grumpyvette Posted August 7, 2008 Share Posted August 7, 2008 http://www.hotrod.com/techarticles/engine/hrdp_0802_chevy_intake_manifold_porting/index.html http://www.gofastnews.com/board/technical-articles/1181-porting-school-6-secrets-reduce-valve-shrouding.html#post5343 http://www.sa-motorsports.com/diyport.aspx http://www.circletrack.com/techarticles/general/139_0305_port_matching_engine_porting/index.html http://speedtalk.com/shows/027_jim_mcfarland.html http://www.chevyhiperformance.com/techarticles/95518_small_block_cylinder_head_porting/index.html http://www.gmtips.com/3rd-degree/dox/tips/plen-port/port.htm http://www.bfranker.badz28.com/96ss/58porting.htm http://www.eecis.udel.edu/~davis/z28/buildup/plenum/ http://www.diyporting.com/molds.html http://www.fordmuscle.com/archives/2006/12/MakingMolds/index.php Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 8, 2008 Administrators Share Posted August 8, 2008 Porting??... Hmmm… I for one am a huge advocate for porting. Heck, port work is our primary business! From Intake and exhaust ports and manifolds to coolant and oil passages and pumps. If fluid flows through it and I have access to it, it gets ported, (air falling into the category of a fluid). And Ron Tyler laughs at me whenever I port on an L-6 front cover smoothing the transitions for the coolant and the oil. HA! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted August 8, 2008 Share Posted August 8, 2008 ive always wanted to do DIY porting but I am always afraid of ruining the valve seat Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 8, 2008 Share Posted August 8, 2008 As soon as we get the timing chain stuff figured out, we'll be doing a home brew port job. We'll probably post a thread about it. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted August 8, 2008 Share Posted August 8, 2008 Porting what is that? Never heard of it, much less tried doing any of it. I heard it can be done by pouring sand down the intake manifold while the engine is running? I might have to try it on the tt setup! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted August 8, 2008 Share Posted August 8, 2008 ohh that's how you do porting!! I heard you can port your intake manifold and extrude the exhaust manifold at the same time pouring sand in the intake!! this is sooo much easier than I thought! Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted August 8, 2008 Share Posted August 8, 2008 I bet you can use that sand in the block to polish the bearings and journals too! Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted August 8, 2008 Share Posted August 8, 2008 I just did that sand porting technique and now my car runs like ♥♥♥♥, I think I need to poor water in now to rinse the sand out, does this sound right to you guys? Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted August 8, 2008 Share Posted August 8, 2008 nah you need to use draino to help flush it out. not the jell kind though. And make sure it soaks for at least a day before you crank it back up Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted August 8, 2008 Share Posted August 8, 2008 oh ok, thanks, lol Quote Link to comment Share on other sites More sharing options...
CantZme Posted August 8, 2008 Share Posted August 8, 2008 i dont think i did this right, my car wont start now. how much draino do I need? Quote Link to comment Share on other sites More sharing options...
Soundmasterg Posted August 8, 2008 Share Posted August 8, 2008 Actually, the best thing to pour into your engine for porting is glue.....something really strong is best. Greg Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted August 8, 2008 Share Posted August 8, 2008 somebody is going to find this later on and think we are some of the stupidest mechanics alive, lol Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted August 8, 2008 Author Share Posted August 8, 2008 Im assuming its lousy humour, if its not........YOUR CORRECT...YOUR NOT ONLY PISS POOR MECHANICS .......YOUR REALLY BAD COMICS Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 9, 2008 Share Posted August 9, 2008 PrOxLaMuS© said: ive always wanted to do DIY porting but I am always afraid of ruining the valve seat Just do a valve job after you finish the port work. I think you'd have to be pretty hamfisted to screw it up so bad the seat needed replacing. If you're just doing the chamber you can put an old valve in to protect the seat. Quote Link to comment Share on other sites More sharing options...
Careless Posted August 9, 2008 Share Posted August 9, 2008 PrOxLaMuS© said: ive always wanted to do DIY porting but I am always afraid of ruining the valve seat so do as jmort said, and do it on a spare head and fix the head up on the side with all the goodies you need. porting takes time and effort, of course you'll screw something up. its the laws of mechanics... if something can go wrong, it will. that's why you do practicing on spares. other than making mistakes and actually doing the work, how else would you learn? Quote Link to comment Share on other sites More sharing options...
Careless Posted August 9, 2008 Share Posted August 9, 2008 im just curious. why do people use super long shanks on their grinders and hold it a mile away? wouldn't it be easier to use a second grinder for close work and a more accurate grinder with less run-out for long-reach stuff. I have a tiny grinder i bought, it is about the size of those aluminum-encased permanent markers with the chiseled tip, and I really don't see why people don't use them? I mean, I ground off some pretty hard welds in a matter of minutes. I'd imagine it can go straight through aluminum if not careful, and it would be a heck of a lot easier to work with if you ask me :-/ Quote The components in these kits are designed for mounting in a die grinder having a maximum speed of 18,000-20,000 rpm and a 1/4-in. diameter collet or "chuck." Do not use an 1/8-inch collet grinder of the type used in hobby or arts and crafts work.Why not? I bet I can even modify my 1/8th collect grinder to work with this kit rather than modify the bits and compromise the shank strength. And it would have enough power, and enough RPM to maintain a nice steady work-rate. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted August 9, 2008 Share Posted August 9, 2008 They probably got used to using the huge shanks out of not wanting to switch parts out, and if they were to switch maybe they wouldn't be able to feel comfertable doing a port job? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 9, 2008 Share Posted August 9, 2008 Careless said: im just curious. why do people use super long shanks on their grinders and hold it a mile away? wouldn't it be easier to use a second grinder for close work and a more accurate grinder with less run-out for long-reach stuff. I have a tiny grinder i bought, it is about the size of those aluminum-encased permanent markers with the chiseled tip, and I really don't see why people don't use them? I mean, I ground off some pretty hard welds in a matter of minutes. I'd imagine it can go straight through aluminum if not careful, and it would be a heck of a lot easier to work with if you ask me :-/ Why not? I bet I can even modify my 1/8th collect grinder to work with this kit rather than modify the bits and compromise the shank strength. And it would have enough power, and enough RPM to maintain a nice steady work-rate. They use long shanks because you need them to get to the deepest part of the port. They hold them at the back because that's where the trigger is if they're air tools. I always use both hands so I can get better control and get a hand closer to the collet. Forget about porting with a dremel. It might work for some of the chamber work, but it would take forever and a day to port the whole runner that way. A 1/4" air or electric die grinder is the way to go. Try it out and you'll quickly see why. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted August 9, 2008 Share Posted August 9, 2008 Heh, my roomate has spend about a week and a half of evenings working on his v6 heads. It indeed goes VERY slowly with a dremel. He still has the intake manifold and supercharger housing to do... heh. Quote Link to comment Share on other sites More sharing options...
