March 16 Will the engine rev to 6000 rpm when there's no load on it? Years ago I was driving my 71 on I-5 when I found the engine wouldn't go any faster than 4000 rpm. I kicked in the clutch and found it would rev to 6000 but under a load it wouldn't go past 4000. The problem turned out to be a partially plugged fuel filter. 1 Quote Link to comment Share on other sites More sharing options...
Kad77 Posted March 17 Author Share Posted March 17 Thanks for the reply! Yes, my engine will rev to 6000 when not underload. But it still feels like flat power after 4000. While driving, it will I've revved it to 5500, but above 4000, there is just no acceleration. I've got brand new fuel filters on mine as well. The old ones were definitely clogged. Any advice is appreciated! Quote Link to comment Share on other sites More sharing options...
A to Z Posted March 17 Share Posted March 17 what elevation are you at? The stock SU needles are a compromise between power and emissions to a point. "SM" needles are a performance needle set. they give more fuel at higher RPM's. Being a L28 engine, it IS larger than the factory L24 engines these carbs were intended for and that may be at least some of the cause if not THE cause. When installing the needles there is a process to make sure they are installed just right. I would recommend some SM needles. Try "Z Car Depot". Did your setup ever pull to 6K or has it always been like this? Quote Link to comment Share on other sites More sharing options...
Kad77 Posted March 17 Author Share Posted March 17 I'm in Salt Lake City, Utah. So around 4000-5000ft elevation. The car has always been like this since I rebuilt the engine. Prior to the rebuild, the car did not run. I bought the car non running, and had to rebuild the engine after realizing it was toast. Thanks! Any advice is greatly appreciated! Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 18 Share Posted March 18 Probably worth your time to study up on how the SU's work. They're not your Dad's Buick's carburetor. Air flow is controlled by vacuum. Seems like your "suction pistons" might not be rising fully, choking off air flow. This from the 1973 Engine Fuel chapter - Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted March 20 Share Posted March 20 Check the banjo filters where the fuel enters the float bowls. Then I'd do a fuel pressure and volume test. The symptoms all relate to a lack of fuel. Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 20 Share Posted March 20 Clogged exhaust system comes to mind also. Especially if it has a catalytic converter. 1 Quote Link to comment Share on other sites More sharing options...
seattlejester Posted Sunday at 09:33 PM Share Posted Sunday at 09:33 PM Would suggest checking fuel too, engine uses more fuel under load. Depending on how you converted the fuel setup over could be running the bowls dry under load. My problem with my SU conversion was my bad wiring with my electric fuel pump, on cruise would be fine, but on load it would intermittently pulse and not feed enough fuel and the bowls would run dry Quote Link to comment Share on other sites More sharing options...
Kad77 Posted Sunday at 10:11 PM Author Share Posted Sunday at 10:11 PM Thanks for the reply! How could the wiring be screwed up for the fuel pump? As far as I understood it, it was simply two wires. When I first got the car running, I didn't have a fuel pump with high enough gallons per minute and the car would shut off under load. I upgraded the fuel pump, and it seems to do the job. It is a 4-7psi 30gpm pump. Do you think this is enough? Thanks!! Quote Link to comment Share on other sites More sharing options...
bunkhouse Posted Monday at 05:14 PM Share Posted Monday at 05:14 PM 4 psi is enough but the fuel supply can meet pressure requirements and not meet volume requirements for an engine under a load. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 06:53 PM Share Posted Tuesday at 06:53 PM do you have an adjustable fuel regulator? If so richen it up a tad and take it out and see if it helps. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Tuesday at 06:56 PM Share Posted Tuesday at 06:56 PM With the SU's, I would go with SM needles, turn the mix screws about 2 turns down from the top, re-sync the carbs, and verify ignition. should have 18 degrees advance at idle with the vacuum disconnected and plugged. ~Joe Quote Link to comment Share on other sites More sharing options...
