for those that asked about my garage project
grumpyvette
well finally got the stucco
the lift
the bathroom installed in my new garage so Im advancing slowly
YEAH! I went with the TWO post,RELUCTANTLY
heres a older post from a couple days back explaining WHY
Ive spent the last month extensively researching my lift purchase options ,(my budget allows up to a $4000 installed cost)
first I refuse to buy a CHINESE MADE lift the lift I purchase must have some important feature,s it MUST be american made! ALI certified/validated by ETL
http://autolift.org/
http://autolift.org/purchase_considerations.pdf
BECAUSE IM GOING TO BE UNDER IT! and it must have all controls easily acessable from one single main location and have a local service company with parts
both two and four post designs are/were extensively researched feature by feature and support/parts availability and service were very important factors. ive narrower the field considerably and much to my surprize this (BELOW) is the lift that currently looks like the winner, its american made and comes with a 5 year warrantee and its certified
http://www.ben-pearson.com/9000si.shtml
yeah! ITS a TWO post!, Im still looking for a 4 post that costs the same, and has the same features (american made) and I looked into every "lift failure"
I could find, most accidents are either on CHINESE made LIFTS or envolve OPERATOR ERROR, since OPERATOR ERROR is not really a LIFT FAILURE UNLESS its a BADLY DESIGNED FEATURE that CAUSED THE PROBLEM, I took that into account also
as some of you know I purchased a lift (ON-LINE/OFF THE INTERNET) last year and got charged but the lift never got shipped(FRAUD) luckly VISA reinbursed the cost after it was proven to be obviously a scam
another reason I will only deal with a FLORIDA DEALER who will INSTALL,and maintain the lift I purchase
it was close but sometimes its what they DON,T say thats important also, heres what the sites say.... I called several companys who could not or would not even tell me where I could inspect one of thier lifts in the area or tell me who was the local service company, or tell me they sold american made CERTIFIED LIFTS
cost about $3000 installed
Model: XL-9X
Manufacturer: Bend-Pak NO LOCAL SERVICING DEALER
Weight: 1395.lbs
no mention of (Single point safety release )
9,000 pound lifting capacity
Narrow design
Dual hydraulic cylinders
Electric/hydraulic power system
Large, 17" x 17" A36 steel base plate
Self-lubricating Dura-Glide polyethylene bearing system
Safety locks in each column spaced every 2-inches
Automatic arm restraints
Heavy-duty chain lifting system
Low profile columns for low-ceiling applications
Truck and van adapters standard
ETL Approved
cost about $3600 installed
Ben Pearson's LOCAL SERVICING DEALER
Ben Pearson's 9000SI Two-Post.
ALI certified /validated by ETL
Weight: 1700lbs
Padded overhead shut-off bar
2-5/8" & 5" truck adapters included
Extra long carriage for smooth lifting
Convenient stack-pad storage rack on post
Automatic engage and release arm restraint
Extra large ultra-high molecular bearing blocks
Low profile arms for low ground clearance
Optional height extension kits for taller vehicles
Clear floor design for convenient use of floor jacks
now I called and talked to all the companys listed in the first post in this thread to get a feel for the sales/service,and ask questions on features but what clinched it between the two for me personally was calling both companys for locations where each had installed lifts,and finding and looking over both lifts at local shops, I found three shops with BEN PEARSON lifts, THEY WERE ALL VERY HAPPY,so happy they were braging about how trouble free they were! while the two shops I visited with the BEND PAC lifts were happy but found nothing to rave about, now Im not sure thats a valid source of info but it impressed me! since the local shops with the ben pearson lifts also mentioned the local dealer stops by or calls about once every month to check if they need service or shop tools (kind of like the MAC tool guys, the BEN PEARSON GUYS have a route)
IVE pretty much narrowed the list at this point, Ill let you know how things work out! once I order and install a lift
well I went and did it!. I had one of the local shops put my vette up on his lift, I checked it out, operated it,then I went home and I ordered the lift, it will be installed tomorrow (now thats fast)and total cost will be about $3600(expected)
my floor slab is 6"-8" thick 3500psi concrete so it will have a good base for the (16) 7/8" anchor bolts
__________________
"Enterring from the pond side seemed awkward. Will you build it up and put a drive in?"
the driveways COMING,and yeah Ill build the area up first, but 800 feet of concrete , 16 feet wide and a pad in front of the garage will cost me over $27,000 so its on hold till my budget allows
"Did you consider metal building before going to block? What are the pros and cons of metal vs block. Thanks"
I was looking at one of those steel kit garages before building my current CBS garage and while I could have built a larger garage for slightly less money and surely had it up quicker,(and it would have been an excellent garage,)than I finally built (36x74-2664 sq ) vs (40x80 3200sq)17% larger but the long term resale values over time made the decision for me
while Im glad I did what I did I would have been far ahead cost wise to have gone the prefab route, my neighbor had a 40/80 built for slightly under $80,000, the metal buildings are considered as TEMP structures by the building department and most guys I know consider 30 years as the average lift span on the steel buildings altho many that are properly maintained last longer
"How did the shingle count work out?"
thats a SORE subject, I bought 39 sq of 50 year garauntee shingles at $79 a sq , the builder insisted I needed 6 more sqs ...I have 7 sq of those shingles in the garage left over!!!!!
in the long term ,, minor problems like that are just that minor , wasteing $500 0n a $110-$140 thousand dollar project is peanuts, I only wish ALL my problems in life were that minor, in fact Ill probably just give those shingles to someone locally building a garage as a friendly jesture
:lmao:
OK, Now that I'm done laughing at you for buying a twin post lift, I'm envious of your huge arsed garage and your nice Crapper! :2thumbs:
You have the only type twin post lift I'd own, which has all the controls in one location so you can safely raise and lower it by yourself. Mine is OSHA certified and passes ALI standards. It has been a real workhorse. When we sell our place I'm tempted to pull out the lift and take it with me! :-)
I'll probably put up a steel building when we do the next one, but you're right about resale. Yours will have much higher returns on the money spent! But you already knew that! :wink:
Cheers! :cheers:
Mike :cool:
  • 4 months later...
"Must be nice to have money"
"Must be nice to have (HAD SOME) money would be closer"
BUT NOT ANY MORE!
since I spent it on that GARAGE and needed a MORGAGE to swing the deal...........it always comes down to PRIORITIES
BTW
I had this change in the paint scheme suggested, while Im not sure the neighbors would approve I thought it was a cute thought
