WizardBlack Posted August 12, 2008 Share Posted August 12, 2008 Bobby C. said: what' ive seen done...before your plates are welded in, you cut a hole in the floor and drop the cage down to weld up top...then install your plates and finishing welding...seems like a good way. Ahh, that's sneaky. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 22, 2008 Share Posted August 22, 2008 you guys should really have a look at 74 5.0l 's spec sheet on his main hoop design...just buy the tube, take it to a local exhuast shop and walla! main hoop done...no fuss no muss!!! and you dont have alot of useless parts you have to modify to make work (IE- your not paying for stuff you dont use!!) buy the rest of the tube and fab it up yourself! as for the $200 notcher...i vote for MULL's way of notching...measure are to cut out...draw line and hand notch with a $20 pawn shop grinder!!! every penny counts right! I'll probably be doing the exact same cage after she comes back from being blasted! Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted August 22, 2008 Share Posted August 22, 2008 I wouldn't go to a muffler shop. Just take the print to a local cage builder. That way you don't waste money and material on a poorly bent main hoop by mister muffler. Justin Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 23, 2008 Share Posted August 23, 2008 cage builders in this area (ATL) are extremely prideful in their work...IE i got one quote for a 5k STARTING bid on a 10-12 pt cage from a reputable builder down the road...he would probably charge 500 to bend some pipe...but i do agree with you about not wasting money to end up with a bent piece of metal worth its weight! If you have a good and reasonably priced build in your area then that would be the way to go...if not shop around some exhaust shops (they bend pipe all day too) Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted August 24, 2008 Share Posted August 24, 2008 This is for the guys looking to do their own coping on tubing. This is a neat little program I've found a while back, it allows you to type in a few things, and then it will generate a wavy line, which when you print it out, and roll it on to the end of the tube you're cutting, it will give you a pattern where to cut. http://metalgeek.com/static/cope.pcgi Quote Link to comment Share on other sites More sharing options...
v8dats Posted August 24, 2008 Share Posted August 24, 2008 i think i saw that on extreme 4x4. cool stuff!! Quote Link to comment Share on other sites More sharing options...
redneck1545 Posted August 24, 2008 Share Posted August 24, 2008 wow! that helps out alot!!!! THANKS monkeyt88!!!! Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted August 28, 2008 Share Posted August 28, 2008 Sticky that puppy. That's too good to let fall into the sea of threads. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 16, 2008 Share Posted September 16, 2008 Hey Ivan280zt, Sorry it took so long to take these for you but I have been busy and pulled in many ways. I hope it is not to late, but maybe you will get some ideas. The cage has been certified to 8.50 1/4 mile. John PS: the rear back bar behind the seats where the harnes bolts to was custom made, not jegs. Also the rear bars were custom made, only the hoop and window / dash bars were jegs. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 16, 2008 Share Posted September 16, 2008 More pictures. Quote Link to comment Share on other sites More sharing options...
MoNkEyT88 Posted September 16, 2008 Share Posted September 16, 2008 jnjdragracing said: More pictures. Did you modify the bar behind the seat so you could move your seat back further? I have the 12 point jegster cage, and from what I can tell, the bar would just go straight between the main hoop. I'm 6'3" and would need the seat back further. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 16, 2008 Share Posted September 16, 2008 Yes we did, we made our own bar. John MoNkEyT88 said: Did you modify the bar behind the seat so you could move your seat back further? I have the 12 point jegster cage, and from what I can tell, the bar would just go straight between the main hoop. I'm 6'3" and would need the seat back further. Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted September 18, 2008 Author Share Posted September 18, 2008 John, hey bud thanks alot for the pictures that is what I was looking for. I am modifying my floor board so I can run my new Sparco seat and as soon as that is in place cage will be getting installed around it. Quote Link to comment Share on other sites More sharing options...
Slow_Old_Car Posted September 18, 2008 Share Posted September 18, 2008 JNJ what is that steering wheel release system your using? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 18, 2008 Share Posted September 18, 2008 It is made by Moroso, it is just a quick disconnect. Since we are getting older and bigger around the belly we need it in order to remove the steering wheel so we can slip in the car because of the roll cage. John Slow_Old_Car said: JNJ what is that steering wheel release system your using? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 18, 2008 Share Posted September 18, 2008 redneck1545 said: you guys should really have a look at 74 5.0l 's spec sheet on his main hoop design...just buy the tube, take it to a local exhuast shop and walla! main hoop done...no fuss no muss!!! and you dont have alot of useless parts you have to modify to make work (IE- your not paying for stuff you dont use!!) buy the rest of the tube and fab it up yourself! as for the $200 notcher...i vote for MULL's way of notching...measure are to cut out...draw line and hand notch with a $20 pawn shop grinder!!! every penny counts right! I'll probably be doing the exact same cage after she comes back from being blasted! This is what I did. I sent Dan's jpeg to a local cage builder and went and picked up the bent main hoop. Worked great, the hoop was TIGHT (the way it should be) to the sides of the car. I left the length long and trimmed to fit. As for the tubing notches, I just used the program the other day for the first time. It is WAAAAAY easier. Sometimes you have tubes coming together in weird angles and can't do that, but if you can by all means go for it. I measured by using tape to simulate the tube and a digital protractor to get the angle. Worked great. If someone does use Dan's tube specs, be aware that paper towel rolls are 1 5/8" ID so they'll plug right onto the tube. If you have a weird junction to figure out where the program doesn't work, it's useful to be able to figure out the notch on a piece of cardboard then slide it over the tube and have it right. Quote Link to comment Share on other sites More sharing options...
JIM73240Z Posted September 18, 2008 Share Posted September 18, 2008 +1 on the metal geek program. made life so much easier for 90 degree cuts. once it started to get off of 90, i just went slower. after a buch of tubes being notched, i have not used it much because i have figured out the notches in my head. as for tube coming into each other at really wierd angles, paper towel tubes are your best friend. way cheaper than messing up a tube and having to go get more. jimbo Quote Link to comment Share on other sites More sharing options...
jtl260z Posted October 14, 2008 Share Posted October 14, 2008 jtl260z said: I got the 8 point installed and modified. I will be painting it soon and I will post some pics then. PrOxLaMus is right, it does need a lot of work to fit, but I was planning a custom set up from the start. I finally finished my cage. Quote Link to comment Share on other sites More sharing options...
Filmjay Posted November 6, 2008 Share Posted November 6, 2008 jtl260z said: I finally finished my cage. [ATTACH]9791[/ATTACH] That looks great!!!!! Sorry, I didn't read through the fine details, but what cage kit is that? Jegs? I've put a Jegs cage in a 71 Nova before, but I haven't worked on Z-cars..yet..still looking for a good 240 that's not a total dog or a beauty queen. Have any troubles to speak of? Quote Link to comment Share on other sites More sharing options...
