S30TRBO Posted January 11, 2008 Share Posted January 11, 2008 So I brought the Z over to my mechanic friends house who has a lift to put the R/T diff mount in and adjust the valves. My question is for guys who have done this in early 240Z like mine. How did you get it to fit around the stock brake/fuel lines. There is a stock clamp that holds all the lines together right where the mount goes. Does the bracket somehow get slid in behind the lines then bolted into place? That clamp looks like it’s tack welded to the body. All the pictures I found show the R/T diff mount mounted but there are no stock fuel/brake lines running in the tunnel? Note this pic is not my Z! No camera handy last night, Z is an hour away. I modified this picture and added my artistic fuel and brake lines in red so you get a better idea. Pic Credit: http://4moores.com/280z/ Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 11, 2008 Share Posted January 11, 2008 This is my early 260. Is your different? I think I may have had to mod it a tad... Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 12, 2008 Share Posted January 12, 2008 Here is a pic of my mount. I don't have the lines in at the moment, but I didn't think there was going to be an issue with clearance. The car is a 1970 model Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted January 12, 2008 Author Share Posted January 12, 2008 J, My lines actually run along the passenger side of the tunnel like this: Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted February 28, 2008 Share Posted February 28, 2008 Did you ever solve this problem? I'm running into the same issue on a series one. Quote Link to comment Share on other sites More sharing options...
junglist Posted February 28, 2008 Share Posted February 28, 2008 what bolts/nuts/washers are you guys using? I have the poly mount and am waiting for the RT mount from roostmonkey but I need to get all new hardware as the old stuff is all in pretty rough shape. Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted February 29, 2008 Share Posted February 29, 2008 The bolts that mount the RT mount to the tranny tunnel I ordered through Grainger. I'm reusing the diff bolts. Quote Link to comment Share on other sites More sharing options...
junglist Posted February 29, 2008 Share Posted February 29, 2008 do you happen to remember what size you used? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted March 2, 2008 Author Share Posted March 2, 2008 BayAreaZT said: Did you ever solve this problem? I'm running into the same issue on a series one. Pics as requested: http://www.putfile.com/album/179405 Quote Link to comment Share on other sites More sharing options...
BayAreaZT Posted March 4, 2008 Share Posted March 4, 2008 junglist said: do you happen to remember what size you used? M10x1.25 Thanks for the pics Joe. Got mine mounted now. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted October 15, 2008 Share Posted October 15, 2008 I just noticed that some of the pictures show two bolts holding the poly mount to the RT mount, and some showing just one bolt. The poly mount has three holes, so either way works. The question is, is one bolt enough, or should I drill out my rt mount for two holes, since it only came with one? Quote Link to comment Share on other sites More sharing options...
capt_furious Posted November 11, 2008 Share Posted November 11, 2008 Anyone have an answer to TR's question? I'm having mine mounted tomorrow (yeah, I'm checkbooking it, that's the problem with having only one car, no garage and driving it all the time) and I'm wondering about the possibility of using both the RT mount and the stock lower mount in conjunction with each other. It looks as if Joe (240ztt) was successful in this. How much thread is available on the stock bolts? Can you fit the ES poly mount on there and still have enough thread to get the lower mount on, or does the RT mount make this a non-issue by lowering the pinion in relation to the chassis and leaving no room for the lower mount? Car in question is a early 260 with an R200. The idea of one short bolt holding the nose of the diff in place during downshift / reverse bugs me. Just how strong is the bolt that comes with the ES poly mount? I'd rather not find out. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 13, 2008 Author Share Posted November 13, 2008 capt_furious said: It looks as if Joe (240ztt) was successful in this. How much thread is available on the stock bolts? Can you fit the ES poly mount on there and still have enough thread to get the lower mount on, or does the RT mount make this a non-issue by lowering the pinion in relation to the chassis and leaving no room for the lower mount? The idea of one short bolt holding the nose of the diff in place during downshift / reverse bugs me. Just how strong is the bolt that comes with the ES poly mount? I'd rather not find out. Probably a little late....All stock bolts were reused with both the R/T mount and the stock one in place. The top of my ES mount has 2 bolts holding it to the R/T mount. No issues thus far. Quote Link to comment Share on other sites More sharing options...
capt_furious Posted November 13, 2008 Share Posted November 13, 2008 Thanks, Joe! The mount is going in today. That's reassuring. Quote Link to comment Share on other sites More sharing options...
capt_furious Posted November 17, 2008 Share Posted November 17, 2008 Got it in, the car really puts the power down now without any feeling of slop. The fuel lines had to be moved up the tunnel a bit, but otherwise, it went in with minimal fuss, and the lower mount bolted right back in, as well. The nose of that diff isn't going anywhere! Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted November 17, 2008 Share Posted November 17, 2008 Congrats! Any pics for us? Quote Link to comment Share on other sites More sharing options...
capt_furious Posted November 17, 2008 Share Posted November 17, 2008 Didn't have a chance to get the camera in there, unfortunately. The install pretty much looks just like Joe's. No interference with the ebrake, either. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 19, 2008 Author Share Posted November 19, 2008 Sweet A.J. glad we all could help! Quote Link to comment Share on other sites More sharing options...
buZy Posted November 19, 2008 Share Posted November 19, 2008 Ours is trapped from the top and bottom. Much better than fully relying on the ES mount. Quote Link to comment Share on other sites More sharing options...
Pyro Posted November 19, 2008 Share Posted November 19, 2008 I used a universal sway bar bushings and bolt kit for my diff mount. Quote Link to comment Share on other sites More sharing options...
