the turbo is coming along (pictures)
well got some more work done today but still waiting for a some v band flanges so i tacked the downpipe on. i already pressure tested the left side and it looks good. once i finish the right side ill presure test that, then heat black heat wrap iwill cover the entire system.
  • Replies 49
  • Created
  • Last Reply
Top Posters In This Topic
  deja said:
Wow, nice work. Is that really going to fit in the Z? Looks like there will be no room for the radiator.
That is what I was thinking. That turbo is pusing forward pretty far forward.
What engine is that? Looks Gen III :icon6:
iv test fit eveything, theres gunna be like 1/2 to 1 inch between the radiator and the turbo but it fits, heres a picture from the test fit.
  MONGO510 said:
Do you have any provision for flex and expansion in the turbo piping?
nope, but thats a really good idea. i do have some vbands on the way which will alot me to take apart the system pretty easly.
After I posted I looked at your website and saw the mods you were doing up front. 1/2" isn't much, but I've got thing closer than that in my LT1 swap. Your car should fly that's for sure!
Nicely done!
Couple of things I would suggest. You need to address the expansion/vibration issue mentioned by Mongo510. I also strongly suggest making bracket(s) to support the weight of the turbo, else the headers are going to crack. Have you considered I/C plumbing? You are going to have to reclock the compressor housing probably pointing straight down since there is no way you can a get a 90* turn with 2.5" pipe with such little clearance. Also give strong consideration to the oil feed and drain.
Good luck.
  Scottie-GNZ said:
Nicely done!
Good luck.
i already thought of that, here are some picture of the bracket i made to support the turbo. it can hold the turbo on its own with no problem. i am considering adding a stainless steel flex joint to deal with heat expantion.
as for the intercooler piping, i think im gunna clock the turbo so the outlet is facing forward and slightly down so i can run the tubing under the front cross member. its gunna be trick but im not worried.
i have already gone ahead and tapped the oil cap above the oil filter and will be using that to supply oil to the turbo. i may also put a t on that for a oil pressure sender if i dont run it off the factory location.
thanks for the comments!
  dr_hunt said:
Good points scottie. BTW, that turbo does look kind of small for a single turbo application, but should be good for 600 to 700Hp which should be pleanty. What EMS are you planning on running?
my goal is 500 reliable hp because i want to get decent gas milage (like 20-25 mpg hwy) which with 44 injectors should be possible. im sure ill get bit by the hp bug and want more latter though (that damn hp bug!)
i base this on the fact that there are people over on the performance truck forums who are getting 18mpg with 9000 lbs trucks and auto transmissions.
oh btw its a Garrett GT4082 turbo.
I think the drive belt you have on here Should support everything you will throw at it.:lol:
Honestly looks like an awesome build. I have seen several of the single turboed trucks getting nearly 20mpg on the highway but that was with very, very careful driving. Enjoy
