DJACEY Posted December 8, 2007 Share Posted December 8, 2007 I would appreciate it if some one could post some pictures here or send an email of how they connected the 260Z throttle pedal to the standard RB25DET cable assy. I presume it's pretty straight forward ? Quote Link to comment Share on other sites More sharing options...
chrism Posted December 8, 2007 Share Posted December 8, 2007 I have an RB20 but the cable connection should be the same. I didn't run cable to the peddle. I ran the cable to the linkage on the firewall. This is the pivot linkage with some of the push rod left over from the L28. I routed it through the hood latch assembly. You can see a home made clamp that converts the solid linkage over to cable. Then I connected a right hand drive Skyline cable from that to the throttle. You can see from this pic that the cable bracket is mounted to the other side of the hood latch assembly and bolted to the fire wall to keep the cable assembly from moving. From there it loops around to the throttle. The total movement of the peddle matches the total open and close position of the RB20 throttle. Works perfect. No modifications under the dash where it is hard to reach. Quote Link to comment Share on other sites More sharing options...
DJACEY Posted December 8, 2007 Author Share Posted December 8, 2007 Great idea using the existing linkage rather than trying to run the cable all the way through to the pedal. Thanks for the pictures - much better than a description. Quote Link to comment Share on other sites More sharing options...
stony Posted December 9, 2007 Share Posted December 9, 2007 I dont have any pics but what i had done was i cut the top of the gas pedal off of a z31 that had the rb20 motor in it then welded that piece to my Z's pedal linkage then ran the cable thru the hole where the stock linkage goes and hooked it up. Worked pretty good. Quote Link to comment Share on other sites More sharing options...
DJACEY Posted December 9, 2007 Author Share Posted December 9, 2007 Thanks Stony. Which intake manifold/thottle body are you using ? Quote Link to comment Share on other sites More sharing options...
jerryb Posted December 9, 2007 Share Posted December 9, 2007 I used a pulsar cable and firewall bracket....VIVA ebay I took me forever to figure out how to install the thing and then late one night I had a epithaney..... I trimmed the bracket down and bolted the remaining part to the firewall. Then I ground the ball off the pedal assembly and drilled it out to accept a bolt I think 3/8...sorry cant remember. I drilled a hole through the bolt so that the SS cable could be threaded through and clamped tight onto the pedal with a nut. I was so easy and looks pretty clean. Works great and the pedal feels smoother.....probably because it eliminated all the stock mechanical linkage pivot points. I will try to take an under dash pic... Hope this helps. Quote Link to comment Share on other sites More sharing options...
jerryb Posted December 9, 2007 Share Posted December 9, 2007 This one is under the dash Quote Link to comment Share on other sites More sharing options...
stony Posted December 9, 2007 Share Posted December 9, 2007 I was using the stock rb26 intake, Z31 cable ( but i think any TB cable should work) I dont really have any good pics sorry. Quote Link to comment Share on other sites More sharing options...
DJACEY Posted December 10, 2007 Author Share Posted December 10, 2007 Thanks for the responses guys - you've given me some ideas. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted December 10, 2007 Share Posted December 10, 2007 Mine uses the stock 240Z pedal linkage: Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted December 10, 2007 Share Posted December 10, 2007 http://www.arizonazcar.com/cableinstall.html Did this on my dad's to run a 240sx TB with a cable. Mario Quote Link to comment Share on other sites More sharing options...
jerryb Posted December 10, 2007 Share Posted December 10, 2007 Bingo...that pretty much what I did! Pics are better than my decription above. Quote Link to comment Share on other sites More sharing options...
DJACEY Posted December 11, 2007 Author Share Posted December 11, 2007 Nice job qwik240z. The Arizonazcar car site is great- thanks for sending me the link Mario. Quote Link to comment Share on other sites More sharing options...
Careless Posted December 12, 2007 Share Posted December 12, 2007 its a shame it doesn't have the bracket or the throttle cable part number =/ Quote Link to comment Share on other sites More sharing options...
jerryb Posted December 12, 2007 Share Posted December 12, 2007 and whats wrong with a nut and bolt! Quote Link to comment Share on other sites More sharing options...
Forrest Posted December 12, 2007 Share Posted December 12, 2007 You guys that connected to the throttle linkage on the firewall instead of replacing it...how does the pedal feel? I want to make sure when I do this that the pedal is really tight and smooth. Quote Link to comment Share on other sites More sharing options...
jerryb Posted December 12, 2007 Share Posted December 12, 2007 Taking out the stock linkage makes it smoother..IMO.... Quote Link to comment Share on other sites More sharing options...
lowrider Posted December 12, 2007 Share Posted December 12, 2007 with the throttle cable mounted to the fire wall it is much smoother and responsive compared to the stock pivot. Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted December 13, 2007 Share Posted December 13, 2007 Z31 cable mount will snap into the S30 firewall hole, I am using a Z31 cable on my car. Doug Quote Link to comment Share on other sites More sharing options...
chrism Posted December 13, 2007 Share Posted December 13, 2007 I have a smooth pedal response. It doesn't stick or feel loose. Quote Link to comment Share on other sites More sharing options...
