RB26240Z Posted February 23, 2006 Share Posted February 23, 2006 After taking the oil pan out I checked for the rear dipstick hole but I don't seem to find it there, isn't there supposed to be a brass plug? I did the search and it says there should be a brass plug and can be punched out from the underside. Thanks Henry Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 23, 2006 Share Posted February 23, 2006 http://forums.hybridz.org/showthread.php?t=107538 Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted February 23, 2006 Author Share Posted February 23, 2006 I guess the later R32 R33, and R34 dont have the holes drilled and plugged. Thanks for the link 240z master. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 23, 2006 Share Posted February 23, 2006 I guess the later R32 R33' date=' and R34 dont have the holes drilled and plugged. Thanks for the link 240z master.[/quote'] I'm sure they do, my friend had a R32 RB26 that had it, a lot of the guys here have it. Can you take a picture to show me where you are looking? Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted February 23, 2006 Share Posted February 23, 2006 my R32 (1990) has it, look on my website there is a picture of where it is in Engine Rebuild Pt 3 Quote Link to comment Share on other sites More sharing options...
Zhadman Posted February 23, 2006 Share Posted February 23, 2006 I don't think the rear dipstick location on my R33 block was pre-drilled and plugged... hafta check this weekend. Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted February 24, 2006 Author Share Posted February 24, 2006 240z master, I am trying to post images but I am not having any luck. Do I download from the "reply to thread" screen? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 25, 2006 Share Posted February 25, 2006 240z master, I am trying to post images but I am not having any luck. Do I download from the "reply to thread" screen? You can use the HybridZ member photo albums. Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted February 25, 2006 Author Share Posted February 25, 2006 OK, photos in the member gallery, one is little blurry, I will get a better shot with the bottom flipped to top. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 26, 2006 Share Posted February 26, 2006 OK, photos in the member gallery, one is little blurry, I will get a better shot with the bottom flipped to top. I don't see your photos, maybe you have to publish them also to your profile (kind of a 2 step process). Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted February 26, 2006 Share Posted February 26, 2006 I saw them in the photo section yesterday. Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted February 26, 2006 Share Posted February 26, 2006 I saw them in the photo section yesterday. I just don't know where to look then, slanted eyes give me a problem every now and then Quote Link to comment Share on other sites More sharing options...
fbomb Posted June 14, 2006 Share Posted June 14, 2006 I have an R32 Rb26, I see the location where the people claim the pre-drilled hole is supposed to be. I have looked on the inside scratched the outside with a screwdriver and can't find a brass plug, it appears un-drilled. Can someone confirm that this is sometimes the case, or tell me that I am crazy and that it is drilled and plugged. Quote Link to comment Share on other sites More sharing options...
stony Posted June 14, 2006 Share Posted June 14, 2006 Mine is a r32 block and i just did mine this weekend. punched the plug out, pulled out the dipstick and swaped them. I recall reading somewhere someone saying that the r33 blocks may not have had the holes drilled and plugged. Quote Link to comment Share on other sites More sharing options...
GTR-240Z Posted June 15, 2006 Share Posted June 15, 2006 My block never had a brass plug so I had a machine shop drill a hole for me. Once the sump is off if you look inside the engine you can see the notch inside the block were the hole would have exited if it had been drilled. Quote Link to comment Share on other sites More sharing options...
RB26240Z Posted June 15, 2006 Author Share Posted June 15, 2006 I drilled out the block form the bottom, drilling at an angle, punched out the dipstick from the front and put it in the new drilled hole. Like stony said, the R33 blocks might not be drilled. Mine wasn't a R33, but the seller told me it was the later R32 with the updated crank collar. Henry Quote Link to comment Share on other sites More sharing options...
cheftrd Posted June 15, 2006 Share Posted June 15, 2006 Quote Link to comment Share on other sites More sharing options...
fbomb Posted June 15, 2006 Share Posted June 15, 2006 Is this an R32 or R33...this is exactly what my r32 looks like Quote Link to comment Share on other sites More sharing options...
Full-Race Geoff Posted June 22, 2006 Share Posted June 22, 2006 there is 2 generations of rb26. early R32 (predrilled, easy to punch out) and Late R32/R33/R34 (not drilled) Quote Link to comment Share on other sites More sharing options...
fbomb Posted June 22, 2006 Share Posted June 22, 2006 Does this mean that I have the improved crankshaft that with the oiling design flaw corrected? Quote Link to comment Share on other sites More sharing options...
