Post pics of your z's here!!
terrorizer805
Put myself through some painstaking work by painting the car myself in my own garage :). So if transformed from pretty worn black matte to a fairly shiny white, it will though need a proper water sanding + polishing to get shiny all around.
And there is still a loooong list of minor to-do´s but I´m slowly getting where I want the car (albeit I had visioned it in a Porsche Signal Orange :))
11225111_10153004761560878_4625784834393
10535006_10153004761820878_2648423686316
11698961_10153004761910878_5894938466763
11722482_10153004762170878_4868320084586
11411603_10153004762240878_1116401477931
11722370_10153004762305878_5368443421175
11703249_10153004762480878_7113081274322
11016961_10153004762635878_1992428176258
Well, thats another little bit done now, coil overs are next, if you guys caught my thread in the suspension area. But my list of things I want to do is getting bigger and bigger.
I've had an account for awhile(just over 2 years now) to read up on things.
I finally found a Z I wanted about a month ago, and I picked it up a week ago near Richmond, Virginia.  I then drove it home to Minnesota.
The SBC had a couple of oil leaks I took care of plus one more I've not gotten to yet.  It starts/runs/drives great.
http://imgur.com/a/ic8Bx
Pretty sure I've already put more miles on it than it has otherwise seen since at least the 90's.  The tires it came with were from 1992 and still had the nubs from when they were made.  With the shape everything is in and the way the numbers are lined up on the odometer, I think the 71k might be the first time around.
Planning on trying out that 8.8 IRS bolt in swap+updating the front suspension this winter along with adding flares.  Gauges will be swapped out for autometer ones in the next couple weeks.  Might get rid of the OEM bumpers for something more like the 240z ones, fiberglass or otherwise.
It came with the original book, window sticker, toolkit, jack, radio book and wheel chocks.
Originally when I was looking for a Z I wanted a semi beater one as I was going to tin-can and backhalf the thing anyway.  This one I'll feel bad about cutting the fenders to add flares.
Edited by bramagedained
  On 7/8/2015 at 11:23 PM, LanceVance said:
It's already got an engine swap, no point being sentimental now!
Gotta disagree with you there. The bodywork on that car looks immaculate, and it looks very clean and understated. I personally wouldn't touch it, not even the bumpers. I think it's perfect as it sits.
