DrEaM Posted August 19, 2007 Share Posted August 19, 2007 so i just ordered a new steering rack from msa and i was going to order a solid diff mount BUT the sales guy told me that it would transmit ALOT of harshness back into the car, and that the solid mount was mainly for race cars... now i want to know what personal experiences are with going with a solid mount.. i'm thinking about going with the arizona z car mount or the msa mount some advice would be appreciated Link to comment Share on other sites More sharing options...
Clifton Posted August 19, 2007 Share Posted August 19, 2007 Doesn't transmit harshness, just alot of noise. If you have obnoxiously loud exhaust you probably won't notice. If it is on the more quite side it will get old hearing the hum. Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 19, 2007 Share Posted August 19, 2007 The noise will vary depending upon the condtion of your diff. Some have had worse experiences than others The bigger problem is they will cause your front crossmember to crack and ultimately destroy itself. http://forums.hybridz.org/showthread.php?t=108276 There are other threads where people have posted pictures of the destruction caused to their rear suspensions when the cracked cross member fails. Not pretty. Link to comment Share on other sites More sharing options...
bjhines Posted August 19, 2007 Share Posted August 19, 2007 This is what you need to go along with the solid front mount. A solid rear mount. The solid front mount was designed to be used with a solid rear mount. The factory mustach bar is a spring and it bends into an S-shape. This will fatigue the crossmember and the lower chassis mounting points. This is not my picture but one for the record. The crossmember is not only the next weakest link but it will fatigue to the point that it will literally fall apart on it's own. Here are some pics of a cracked but still holding together crossmember. This one was never subjected to more than stock power. The damn thing made all sorts of creaking and clanging noises before I gave everything a good look. This is what I found, cracks everwhere. Link to comment Share on other sites More sharing options...
bjhines Posted August 19, 2007 Share Posted August 19, 2007 Another approach to this problem is the Ron Tyler mount. The R.T. mount was designed to lower the nose of the differential for the JTR V-8 swaps. You will need to adjust the dimensions to suit your engine tranny combo. This picture shows that it lowers the differential right to the crossmember's top surface. Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 19, 2007 Share Posted August 19, 2007 This post should be hyperlinked into the FAQ thread. Link to comment Share on other sites More sharing options...
ktm Posted August 20, 2007 Share Posted August 20, 2007 Wow. VERY nice photos demonstrating the problem. I know I switched BACK to urethane from a solid mount (did not drive with it, only mounted it), after doing hours and hours of reading. I agree with Pop. Link to comment Share on other sites More sharing options...
smoorenc Posted August 20, 2007 Share Posted August 20, 2007 I had the Arizona Z Car solid one on mine, but not for too long. I even tried sandwiching in radiator hose rubber to help dampen the noise levels. It finally became unbearable and I removed it. Link to comment Share on other sites More sharing options...
johnc Posted August 20, 2007 Share Posted August 20, 2007 Stuck and linked. Link to comment Share on other sites More sharing options...
DrEaM Posted August 20, 2007 Author Share Posted August 20, 2007 wow thanks for the feedback and the pictures!!! i will def be trying to go with something a little softer like the stock rubber mounts or if i can find one a urethane one.... do you guys know where i can find one at? Link to comment Share on other sites More sharing options...
JMortensen Posted August 20, 2007 Share Posted August 20, 2007 Try a little searching. There is a sticky post in the drivetrain forum that has info on several different front diff mounts. You won't find a poly mount, and the stock system with the strap and mount underneath is REALLY crappy, so you might look hard at the alternatives instead, including the one that bjhines showed above. Link to comment Share on other sites More sharing options...
dhp123166 Posted July 15, 2008 Share Posted July 15, 2008 I just replaced my worn out stock diff. mount with... A brand new stock diff mount. I had ordered a solid steel mount but cancelled it when after doing research and ascertaining that a solid steel one might be too noisy and as I have already lost the upper registers of my hearing range extra noise is something I would like to avoid. The weak point in the mount is the rubber which when it is new is not a problem, it is only after a long time of degradation that it fails, and really after normal driving how often do these things fail due to that? Every decade or so, if that? I guess it depends what kind of driving one is doing, 'cause like they say; "If you are not breaking anything you are not trying hard enough..." ______________________________________________________________ '76 280 Z-daily driver "Sometimes stock is good enough" Link to comment Share on other sites More sharing options...
