S30 SPL Posted November 13, 2014 Share Posted November 13, 2014 @Texis - What offset are those wheels and have you put the car on the ground? As you can see, I have some clearance issues with the air dam and the front of the fender. What suspension are you running? Settings? I figured if I dial out some caster, it would move the wheel back, but that's not exactly the best for handling. Quote Link to comment Share on other sites More sharing options...
Dat Z Sun Posted November 14, 2014 Share Posted November 14, 2014 Any one have pics of 17x9 et+15 no flares...? searched threw the las 30 pages and nothing yet. Thanks Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted November 14, 2014 Share Posted November 14, 2014 (edited) Any one have pics of 17x9 et+15 no flares...? searched threw the las 30 pages and nothing yet. Thanks I'll have some 17x8 -3 17x8.5 +3 (rear size depending. Haven't taken the clearance measurement yet) mocked up this weekend on my new non-flared shell. x9 +0 fits just fine. May run into strut clearance with that +15. May need spacers to lower the effective offset and move it away from the strut tube. Edited December 5, 2014 by R3VO 3VOM Quote Link to comment Share on other sites More sharing options...
texis30O Posted November 17, 2014 Share Posted November 17, 2014 I had my airdamn clearanced for the wheel and tire set up. It was the only way after the BAMF flares were put on. Wheels are 5" backspacing up front and 5" in the rear. I have a 1st run ocnversion kit on my car with off the shelf parts. from wfritz Quote Link to comment Share on other sites More sharing options...
AZGhost623 Posted November 17, 2014 Share Posted November 17, 2014 Work CR01 15x9 -53 & 15x10 -53 What kind of modifications are needed to make that kind of setup work on your 280? Quote Link to comment Share on other sites More sharing options...
S30 SPL Posted November 24, 2014 Share Posted November 24, 2014 I had my airdamn clearanced for the wheel and tire set up. It was the only way after the BAMF flares were put on. Wheels are 5" backspacing up front and 5" in the rear. I have a 1st run ocnversion kit on my car with off the shelf parts. from wfritz Pics? What's that conversion kit all about? Quote Link to comment Share on other sites More sharing options...
texis30O Posted November 24, 2014 Share Posted November 24, 2014 Ford 8.8 lsd diff 5 lug conversion, coilovers, Wilwood brakes. Look in the drivetrain section. Quote Link to comment Share on other sites More sharing options...
Carlissimo Posted November 27, 2014 Share Posted November 27, 2014 (edited) Finally bit the bullet and replaced my old 15in Epsilons with a set of 17in Image BPS wheels. Edited November 27, 2014 by Carlissimo Quote Link to comment Share on other sites More sharing options...
310z Posted November 27, 2014 Share Posted November 27, 2014 Those look nice. Quote Link to comment Share on other sites More sharing options...
Hester_prynne Posted November 28, 2014 Share Posted November 28, 2014 (edited) Rota RKR 15x9 -15 Edited November 28, 2014 by Hester_prynne Quote Link to comment Share on other sites More sharing options...
blacksnshn Posted November 29, 2014 Share Posted November 29, 2014 16x8 +0 XXR 537 with Hankook Z214 255-50-16 Had to give up some caster to make it not rub the air dam. Quote Link to comment Share on other sites More sharing options...
jgraham Posted December 2, 2014 Share Posted December 2, 2014 Wow what all did it take to get 255s under your z? I have the same wheels and was think that 225 was pushing it. Quote Link to comment Share on other sites More sharing options...
zmnap Posted December 3, 2014 Share Posted December 3, 2014 My 3 Piece Revolution RFX wheels. Getting refinished this winter. Gloss Bronze Lips with Matte Black faces. Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted December 4, 2014 Share Posted December 4, 2014 Only had limited supplies on hand at the time to mock the new wheels up, hence the weird camber. But new setup for my non-flared S30 which is waiting for warmer temps to be painted. Quote Link to comment Share on other sites More sharing options...
VKLR Posted December 5, 2014 Share Posted December 5, 2014 Only had limited supplies on hand at the time to mock the new wheels up, hence the weird camber. But new setup for my non-flared S30 which is waiting for warmer temps to be painted.10392347_859580087396102_2863883015721610000_n.jpg That is looking good, give us some rim data and expected tire sizes. I don't really want to cut and flare my car either. Quote Link to comment Share on other sites More sharing options...
R3VO 3VOM Posted December 5, 2014 Share Posted December 5, 2014 (edited) That is looking good, give us some rim data and expected tire sizes. I don't really want to cut and flare my car either. Thanks. I have a flared 280Z but only because it was all rusty. This one is 100% rust free body so I don't plan to cut this one. Wheels are Work VSXX 17x8 +22 and 17x8.5 +10. Front will have 1" spacer and rear will probably get a small slip on. I'm thinking of going with a 205/45, 225/45 or 225/40. Haven't made up my mind yet. Good thing about 17" is you can get nearly any size and profile you want. My flared car is on 16" and there is very limited choices. Edited December 5, 2014 by R3VO 3VOM Quote Link to comment Share on other sites More sharing options...
socorob Posted December 8, 2014 Share Posted December 8, 2014 Infiniti wheels with 245-40-17 rivals. Quote Link to comment Share on other sites More sharing options...
disepyon Posted December 13, 2014 Share Posted December 13, 2014 Quick question, those of you running 17x9.5 wheels up front, are you using a bump steer spacer? Are there clearance issues? Quote Link to comment Share on other sites More sharing options...
415DZ Posted December 20, 2014 Share Posted December 20, 2014 For those of you running 16x8 what tires sizes are you running and what suspension? I'm looking for 16x8 all around with maybe 225/50/16 tires. I will run eibach progressives with tokico blues. I wanna know if I need to roll my fenders or trim back the stock perch to prevent rubbing. Thanks for your help. Also if anyone has pictures of rota wires or rota flush wheels please share them. Would love to see them mounted on a 240 Quote Link to comment Share on other sites More sharing options...
blacksnshn Posted December 20, 2014 Share Posted December 20, 2014 For those of you running 16x8 what tires sizes are you running and what suspension? I'm looking for 16x8 all around with maybe 225/50/16 tires. I will run eibach progressives with tokico blues. I wanna know if I need to roll my fenders or trim back the stock perch to prevent rubbing. Thanks for your help. Also if anyone has pictures of rota wires or rota flush wheels please share them. Would love to see them mounted on a 240 Quote Link to comment Share on other sites More sharing options...
