Hosting site slow to respond.
Ditto.  Seems slower to load than previously -- I've also noticed it's worse with some web browsers vs others, depending on what operating system you have.
I'm only guessing here...but it may be due to the fact that our hosting site has certain updates available, but they all cost $ and we don't have the funds to pay for them.  Dan's been running the forum on a shoestring budget for several years now (often paying for operating expenses out of his own pocket); and as a result, our software's not fully up to date.
Anyone wishing to make a donation to help keep HBZ up and running can do so here:  https://forums.hybridz.org/clients/donations/
Seems like half the time the site isn't even accessible. What's going on here? If money is needed, then I would suggest starting a fundraising campaign with its own separate thread. In the past, they've done well. Maybe another merch run if Cockerstar is up to it.
The site is slow as it is due to the decline of forums. If this site becomes regularly inaccessible, it's probably going to kill off the remaining activity it has completely. Forums these days are mostly running on momentum, site problems kill that.
  • Like 1
A slow-responding forum is commonly caused by high server load from excessive traffic, inefficient database queries, too many active plugins, unoptimized heavy images, or poor caching strategies. Other factors include network congestion, inadequate hosting resources, or unoptimized JavaScript.
In other words, unless the forum owner owns the server - money ain't the problem - it's the server connecting to the internet.
  • Sad 1
I've noticed that refreshing the page when it hangs seems to help. I can go down the main page and open new tabs with all the threads with updates, and some will load right away while others won't. I refresh the ones that don't load, and then they seem to come up. It isn't a 100% success rate because sometimes they fail to load again, but it's almost like some queries get lost and sending them again kicks the server into gear.
  • Thanks 1
  • 4 weeks later...
Using a VPN can also slow down network and website response times.  If you're running a VPN, try turning it off and see if that helps the issue.
Not an ideal solution, but worth a try...
On 6/8/2026 at 5:54 PM, rturbo 930 said:
Is SuperDan aware of the problem?
Yes, he is; and he's looking into various solutions to address this and other issues we've been having with the site.
He will let us know if there's a need for additional resources, due to any necessary changes in site hosting.
4 hours ago, jhm said:
I've been having much faster site-response and loading times lately, when navigating the forum.  It would appear that the fixes Dan implemented have improved things significantly.
Are y'all seeing the same improvements on your end?  @rturbo 930, @calZ, @Brad-ManQ45, @Leon, @flatout?
I haven't noticed much difference but i generally refresh the page and then flip off it and do something else while it loads.
  • Like 1
I still get a site not responding when I go to it and have to wait more than 30 seconds for it to load.  Clicking among sub forums takes a while as does loading threads.
Whatever he's doing isn't working ..
  • Sad 1
For me it works more often, and when it does work it's very snappy. When it's slow, I just hit refresh and go to a different tab for a moment and it'll be back by the time I return. It's still not perfect, but I think it's better than it was.
  • Thanks 1
It feels slow often for me from all the ads, pop ups, click bait ect trying to load.  Its practically useless to view on a phone.  But I get it, need money to host it, but it also destroys it.  Sorry
  • Sad 1