Matt 78Z Posted July 30, 2008 Share Posted July 30, 2008 You can take a stock one and make it solid with a couple small welds. You weld 1/4" stock between the outer and inner shell on the bottom by the crossmember. The stock mount has a much larger surface area and wraps around the crossmember. This helps to disperse the load. Those solid metal pieces make for such a pinpointed load they tear up the crossmember. Link to comment Share on other sites More sharing options...
drmiller100 Posted February 1, 2009 Share Posted February 1, 2009 old school answer is to buy 8 feet of 1/8 or so plastic wrapped cable from local hardware store, and 2 clamps. Wrap the cables under the front cross member, then up and over the top of the differential. Pull it tight with a claw hammer, and tighten it up. You can use a shot front diff mount with this solution. Link to comment Share on other sites More sharing options...
coolbeans Posted October 23, 2009 Share Posted October 23, 2009 What are the symptoms of a broken or worn Diff mount? I ask because I recently discovered a movement in the rear of the car that occurs when I accelerate or decelerate. It is more noticable on deceleration but is there on acceleration as well. When I let off the gas the car seems to slide out in the rear to the right. I have a Quafie rearend and Wolf racing cv joints. I recently ran sticky tires on the car as well. Any help would be great Jeff Link to comment Share on other sites More sharing options...
HLS30-08077 Posted October 23, 2009 Share Posted October 23, 2009 The picture below is an example of a bad diff mount. You can see that the rubber is seperating from the metal. The first time you really GET ON IT (floor it or drop the clutch) the rubber will completely seperate and the diff will smack the upper diff strap (located above the diff to "Arrest" the diff under diff mount breaking conditions. You can tell if it's wearing out by dropping the four bolts that hold the crossmember and letting the diff hang by the mustache bar. While it's hanging, apply a trwisting motion to the crossmember while watching the rubber and metal area or the mount. (as shown in the picture) Dave Link to comment Share on other sites More sharing options...
HLS30-08077 Posted October 29, 2009 Share Posted October 29, 2009 OK, so here's my "Question of the Day" for any of you, Brad, BJHines, etc, etc. In the pictures on post #5, It shows 2 bolts holding the GM mount to the R/T mount. So why did my R/T mount only come with 1 hole? And which of the 3 holes on the GM poly mount should I use? Should I drill another hole? Wouldn't 2 bolts be better than one? Some one? Anyone? Dave Link to comment Share on other sites More sharing options...
johnc Posted October 29, 2009 Share Posted October 29, 2009 You're mistaken. Two bolts hold the GM mount to the diff housing and one bolt attaches to the RT mount. You don't need to drill another hole and two bolts won't make anything better. The mount is in compression under load. Link to comment Share on other sites More sharing options...
HLS30-08077 Posted October 29, 2009 Share Posted October 29, 2009 I'm not mistaken, I'm misinformed and confused. There are 3 holes on top of the GM mount. Should I just use the middle one? I know the mount is in compression when the car is under load (forward motion) but what about if the car is in reverse and the only thing holding the diff up is 1 bolt? Just trying to cover all the bases. For safety, clarity and peace of mind. Dave Link to comment Share on other sites More sharing options...
JMortensen Posted October 29, 2009 Share Posted October 29, 2009 I'm not mistaken, I'm misinformed and confused. There are 3 holes on top of the GM mount. Should I just use the middle one? I know the mount is in compression when the car is under load (forward motion) but what about if the car is in reverse and the only thing holding the diff up is 1 bolt? You could drill another hole in the RT mount and use two holes if it makes you more comfortable, but here are a couple questions for you that may ease your mind. How much torque do you put to the pinion in reverse vs driving forward? Enough to cause that bolt to fail under tension? How many bolts hold the stock diff mount to the crossmember that's taking 100% of the torque under acceleration? What size is that bolt compared to the one on the GM mount? Link to comment Share on other sites More sharing options...
