Guest Rolling Parts Posted July 29, 2009 Share Posted July 29, 2009 Here is a picture of the piston set BEFORE re installation into the block: Here is the problem assembly (swapped into #1 hole as sugeested by jt1) where the problem followed the assembly and not the crank location. Since a penny is about 1.5mm then I was guessing that it's about 2mm "short" after installation: Here is a picture from slightly askew to see the curvature a bit better than straight on: Here is a picture of the problem assembly (left) beside the "spare" rod (right) that I will be harvesting from a long forgotten short block I had stuffed under another workbench: Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 29, 2009 Share Posted July 29, 2009 Oh wow, no mistaking that once you are looking for it! Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 29, 2009 Share Posted July 29, 2009 Guys: Glad to see you had a rod problem, but it definitely wasn't because of a 240 rod - it's LONGER than the 280... Quote Link to comment Share on other sites More sharing options...
Tony D Posted July 29, 2009 Share Posted July 29, 2009 No photos for me... >:^( Damn computer. I'll look on my kids with the new big LCD screen, he's hardwired to the router and not experiencing the issues I have of late on the work laptop... Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 30, 2009 Share Posted July 30, 2009 None for me either. Quote Link to comment Share on other sites More sharing options...
kolonelklink87 Posted July 30, 2009 Share Posted July 30, 2009 nor me. *tear* Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted July 30, 2009 Share Posted July 30, 2009 no pics Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted July 30, 2009 Share Posted July 30, 2009 None here either Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted July 30, 2009 Share Posted July 30, 2009 are there supposed to be pics? can't see any here either Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 31, 2009 Share Posted July 31, 2009 Hmm, I sure can. Quote Link to comment Share on other sites More sharing options...
cockerstar Posted July 31, 2009 Share Posted July 31, 2009 You're crazy Drax! I've got nothin' on my end Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 31, 2009 Share Posted July 31, 2009 Rolling Parts said: How about now? Quote Link to comment Share on other sites More sharing options...
rags Posted July 31, 2009 Share Posted July 31, 2009 Nope. Still nothing. Quote Link to comment Share on other sites More sharing options...
woldson Posted July 31, 2009 Share Posted July 31, 2009 If I close my eyes, it magiclly appears! Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted July 31, 2009 Share Posted July 31, 2009 It's also magically delicious. Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted August 1, 2009 Share Posted August 1, 2009 Drax240z said: How about now? Nope. Maybe DL it an rehost? Quote Link to comment Share on other sites More sharing options...
batou Posted August 3, 2009 Share Posted August 3, 2009 email them to batou1 at gmail dot com and ill host em for you. Quote Link to comment Share on other sites More sharing options...
(goldfish) Posted August 3, 2009 Share Posted August 3, 2009 mo pics here, strange as they are hosted on hybrid. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 3, 2009 Share Posted August 3, 2009 I've seen a L6 engine where the #1 cylinder had a piston with a higher pin then the other five but that was a cheater ITS engine designed to fool the SCCA "whistle" compression check. L28 crank in a L24 block. Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted August 3, 2009 Share Posted August 3, 2009 That is funny....I've heard of that too. What's amazing is those cheater engines ran fine with an obvious difference in compression in one cylinder. It kind of makes you wonder why you would spend the time CC'ing combustion chambers after seeing that. Quote Link to comment Share on other sites More sharing options...
