watanabe tire sizes
Hey I got a set of watanabe RS 16x9.5 (-19) and 16x9.0(-13) from 240z Master. Im getting to the point in my build were I need to mount the wheels for fender flare fitment. Im running stock spring perches with 1" lowering springs. Does anyone have any idea what tire sizes would be for best fitment? What brand of tires do you recommend? Thanks
I have RS Watanabes for my zed which has stock spring perches and lowered spring like your setup. The rims I have are 16x8.5 -6 and 16x9.5 -19. I have 225/50/16 on the fronts and 245/45/16 on the 9.5" on the rear. The only pics I have are with no springs installed so I could check the rear custom flare and inner guard so I have blocks of wood that are just a little under a fully bound spring = the car will not get this low on the road.
The rims clear the stock spring perches with no issues. You can see a few pics here on my website.
http://nzeder.net/phpws/index.php?module=photoalbum&PHPWS_Album_op=view&PHPWS_Album_id=7
If I may, where in the world can you get the bigger RS Watanabe wheels (or Panasports for that matter)? Looking for 16x9/9.5.
Like the OP stated, from a member on the forum: 240z master.
and back on topic. 245/45/16's fit best imo, and they're coincidentally one of the easier sizes to find. any wider than that, and you're hard pressed...
Yup 245's are about all you can find unless you want R compound tires. It sucks but thats the way it is.
I run 245's all around and they are all stretched, I wish I could run 255 in the front and 275 in the back but I can only wish. Kuhmo makes a V700 that is a 265 I believe.. but thats R compound.
Sounds like you got the tire sizing all worked out. I like using the BF Goodrich Radial t/a tires. I use a 295/60/16 for the rears and a 235/60/15 for the front. 10.5 jj rear and 9.5 j fronts. I like the way the tire looks on the rims and the wheels fill out the overfenders to say the least. BF tires haven't let me down yet. Although I never tried racing in them.
Actually 9.5" are the largest that you can get in a 16" wheel. 13"-15" you can go up to 12" wide. http://www.rs-watanabe.co.jp/pay/al8r.htm
I bought my 1st set from Joji at http://www.wheelchoice.com 8.5"/9.5".
I sold my 9.5" and bought another (2) 8.5" from my friend Eiji who owns http://www.datsunspirit.com
You can also check http://www.takumiproject.com
