clarkspeed Posted August 7, 2025 Share Posted August 7, 2025 Found this on Grassroots Motorsport web page. Seems Legit Garage is adapting some interesting modern trannys to other platforms. Think $2k for a fully sequential used 8sp box, any HP needs you have. The ZF-8HP from BMWs, Dodge and others can be fully reprogrammed for sequential operation and even add a dbw pedal to simulate a clutch launch. Might be a good project for someone that could adapt this to an L6 easily....Derek? Transmission Solutions | "Seems Legit" Garage https://share.google/HyOxohcae82yQu0Th 1 Quote Link to comment Share on other sites More sharing options...
tube80z Posted August 9, 2025 Share Posted August 9, 2025 I think the only downside, other than size, is the 180 pounds these weigh, from my research. DCGs are very heavy and have a deep oil pan that limits ground clearance. For a high HP car where the weight isn't a problem, I think that they could be a good solution. The MaxxECU is a nice bit of kit. I got to see one being put on a friend's car and it had tons of IO for the cost. 1 Quote Link to comment Share on other sites More sharing options...
Ben280 Posted August 10, 2025 Share Posted August 10, 2025 The turbo lamik stuff is very trick, and it has a lot of potential. The weight is a downside, but it's low and centered. I have a buddy who just put one in his 2JZ swapped FC RX-7, and he didn't have to touch the tunnel. There are a couple guys on IG as well who have swapped these in with good success. I think compared to the T56's they are only slightly heavier, but much stronger and have nicer ratios. 1 Quote Link to comment Share on other sites More sharing options...
Derek Posted August 13, 2025 Share Posted August 13, 2025 On 8/6/2025 at 9:25 PM, clarkspeed said: Might be a good project for someone that could adapt this to an L6 easily....Derek? NO!!! Actually it seems well suited to a billet solution and I can't compete with billet solutions. The only reason I can play in this arena with my equipment is leveraging my pattern making abilities. 1 Quote Link to comment Share on other sites More sharing options...
Dat73z Posted August 14, 2025 Share Posted August 14, 2025 This has already been done a few years ago. Reach out to Jakub at Datsun Europe, he's running a zf8hp50 behind his sick turbo L and has a few adaptor plates left. 1 Quote Link to comment Share on other sites More sharing options...
