N3RB Posted March 23, 2008 Share Posted March 23, 2008 Well, for awhile now my steering wheel shakes vigorously whenever i am at freeway speeds. I got an alignment and my brakes check and they are all good. But my friend pointed out that my boots for my steering rack is cut open and he said that they are supposed to be lubed. So I am thinking to just buy a whole new steering rack for 300 bucks. Because the rack could be corroded(they have been like that for years) . If there is another way to do this cheap that would be great. Quote Link to comment Share on other sites More sharing options...
Mr.INSANE Posted March 23, 2008 Share Posted March 23, 2008 Alot of the people here still have the stock steering rack with no problems. Theres a piece of rubber between the steering wheel rod and rack rod that is called a steering coupler. it sounds like yours may be worn out. http://www.thezstore.com/page/TZS/PROD/PSDC11/23-4161 Thats a replacement. I would replace a $12 dollar part before replacing a $300 Dollar steering rack Quote Link to comment Share on other sites More sharing options...
jknc90 Posted March 23, 2008 Share Posted March 23, 2008 If it ends up being the rack, I've got a used one for you, a lot cheaper than 300 too lol Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 23, 2008 Share Posted March 23, 2008 So I'm assuming from the post title that the rack locked up on you, hence the "Seizure"? The open boots will allow the ball joints at the end of the rack to be exposed to the elements, which may, with time, contribute to the shimmy of the steering wheel, but not any seizure that I'm aware of. Quote Link to comment Share on other sites More sharing options...
N3RB Posted March 24, 2008 Author Share Posted March 24, 2008 Alot of the people here still have the stock steering rack with no problems. Theres a piece of rubber between the steering wheel rod and rack rod that is called a steering coupler. it sounds like yours may be worn out.http://www.thezstore.com/page/TZS/PROD/PSDC11/23-4161 Thats a replacement. I would replace a $12 dollar part before replacing a $300 Dollar steering rack Ya, i replaced that about 6 months ago. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted March 24, 2008 Share Posted March 24, 2008 are your wheels balanced? Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted March 24, 2008 Share Posted March 24, 2008 My friend had a different issue with his Sentra. His sister had locked the tires and flat spotted the rear tires. No amount of balancing would get rid that horrible noise and vibration, but it might not be that. Quote Link to comment Share on other sites More sharing options...
stony Posted March 24, 2008 Share Posted March 24, 2008 If your steering wheel is shaking you either have a bent wheel or the wheels need to be balanced. Quote Link to comment Share on other sites More sharing options...
G.I.jonas Posted March 24, 2008 Share Posted March 24, 2008 If your steering wheel is shaking you either have a bent wheel or the wheels need to be balanced. Or you need an alignment its pretty amazing sometimes what an alignment will do. Quote Link to comment Share on other sites More sharing options...
stony Posted March 24, 2008 Share Posted March 24, 2008 Says he already got an alignment..... I don't think the shake has anything to do with the steering rack. Quote Link to comment Share on other sites More sharing options...
buZy Posted March 24, 2008 Share Posted March 24, 2008 How about the rack mounting isolators? Any movement there? Quote Link to comment Share on other sites More sharing options...
G.I.jonas Posted March 24, 2008 Share Posted March 24, 2008 Says he already got an alignment..... I don't think the shake has anything to do with the steering rack.Sorry i missed that,but like with anything it doesnt matter if something has been done if it wasnt done right. I'll probly put my money on bent rim. Quote Link to comment Share on other sites More sharing options...
N3RB Posted March 24, 2008 Author Share Posted March 24, 2008 Sorry i missed that,but like with anything it doesnt matter if something has been done if it wasnt done right. I'll probly put my money on bent rim. lol, rims are brand new. but ill go do another alignment and balance my tires this week. its damn bad... Quote Link to comment Share on other sites More sharing options...
G.I.jonas Posted March 24, 2008 Share Posted March 24, 2008 lol, rims are brand new. but ill go do another alignment and balance my tires this week. its damn bad... And i lose again Quote Link to comment Share on other sites More sharing options...
stony Posted March 24, 2008 Share Posted March 24, 2008 If they are new rims i wouldn't be surprised if you lost a weight. Happens all the time. I say start with a balance then do the alignment. Unless it all in one cost. Usually the alignments is more expensive. Quote Link to comment Share on other sites More sharing options...
BirdmanZ Posted March 24, 2008 Share Posted March 24, 2008 Check your wheel bearings. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 24, 2008 Share Posted March 24, 2008 I'm not an admin, but at times I can be pretty anal. For search purposes, should this string be titled "Shimmy" at the steering wheel instead of "Seizure". Keeping titles correct helps a lot in searches, and so far I've read nothing dealing with a locked or seized steering wheel or rack (which can happen, but this string does not appear to address this). Quote Link to comment Share on other sites More sharing options...
N3RB Posted March 24, 2008 Author Share Posted March 24, 2008 I'm not an admin, but at times I can be pretty anal. For search purposes, should this string be titled "Shimmy" at the steering wheel instead of "Seizure". Keeping titles correct helps a lot in searches, and so far I've read nothing dealing with a locked or seized steering wheel or rack (which can happen, but this string does not appear to address this). sorry about the posting, but I was referring to number 2, not number 1. Because it does seem like my steering wheel suddenly starts to shimmy side to side violently at 50 mph and up. I thought that "seizure" was a smart word to use. Ill use a more proper car word next time for search purposes. sei·zure (szhr)n. 1. The act or an instance of seizing or the condition of being seized. 2. A sudden attack, spasm, or convulsion, as in epilepsy or another disorder. 3. A sudden onset or sensation of feeling or emotion. Quote Link to comment Share on other sites More sharing options...
CalifaThugz Posted March 24, 2008 Share Posted March 24, 2008 I had the same problem with my 240sx, what was wrong with it is that my rotors needed to be resurfaced, or so I was told. I bought new ones and that solved the problem. Quote Link to comment Share on other sites More sharing options...
N3RB Posted March 25, 2008 Author Share Posted March 25, 2008 nice, thanks for all the input. i have alot to think about and cool stuff to buy. Quote Link to comment Share on other sites More sharing options...
