Zmanco Posted January 30, 2010 Share Posted January 30, 2010 I can't tell if the timing light is firing in the video. Was it flashing at all? If so, then try it with the pickup on sparkplug #1 and see if your timing is set right somewhere around 10 degree advance. If it's not firing, then it may very well be the coil driver in MS. Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 30, 2010 Share Posted January 30, 2010 You telling me you can't see that nylon screw head is melted on the VB921? That thing got hot. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted January 30, 2010 Author Share Posted January 30, 2010 So may we conclude that my VB921 is fried, and that it is safe to assume that is my problem? Quote Link to comment Share on other sites More sharing options...
Zmanco Posted January 30, 2010 Share Posted January 30, 2010 There's no need to assume anything right now - install the new driver and see how it goes. Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 30, 2010 Share Posted January 30, 2010 Yep, I would say so. Quote Link to comment Share on other sites More sharing options...
jacob80 Posted January 30, 2010 Author Share Posted January 30, 2010 Okay, well, we'll see what happens. I'll let you guys know what happens when I put it in. I appreciate all your help. Obviously, if it wasn't for you guys, I would not have been able to figure this one out. Thank you Quote Link to comment Share on other sites More sharing options...
Flexicoker Posted January 30, 2010 Share Posted January 30, 2010 http://www.diyautotune.com/catalog/bosch-bip373-coil-driver-mod-kit-p-230.html Quote Link to comment Share on other sites More sharing options...
jacob80 Posted February 2, 2010 Author Share Posted February 2, 2010 Great news guys, IT RUNS!!!!!! I couldn't be more excited, this issue has had me baffled until you guys stepped in and gave your time and effort voluntarily to help me figure it out, and I thank you so much. Here are some pictures and videos Quote Link to comment Share on other sites More sharing options...
naviathan Posted February 2, 2010 Share Posted February 2, 2010 Awesome, congrats! This is what the forums are here for, helping keep Zs on the road. If you found our services useful or at least entertaining, please make a donation to....wait never mind.... Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted February 2, 2010 Share Posted February 2, 2010 Great news!! Now get off your computer and go drive it Quote Link to comment Share on other sites More sharing options...
Zmanco Posted February 2, 2010 Share Posted February 2, 2010 And now the tuning fun begins! Quote Link to comment Share on other sites More sharing options...
jacob80 Posted February 2, 2010 Author Share Posted February 2, 2010 I know! This damn snow needs to melt fast! Now to figure out tuning from here. On top of all this, I just installed a new oil pan gasket and head gasket no leaks! Everything is going perfect right now Now, I just have to figure out the tuning part of it Quote Link to comment Share on other sites More sharing options...
mobythevan Posted February 2, 2010 Share Posted February 2, 2010 Good to hear. Now whats the next upgrade? Quote Link to comment Share on other sites More sharing options...
jacob80 Posted February 2, 2010 Author Share Posted February 2, 2010 A clutch that will actually hold! We put in a spec stage two which won't hold any kind of load under boost too much power! He he actually the next thing are floors. Thanks again fellas! Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted February 4, 2010 Share Posted February 4, 2010 jacob80 said: Here are photos of my board, doesn't appear that anything is fried, does it?? The melted screw on the VB921 is a classic sign you've overheated the VB921 and made it burn out. You'll like the new BIP373; it's nearly impossible to burn one out even if you try. (And I tried a lot of things before we brought them to market, believe me!) Quote Link to comment Share on other sites More sharing options...
BLOZ UP Posted February 4, 2010 Share Posted February 4, 2010 You think that's burned out? I should show you my old MS v2.2 board... Quote Link to comment Share on other sites More sharing options...
naviathan Posted February 4, 2010 Share Posted February 4, 2010 BLOZ UP said: You think that's burned out? I should show you my old MS v2.2 board... I burned one of mine once. Actually cracked the transistor. Same reason too. I had the dwell set too high, then it stopped running and would fire intermittently like the video. Quote Link to comment Share on other sites More sharing options...
rvannly Posted February 23, 2010 Share Posted February 23, 2010 I'm assuming the VB's burned out because of the dwell settings. Will it be ok to run the same settings, that made the VB's burn out, with the Bip3373? Quote Link to comment Share on other sites More sharing options...
Zmanco Posted February 23, 2010 Share Posted February 23, 2010 Why would you want to run those longer dwell times? With a street coil you'll just generate more heat in it without much more spark. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 23, 2010 Share Posted February 23, 2010 On 2/23/2010 at 3:50 AM, rvannly said: I'm assuming the VB's burned out because of the dwell settings. Will it be ok to run the same settings, that made the VB's burn out, with the Bip3373? No point. Optimize the dwell and keep the heat out of your driver and your insulation. Quote Link to comment Share on other sites More sharing options...
