Garrett76Zt Posted September 17, 2005 Share Posted September 17, 2005 Alright so i took my bottom end apart tonight and this is what i found. This is the #2 Connecting rod bearing. Totally munched . . . and it scored the crank journal pretty badly. Top of piston was peppered with pieces of Turbo Compressor wheel Smashed the edge which in turn scored the cylinder wall badly enough that i cant reuse this block unless i bore and go up to bigger pistons. Which i dont wanna do cause i still have 5 perfect Ross forged pistons. Still havent made up my mind yet what im gonna do, I'll keep ya posted, just thought i'd share the gruesome pics. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted September 17, 2005 Share Posted September 17, 2005 Reason? Dave Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted September 17, 2005 Share Posted September 17, 2005 ouch how did it happen? How'd the compressor come free And how did the bottom end get like that, not enough lubrication? Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted September 17, 2005 Share Posted September 17, 2005 I had a piston that looked like that. The peppering on top of my piston was caused by detonation, likewise the rod bearing was worn in the same way. Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted September 17, 2005 Share Posted September 17, 2005 OUCH garrett. that sucks man. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted September 17, 2005 Share Posted September 17, 2005 Cringe!!! Quote Link to comment Share on other sites More sharing options...
Guest 73Turbo240z Posted September 17, 2005 Share Posted September 17, 2005 i'd also like to know what led to this... Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted September 17, 2005 Author Share Posted September 17, 2005 well, long story short . . . the K&N filter was too close to the exhaust manifold and the rubber began to soften and shred at the clamp. Turbo sucked in a chunk of rubber under boost and munched up the compressor wheel . . . . those pieces eventually found their way into the cylinders . . . and I'll admit the motor was pretty low on oil at the time that this happened, I'm sure that didnt help the situation. Oh well, now I get to do my first rebuild, good times . . . good times. Its a good thing they postponed SEZ, hehe. Quote Link to comment Share on other sites More sharing options...
violacleff Posted September 17, 2005 Share Posted September 17, 2005 Did this happen to your stroker block/pistons? Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted September 17, 2005 Share Posted September 17, 2005 Yep, either replace one forged piston and 240z rod, or sell them (needing one rod and piston) and refresh another short block. Looks just as you described over the phone last night. You said that #5 had a few pit marks, but nothing bad though, correct? Mike Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted September 17, 2005 Author Share Posted September 17, 2005 well I still need to remove the bearing from that rod, but I think the rod is reusable, unless you're seeing something im not? yeah #5 is in good shape Quote Link to comment Share on other sites More sharing options...
Guest HBZ81 Posted September 17, 2005 Share Posted September 17, 2005 ouch Quote Link to comment Share on other sites More sharing options...
Clifton Posted September 17, 2005 Share Posted September 17, 2005 I would think the compressor wheel would have went through more than one cylinder. I would go with the detonation theory. Especially considering the hammered rod bearing. Is it just the top edge of the piston? Looks like you could clean it up on a lathe. Quote Link to comment Share on other sites More sharing options...
kj280z Posted September 18, 2005 Share Posted September 18, 2005 Thats a real bummer, but I'd bet you could get another piston from Ross fairly cheap... Garrett you had called me about the extra motor I have... Word travelled fast and the motor was sold to the first person I talked to! Ragno bought the entire setup. My new motor arrives on monday for my project 240Z... it's a surprize. Ken Quote Link to comment Share on other sites More sharing options...
chino Posted September 18, 2005 Share Posted September 18, 2005 ah man thats shitty. gl with the project! Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted September 18, 2005 Author Share Posted September 18, 2005 Definitely wasnt detonation, there are chunks of compressor wheel missing. . . the car never saw more than 13 psi and it was ALWAYS safe AFR's, besides detontation prolly would have shown some damage on other pistons. Quote Link to comment Share on other sites More sharing options...
510six Posted September 18, 2005 Share Posted September 18, 2005 Is their any chance that the damaged cyl could be sleeved? Quote Link to comment Share on other sites More sharing options...
violacleff Posted September 18, 2005 Share Posted September 18, 2005 So is this the fate to be expected if any turbo fails? I know your's wasn't turbo failure, but say your turbo falls apart after so many miles, will it crunch up the motor like this? Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted September 18, 2005 Share Posted September 18, 2005 While I wouldn't discard the detonation theory just yet (I'm no expert on these things) one other option to consider is that the missing shard of compressor wheel entered #2 cylinder and proceeded to wedge at the edge of the piston/chamber. This then meant that the piston was running into it and then into the head accounting for the obvious metal-on-metal in the rod big end. Of course, this assumes that the shards are big enough to do this, but small enough to make it through the IC? Checked the IC? Dave Quote Link to comment Share on other sites More sharing options...
buZy Posted September 19, 2005 Share Posted September 19, 2005 Ouch I hate when that happens Quote Link to comment Share on other sites More sharing options...
