Guest Death69 Posted June 10, 2007 Share Posted June 10, 2007 whats your ratio of mineral spirits to rustoleum? and now that Rustoleum makes automotive rattle can paint, do you think that would create a finish as good as OTM's? Quote Link to comment Share on other sites More sharing options...
drivercraz23 Posted June 11, 2007 Share Posted June 11, 2007 OTM that is awesome! To the kind of pple that are on a budget paint job, that is a show car paint job. Atleast it is to me. I now for sure know that I am goin to be painting my car with gloss black rustoleum. Side note, If you then the paint out more rolling it on, wont it have less of a orange peal look? Just what Im thinking, I have no experience at all in paint so go ahead and correct me if im wrong. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 11, 2007 Author Share Posted June 11, 2007 This paint DOES have larger ripples in it... It is only 2 thick layers of paint you are looking at at that shiny part. After sanding it is probably closer to 1.5 layers of paint. You should also sand with higher than 600 grit before you polish it. I won't call it show quality but it would look like a decent paint job that has been polished. You will learn that wetsanding is a love/hate relationship. Just make sure that the paint is 100% flat before you polish it!!! Quote Link to comment Share on other sites More sharing options...
jknc90 Posted June 22, 2007 Share Posted June 22, 2007 How much paint does it take to do a whole car (all 8 coats not just the first 2) Thanks Jon Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted June 22, 2007 Author Share Posted June 22, 2007 You could probably do it with a gallon and have a little left over ($28) I think the guy with a charger used just over a gallon but chargers are HUGE. Quote Link to comment Share on other sites More sharing options...
jknc90 Posted June 22, 2007 Share Posted June 22, 2007 Thanks Dan, I'm finishing up the body work on my car and will be painting soon but realized I didn't know how much to get lol Jon Quote Link to comment Share on other sites More sharing options...
DemoFly Posted July 11, 2007 Share Posted July 11, 2007 Hey guys, since this sounds like a good investment, I need some exercise, and already spent $150 on cool toys for this project. I was wondering, if I were to take a small, 4 or 6 inch roller and put a small amount of paint on it...probably in an inverse color such as white (to go on black). If I could do something like a brushed fine water splatter-like decal/pinstripe. You know, sorta like a sponge painted stripe. Oh hell, I'll use a sponge... Anyway, I was wondering if it actually as easy as it sounds. Or if there is some layer trick or sanding technique I won't be abiding by. Just thought of it, so I had to post it up. Quote Link to comment Share on other sites More sharing options...
djbit Posted December 3, 2007 Share Posted December 3, 2007 This is going to be my next project in white gloss professional. I will mix it with 20% Mineral Spirits. I'm also thinking of using their Rusty Metal Primer. Any one here try to use that primer? Quote Link to comment Share on other sites More sharing options...
frldyzpimpn Posted December 4, 2007 Share Posted December 4, 2007 Rustoleum it is for me!! Quote Link to comment Share on other sites More sharing options...
otherguy Posted January 7, 2008 Share Posted January 7, 2008 I am new to hybridz. I will be posting the pics of the 77 280z I just purchased a couple of months ago in the newbie section. But I thought I should add these links I found on the net for the DIY paint job using a roller or similar method. Here ya go. Enjoy: http://rollyourcar.com/default.aspx http://www.bryanswebpage.com/Paint/index.htm http://www.hotrod.com/techarticles/body/hrdp_0707_1962_ford_falcon_budget_paint_job/index.html http://s150.photobucket.com/albums/s97/gfeighny/ Quote Link to comment Share on other sites More sharing options...
Diablo Posted January 7, 2008 Share Posted January 7, 2008 I did this last summer but never got the chance to do the final wet sand. I know its gonna be a pain in the butt to do the final wet sand now after it has been sitting and drying for months. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted January 7, 2008 Author Share Posted January 7, 2008 I don't see why it would be harder to wetsand the paint after it has fully cured... Probably make it better to wetsand. It's a lot of work but it can look good. Quote Link to comment Share on other sites More sharing options...
Diablo Posted January 7, 2008 Share Posted January 7, 2008 I thought maybe because it has fully cured, it would be harder to take off? Anyways, now I just need to get over this food poisoning and the flu and I'll be back in business For polishing, what kind of polisher did you use? I don't see why it would be harder to wetsand the paint after it has fully cured... Probably make it better to wetsand. It's a lot of work but it can look good. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted January 8, 2008 Author Share Posted January 8, 2008 I thought maybe because it has fully cured, it would be harder to take off? Anyways, now I just need to get over this food poisoning and the flu and I'll be back in business For polishing, what kind of polisher did you use? The rustoleum isn't that hard to take off... For polising... an old T-shirt cut into strips and Mother's aluminum polish. Definitely not the best but it fit my budget. I'd sand more (up to 1500 grit) and use real paint polish(more fine) if I were to do it again. Quote Link to comment Share on other sites More sharing options...
Jeff260z Posted June 4, 2008 Share Posted June 4, 2008 I've been reading about this painting technique for a few years or so now. I've seen a lot of pictures of the results that people with patience and proper techique produce. Some are truely amazing. There is no question some of these jobs are show quality. It is possible with patience to get perfection. I was quoted $10,000 to paint my 260z from one shop. I could get that paint job done and it still not be perfect (it better be though for $10K) Once it left the shop I could get a scratch or two and my perfect paint isn't perfect "show quality" any more. But with a roller I could just fix the scratches myself and have perfection again. I think I'm using Interlux brightside black on my car. It's boat paint for god sakes but you can't argue with the results. Quote Link to comment Share on other sites More sharing options...
jeeper42 Posted June 4, 2008 Share Posted June 4, 2008 think I'll try this on the MR2 Quote Link to comment Share on other sites More sharing options...
ihatejoefitz Posted June 4, 2008 Share Posted June 4, 2008 This is going to be my next project in white gloss professional. I will mix it with 20% Mineral Spirits. I'm also thinking of using their Rusty Metal Primer. Any one here try to use that primer? I realize this was posted a while ago, but I might as well warn you. I painted my daily driver's hood with the white gloss early in the winter of '07. It was almost a perfect match with the factory white. Now, after seeing a lot of sun, it has taken on a little bit of a pink hue. I don't think it would be noticeable without the stock white there for reference, but it has changed. Quote Link to comment Share on other sites More sharing options...
djbit Posted June 4, 2008 Share Posted June 4, 2008 I ended up creating my own "perl" white color. I used three gloss white qts and one almond qt. I have not painted anything yet but I like the off white effect when I look at it in the container. I'm not looking for perfection since this is mostly my screw around fun car but I will certainly post before and after pictures here when I get around to doing the body work. I'll be spraying by the way. I realize this was posted a while ago, but I might as well warn you. I painted my daily driver's hood with the white gloss early in the winter of '07. It was almost a perfect match with the factory white. Now, after seeing a lot of sun, it has taken on a little bit of a pink hue. I don't think it would be noticeable without the stock white there for reference, but it has changed. Quote Link to comment Share on other sites More sharing options...
