Q45 T-body on L manifold...
Guest ON3GO
Anybody ever made a adapter or some how got the 86mm Q45 t-body on a Z intake manifold?
i have a few of these T-bodys and was wanting to use one on my Z..
but i thought i would see if anybody else is using one on a Z's intake manifold.. like a N42 manifold or something.
if so what did ya do...?
mike
I have a Q45 throttle body that I will adapting to James Thagard's intake manifold.
Didn't someone on here use a cable linkage from a throttle body to the firewall then use the stock throttle rod? I think Lokar has a kit on Summit.
Scottie seemed to run 10.08 with his 60 or so mm TB from his GN..
Hey! My TB is not that small. It's a whopping 62mm with knife-edged blades. :D :D
Seriously, I think Joel said it best. Some engineer here could calculate airflow based on HP and derive the "required" TB diameter. You might be surprised at what is actually required for a forced-induction engine. Of course required and "check this out" are not always the same thing.
Seriously' date=' I think Joel said it best. Some engineer here could calculate airflow based on HP and derive the "required" TB diameter. You might be surprised at what is actually required for a forced-induction engine. Of course required and "check this out" are not always the same thing.[/quote']
Someone needs to do this asap. Is there software somewhere to figure this out?
You would be loosing a ton of low speed throtle responce...:eek2:
Was this directed to me? I haven't cut it just yet. :) :)
BTW what T/B would I need that his manifold were mocked up to use? Just in case this formula theory proves correct.
Semi-Related Question...
The RB25DET is designed to be used with a Q45 TB. But when the motor and plenum with Q45 TB is bolted up to the S30, the throttle wheel hits the inner wheel well [i don't see why Nissan designed a wheel well that goes almost to the front of the car with the exception of changing our light bulbs].
Can the wheel be relocated? Pictures of this will come soon so everyone knows what the heck I'm talking about.
i have a 60mm 240sx t-body thats ported/polished and knife-edged, should be more then fine.
but like i said i was just wondering as i have a few at the shop.
it is hugh!
mike
Go to http://www.megasquirt.info/ then click the "Injectors and Fuel Supply" link from the left most frame under "MegaManual". Then on the right frame you should see a list of shortcut link with-in the document. Select "Throttle Bodies". Read this section and scroll down you will see a Throttle Body Bore calculation area.
Have fun :-D
Have fun :-D
Thanks
Have fun :-D
that's for NA engines...........I wanna see turbo'd sizing......but thanks for link.
True. But you can work it out for a turbo engine based on boost pressure and average intake temps. Needless to say it will be much smaller for a FI application than a NA one.
Dave
