SHO-Z Posted September 23, 2007 Share Posted September 23, 2007 I just found this, I know it is a TR6, but the set up is neat and utilizes a system that the supercharger is not running all of the time. It is close to what I am working on. http://topshamautoparts.com/tr6/index.htm Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted September 24, 2007 Share Posted September 24, 2007 whoa.. uses an electric switch to turn it on and off?! Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted September 24, 2007 Share Posted September 24, 2007 i had an idea like that.. i wanted to do it on my van (econoline 150 with a 351 windsor) i used the van for hauling my dirt bikes around to races and thought it could use some more umph but i was young and nothing materialized other than just an idea.... Quote Link to comment Share on other sites More sharing options...
KillerBjt Posted September 25, 2007 Share Posted September 25, 2007 Ya i heard that some of the new Mercedes come with supercharges with electronic clutches that can be engaged and disengaged electronically. Quote Link to comment Share on other sites More sharing options...
2+2 turrrbo Posted September 25, 2007 Share Posted September 25, 2007 Ya i heard that some of the new Mercedes come with supercharges with electronic clutches that can be engaged and disengaged electronically. that has been used in mercedes benz's for over 7 years now ,they are pretty small superchargers on the c230's Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 25, 2007 Share Posted September 25, 2007 Not only that, but if you control the bypass electronically (which most newer s/c have built in), you can accomplish the same thing. There's a twin turbo supercharged WRX that uses one of these electronic Mercedes s/c and switches it off once the turbos build like 3lbs of boost. Mario Quote Link to comment Share on other sites More sharing options...
Cruez Posted September 25, 2007 Share Posted September 25, 2007 I always wondered about that.... using a clutch like an A/C compressor uses. I wondered why people said that you can't do that... I remember a thread about the car in Mad Max... where he "turned the supercharger on". People said you couldn't do that. I wondered why not ?? Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted September 25, 2007 Share Posted September 25, 2007 88 and 89 supercharged mr2's have a electromagnetic clutch also. Theres a light on the dash that tells you when its engaged. Quote Link to comment Share on other sites More sharing options...
buZy Posted September 25, 2007 Share Posted September 25, 2007 Whoa that little car must be a rocket! Very Cool! Quote Link to comment Share on other sites More sharing options...
naviathan Posted September 25, 2007 Share Posted September 25, 2007 The electric clutch is better than using an electronic bypass. With the bypass you still get the drag of the s/c without the added boost. With the electric clutch you can drop the drag and the boost all together. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted September 25, 2007 Share Posted September 25, 2007 According to Eaton, an M90 (which is oversized for our engines) takes about 1/3 hp to turn with the bypass active at 60mph. How does the air flow through the Mercedes S/C with the clutch off? Mario Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted September 25, 2007 Author Share Posted September 25, 2007 The only turning, if at all, it will be doing will be due to the friction in the clutch. There is HP losses on every pulley in a system. One more thing, all of you FI guys might want to look at his FI conversion on this project. Quote Link to comment Share on other sites More sharing options...
rztmartini Posted October 6, 2007 Share Posted October 6, 2007 did you guys see the video?! that thing sounds insane! ooooo i want! Quote Link to comment Share on other sites More sharing options...
SilentNight1647 Posted October 6, 2007 Share Posted October 6, 2007 The reason it wouldn't work in Mad Max is because it's a roots blower that have a boost tube that you can pull air though if disengage it. Believe me I thought long and hard about the Mad Max setup and why some stuff would and wouldn't work. It's one of my favorite movies. Quote Link to comment Share on other sites More sharing options...
