stony Posted September 26, 2007 Author Share Posted September 26, 2007 Update: oil cooler/filter relocator is plumbed Gonna take a break and let all the holes in my hands heal up before i make any more hose The oil cooler lines will be clamped to the side of the radiator for anyone wondering Next is the fuel system. Have to mount the new EFI pump/filter, mofify the tank with a return fitting and vent along with install a better sump. the -10 hose is allready run to the engine compartment all i have to do is run the return. Quote Link to comment Share on other sites More sharing options...
stony Posted September 27, 2007 Author Share Posted September 27, 2007 Got some of the fuel system done tonight :> All the fuel system needs is a -10 so I can hook up the distro block to the supply line, a -8 return hose routed from the FPR to the tank and a vent line installed in the tank. Next comes intercooler piping and a couple odds and ends for hardware and ladies this thing will be almost ready to start up. Quote Link to comment Share on other sites More sharing options...
BirdmanZ Posted September 27, 2007 Share Posted September 27, 2007 Looks like you've got a small fortune in AN fittings there. Quote Link to comment Share on other sites More sharing options...
Careless Posted September 27, 2007 Share Posted September 27, 2007 Looks like you've got a small fortune in AN fittings there. Haha, I counted like 27-29. At no less than 15 bucks a piece, I'd agree. LOL Quote Link to comment Share on other sites More sharing options...
stony Posted September 28, 2007 Author Share Posted September 28, 2007 Got most of them with the car i got the motor out of. Dip drop about 500 in fittings in hose to finish everything up though. Quote Link to comment Share on other sites More sharing options...
turbo_fb Posted September 28, 2007 Share Posted September 28, 2007 For a second there I couldnt figure out why the fuel return line went into the water catch tank Finaly good pictures of that extra water outlet from the intake. Nice project and pics. Thanks. Quote Link to comment Share on other sites More sharing options...
Careless Posted September 28, 2007 Share Posted September 28, 2007 For a second there I couldnt figure out why the fuel return line went into the water catch tank Finaly good pictures of that extra water outlet from the intake. Nice project and pics. Thanks. HAHHAHA, it took me like 2 minutes of hard staring to figure out that the hose from the Rail was not connected to that 90° bend at the water canister. Quote Link to comment Share on other sites More sharing options...
stony Posted September 28, 2007 Author Share Posted September 28, 2007 Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 28, 2007 Share Posted September 28, 2007 wow.. amazing work! AN fittings loook sooo good Quote Link to comment Share on other sites More sharing options...
Careless Posted September 28, 2007 Share Posted September 28, 2007 yeah yeah, stony. way to rub in the fpr and the nice tigs on the back of the water-tank nice stuff man. you should anodize the car red, and the engine blue, so everything matches. hahaha Quote Link to comment Share on other sites More sharing options...
stony Posted September 28, 2007 Author Share Posted September 28, 2007 Working mounting the intercooler today and finishing up teh tranny cooler and fuel system. I got the fuel tank out and its a tad small!!!!!! will be modified with a HUGE sump and fitting for a return line and vent here are some shots of the intercooler in its location. Quote Link to comment Share on other sites More sharing options...
stony Posted October 1, 2007 Author Share Posted October 1, 2007 Well all the welding is done now all that is left is fuel tank, exhaust intercooler piping, and electrical. Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 7, 2007 Share Posted November 7, 2007 Wow, spend a few months away from the board and miss progress of an amazing project. Everything looks great stony keep up with the updates and the great work! Quote Link to comment Share on other sites More sharing options...
stony Posted November 11, 2007 Author Share Posted November 11, 2007 Sorry some of the pics are blurry its getting kind of cold outside and i took these in the trailer after i finished up today. Quote Link to comment Share on other sites More sharing options...
stony Posted November 11, 2007 Author Share Posted November 11, 2007 All the welding is done just need to find someone brave enoug to weld on the fuel cell once thats done then it all goes together for a final fit check then the engine comes back out to get the converter installed. Then off to get wired up Quote Link to comment Share on other sites More sharing options...
BirdmanZ Posted November 11, 2007 Share Posted November 11, 2007 Looks good man. Cant wait for startup vids:2thumbs: Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 15, 2007 Share Posted November 15, 2007 Hey stony, where are you going to hook the BOV vacuum line to? Also do you know which spring your BOV uses? Thanks -Chris Quote Link to comment Share on other sites More sharing options...
stony Posted November 16, 2007 Author Share Posted November 16, 2007 Line will come from intake manifold and i have no idea what spring it uses. Are you talking spring weight??? Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 16, 2007 Share Posted November 16, 2007 Line will come from intake manifold and i have no idea what spring it uses. Are you talking spring weight??? TiAL BOV's have different internal springs available, they go by color codes and a PSI rating (not boost PSI), Mine had a 11 PSI (unpainted) when I got it and now use a 9 PSI (white) but, the BOV still seems to hardly open and most of the time air surges out the turbos on low boost (5psi and under?). More info, http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf My guess is you have an 11PSI as it is what is most commonly sold with the BOV, I was just wondering if you had changed it or were running the 11 PSI one without problems. I had never had an issue on my old DSM and its been a bit frustrating thus far. Thanks -Chris Quote Link to comment Share on other sites More sharing options...
stony Posted November 17, 2007 Author Share Posted November 17, 2007 I've got a gready type R standing by if this one give me issues Quote Link to comment Share on other sites More sharing options...
