A/C and Intercooler Question
JSM
Yes I did search. Maybe I did it poorly but I didn't find my answer.
My question is how many of you are running A/C and an Intercooler? (240-280Z)
For those of you who had A/C before the IC, did you notice a difference once the IC was added?
What Kind of plumbing issues are there?
I don't have either yet but I just want to get all my info straight.
Thanks
As my Z is my second vehicle, I took the AC system out. I had very few (normal actually) issues with installing intercoolers. I've even tested several different shapes and sizes with minimal plumbing problems. I only cut into my radiator support for the REALLY big one which I didn't use anyways because it was too big to offer any improvement. Bigger is not better when it comes to intercoolers.
i have a 77 280 with factory ac .i used a 240sx intercooler i bought off of ebay -1 of those big chinese parts for rb install.i reclocked the turbo (t4-t3 hybrid) and ran the hot side pipe under the engine and through the rad core support on rh side.hot side pipe was welded fron summit u bends.i put some of those cast 90 bends from turbonetics on the ic.
So any difference in the way the A/C performed once installed?
Might be a bit late but. I run factory AC and a fairly large intercooler, and an engine oil cooler up front.
From the front INTERCOOLER>OIL COOLER>AC CONDENSER>RADIATOR>16" E-FAN
It actually runs cool when I'm not on it hard. Never overheated yet.
