1 fast z Posted April 15, 2006 Share Posted April 15, 2006 Heres some pics, info on the website about the setup. I have the rears done as well, but no pictures. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted April 15, 2006 Share Posted April 15, 2006 oooohhh shiny.... Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted April 15, 2006 Share Posted April 15, 2006 wow, that's hot. I can't wait to do suspension on my car.... Quote Link to comment Share on other sites More sharing options...
evildky Posted April 15, 2006 Share Posted April 15, 2006 ouch, made mywallet hurt just looking at it did you shorten the struts or just stay full length? Quote Link to comment Share on other sites More sharing options...
phantaz Posted April 15, 2006 Share Posted April 15, 2006 who's are they and what spring and strut did you use????? common with teh info already =0) Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 15, 2006 Author Share Posted April 15, 2006 NO, I lengthend the Rears 1.56" and left the stock fronts. These are 240 strut tubes in a 280. I am using azzcars springs, etc. 250 Lb/in. Quote Link to comment Share on other sites More sharing options...
j260z Posted April 15, 2006 Share Posted April 15, 2006 nice setup. did you screw the threaded tube to the strut to stop it from rotating? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 15, 2006 Author Share Posted April 15, 2006 nice setup. did you screw the threaded tube to the strut to stop it from rotating? Yep, only to keep the sleeves from rotating. Yea, all this stuff is arizona z cars setups. Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted April 15, 2006 Share Posted April 15, 2006 Just curious,why would you lengthen the struts? Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted April 15, 2006 Share Posted April 15, 2006 Nice, very nice! Mike Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 15, 2006 Share Posted April 15, 2006 Just curious,why would you lengthen the struts? Because 280 rear struts are longer than 240 rear struts. The fronts are the same. I agree though, I would have sectioned the front instead of lengthening the rear, especially for an autox car. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 16, 2006 Author Share Posted April 16, 2006 This car is driven DAILY, this is NOT only an autocross car, only sees like three autocross events a year. I need to clear speedbumps, etc. therefore cannot have a ground scrapper. Quote Link to comment Share on other sites More sharing options...
phantaz Posted April 17, 2006 Share Posted April 17, 2006 Yep, only to keep the sleeves from rotating. Yea, all this stuff is arizona z cars setups. im probably going to get flamed for this but.. umm did you expand the strut tube assembly for this to screw into or did you thread it on the outside?? from using my extremely expensive imaging device.. (eyball mark 1) they look like they are the same diameter.. the strut tube and the threaded coil over tube. ive never bought or used a set yet so i was just curious.. i had previously assumed they were welded together after one slid into another. sorry for such a newb question but i dont have any experience with the azzcar coil overs. thnx Quote Link to comment Share on other sites More sharing options...
stony Posted April 17, 2006 Share Posted April 17, 2006 The threaded collars slip over the outside of the strut. When i did mine i was real careful and cut the old perch off nice and even. this left a nice even spot for the collars to sit on. I used all AZC stuff too, Dave is real cool. the original set of springs i got were bad. they compressed and didnt come back up. this also screwed up the shocks because they bottemed out and destroyed the insides of the shocks. Without hesitation dave sent me all new stuff. I recommend them to anyone. Quote Link to comment Share on other sites More sharing options...
j260z Posted April 18, 2006 Share Posted April 18, 2006 phantaz, the threaded portion is an aluminum sleeve that slides over the strut tube (steel) and allows you to adjust your ride height. once the vehicle is on the ground and the vehicle weight is on the tube it shouldn't spin. rather than leaving it to chance people either put a bead of silicone on the perch or (a new one to me) screw the sleeve to the strut tube. Quote Link to comment Share on other sites More sharing options...
phantaz Posted April 18, 2006 Share Posted April 18, 2006 phantaz' date=' the threaded portion is an aluminum sleeve that slides over the strut tube (steel) and allows you to adjust your ride height. once the vehicle is on the ground and the vehicle weight is on the tube it shouldn't spin. rather than leaving it to chance people either put a bead of silicone on the perch or (a new one to me) screw the sleeve to the strut tube.[/quote'] i take it that somewhere inside the threaded tube is a perch?? or do you have some kind of locking mechanism insde for variable height? i was under the assumption that the collar/spring pearch where the spring rests was where you height variations came into. i know i know..newb question..=). sorry for thread jacking 1fastz... i was just really curious how they were put together Quote Link to comment Share on other sites More sharing options...
zed240au Posted April 19, 2006 Share Posted April 19, 2006 hi phantaz to answer your question and this is just the way ive decided to do it (i believe its the right way) the inside of the threaded tube has an section about 3/8 deep machined in it to sit over a collar welded to the strut tube very interested in the top of the struts though using my Bilstein struts i had to machine down the old fronts (im using new bilsteins in front and old fronts in rear to secion shorten struts)to accept the the top bearing dont have anywhere near as much room between the coil top and the top bearing at the momentas the ones in shown here ive machined a 3 mm spacer and locater hoping thats enought other wise ill have to pack with washers or machine a small lip into to coil top wont know till i fit them to the car later this week have pictures in my album if you want to see what im talking about cant work out how to show them here Mick Quote Link to comment Share on other sites More sharing options...
phantaz Posted April 19, 2006 Share Posted April 19, 2006 hi phantaz to answer your question and this is just the way ive decided to do it (i believe its the right way) the inside of the threaded tube has an section about 3/8 deep machined in it to sit over a collar welded to the strut tube very interested in the top of the struts though using my Bilstein struts i had to machine down the old fronts (im using new bilsteins in front and old fronts in rear to secion shorten struts)to accept the the top bearing dont have anywhere near as much room between the coil top and the top bearing at the momentas the ones in shown here ive machined a 3 mm spacer and locater hoping thats enought other wise ill have to pack with washers or machine a small lip into to coil top wont know till i fit them to the car later this week have pictures in my album if you want to see what im talking about cant work out how to show them here Mick thnx Mick.... im going to have to check those out.. visually im just not seeing what they look like. hopefully someone has pics of the inside of the threaded collar and maybe some pics of installations in progress including the welding/mounting of the perches =) once again sorry for thread jacking.. cant wait to see more pictures of it on the ground =) Quote Link to comment Share on other sites More sharing options...
zed240au Posted April 19, 2006 Share Posted April 19, 2006 will take some pics for u at the weekend just waiting on tube cutter to finish mine off so there still apart mick Quote Link to comment Share on other sites More sharing options...
phantaz Posted April 21, 2006 Share Posted April 21, 2006 awesome... i think coil over Z's have some of the best stances around.. ofcourse that might be because you can put nice wide rims on them =0)~ Quote Link to comment Share on other sites More sharing options...
