Challenger Posted March 30, 2008 Share Posted March 30, 2008 Well after seeing a picture of I believe Yorgee's airdam pushed up against the radiator I thought it would be smart to reinforce mine. Ill remove the photo if their any copyright infringement... I made it from strap steel from the local hardware store. ($7.00) Heres it mounted from the bottom. Mounts to two holes already in the radiator subframe. I believe they were for the valance? Mounts tight up against the inside of the airdam with small pieces of rubber (front bumper to bumper bracket gasket ). From the top. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted March 30, 2008 Share Posted March 30, 2008 Can you give out the dimensions on the pieces in a ms paint diagram. Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted March 30, 2008 Share Posted March 30, 2008 for 7 bucks you cant beat it Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 31, 2008 Author Share Posted March 31, 2008 Sure Ill get some dimensions, but I wouldnt go out and make one based on them... might not fit. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted March 31, 2008 Share Posted March 31, 2008 I had something similar on my car after someone told me it was flexing badly. I found it made the car feel more stable at higher speeds. Evan Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 31, 2008 Share Posted March 31, 2008 was the cause of the airdam being pushed up from the speed of the car, or is it just that flimsy. Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 31, 2008 Author Share Posted March 31, 2008 was the cause of the airdam being pushed up from the speed of the car, or is it just that flimsy. Both, the urethane isnt very rigid and at high speed it starts to flex. Hopefully this paired up with my radiator enclosure (see sig) the front end will stay on the ground. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted March 31, 2008 Share Posted March 31, 2008 Be careful around curbs, you have just lost any of the forgiveness of urethane. You could shove that strap right through the air dam. Good idea though. Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 31, 2008 Author Share Posted March 31, 2008 The straping has a rounded edge at the front so it wont go through. I took this into consideration and the way its made under a heavy impact the braces will rotate sideways.... atleast thats the plan. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted March 31, 2008 Share Posted March 31, 2008 I have a design in mind that is similar but adds more radial bracing that might actually work better in a curb incident, since I'm thinking about getting one of these air dams. Quote Link to comment Share on other sites More sharing options...
CArFAn Posted March 31, 2008 Share Posted March 31, 2008 Thanks for posting. I have the same airdam only its on a 240z. I just wanted a starting point as to how much material i should get. Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted March 31, 2008 Share Posted March 31, 2008 seeing as i'm sending someone payment for a xenon airdam today, its good to have this heads up for when i install it. Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 31, 2008 Share Posted March 31, 2008 Another approach is to use a flat plate from the top lip of the airdam to the radiator support crossmember. This helps aerodynamics as well. ... Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 31, 2008 Author Share Posted March 31, 2008 Yeah, I did that also. Look in my sig. It did provide some strength but not enough in my opinion. (26 guage, couldnt cut anything else.) Quote Link to comment Share on other sites More sharing options...
hoov100 Posted March 31, 2008 Share Posted March 31, 2008 imo you should put some sheet metal over it to keep foreign objects from entering that little area. Quote Link to comment Share on other sites More sharing options...
Challenger Posted March 31, 2008 Author Share Posted March 31, 2008 What little area? Quote Link to comment Share on other sites More sharing options...
240zdave Posted April 1, 2008 Share Posted April 1, 2008 Has anyone experimented with fabricating / attaching a splitter to the bottom edge of the air dam? I am thinking of adding that to the dam on the race car, but haven't gotten into materials or attachment methods yet. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted April 1, 2008 Share Posted April 1, 2008 Challenger is working on that too! http://forums.hybridz.org/showthread.php?t=132261 Quote Link to comment Share on other sites More sharing options...
hoov100 Posted April 1, 2008 Share Posted April 1, 2008 What little area? never mind you did it already.. Quote Link to comment Share on other sites More sharing options...
Austin240Z Posted April 10, 2008 Share Posted April 10, 2008 Very nice, need to do this on mine too Quote Link to comment Share on other sites More sharing options...
