- Yesterday
Through bolting the sway bar is definitely a good idea. On mine, I ran a thin wall tubes through the holes in frame rail and welded them at the holes in the frame. The tubes allow me to fully torque the sway bar bolts without crushing the frame rails. -
I always thought an S2000 would be fun to own
New turbo cam from Steve Bonk arrived this weekend! Excited to see how it changes the responsiveness on the turbo and hopefully I'll get much earlier spool and more pleasant street driving. I've started disassembling for the installation and checked everything. It looks like previous builder used different lash pad sizes for intake and exhaust, which wouldn't seem that odd on a "proprietary" grind, except every one of the shorter pad sizes had the wipe pattern pretty far to the pivot side of the rocker arms and the taller ones were nearly perfectly centered. I know the one time I did a valve adjustment a while back wasn't perfect with my limited experience, but I find it hard to believe I'd be that far off with how paranoid I was about using the right feeler gauge for intake and exhaust. One of the intake rockers and the lobe it was on were fairly damaged but everything else looks good. Got some advice from Steve on the lash pad sizing based on my current specs. I'll be ordering new pads tomorrow and hopefully two new rockers to replaced the damaged ones I found. Also ordered some new valve stem seals. Figured now was the best time. -
5 cylinder GM ATLAS 3700 build with 4L60e transmission
A to Z replied to A to Z's topic in Other Engines
10-04-2026. I took some time today, and went ahead and removed the wiring harness, the intake manifold and some other parts bolted to the block. The stuff still attached, all the bolts are now broken loose and will be easy to deal with as we go. The parts I removed either got tossed, or put into a pile.....I then cleaned them up and took a couple quick pics. Engine looks a lot smaller once you get all the "junk" off! PICS -
10-04-2026 ATLAS Z UPDATE: Well, I found out the hard way that my water methanol container had a crack in it. I ended up having to get a replacement container and a new braided line from it to the pump. I smothered the thread in pipe dope and assembled it. Then I got the whole deal back together. After that I began the install of a gas vapor filter, I went with the 8 inch long version. Just need some hose and that will be done. I spent the rest of the day on other projects. PICS.
A little progress this weekend. Painted the engine cradle and started making some brackets for the front sway bar. Going to mount the sway bar mounts by through bolting through the frame. Someone had already done that, but bolt holes were all wonky and not vertical, so made new holes and going to weld some plates for extra support. Going to use the angle iron as part of my radiator mount, and will also support sway bar bolts. - Last week
Best ways to prevent chassis /frame warping
primaz replied to Joe0690's topic in Brakes, Wheels, Suspension and Chassis
The ones from Cap Metal Works look like they are only the bottom rails. To me what I did which is much stronger as it uses that "U" channel on the bottom and the same "U" channel inside the car to create a fully boxed frame rail and the thickness of the "U" rail is very heavy duty. I am sure those do help but if you create a fully boxed version then it really is as s strong as a full cage for chassis rigidity. -
I went ahead and worked on the 3700 today. I removed the balance shafts, and used the Badlands Industries delete kit. I then cleaned up and re-sealed the rear plate, installed the flex plate with a few bolts in case I want to do a compression test later, and then got it on the engine stand. Int he pics you will see the 4 speed automatic trans for it, a lockup unit GM "4L60e", that I will rebuild with all the tough parts and probably a 3000 RPM stall, unsure at this point. PICS: -
A week or two ago, I began an engine and transmission project, thinking there may yet be another rip snorter in my future. Maybe a B210 or maybe a Roadster? I bought a ATLAS 5 cylinder engine, it's a 3.7, or 3700 cc inline 5. lengthwise about the same as a 2000 roadster engine, but yes it is taller. Like my 4200 it is all aluminum, 4 valves per cylinder, dohc, with VVTi on the exhaust cam. I additionally got a 4 speed automatic for it, a GM "4L60e", that is a lock up setup, where there isn't a lot of slush and stuff. I have already gotten some parts for the 3700, and I will post updates on here.
Zetsaz replied to Joe0690's topic in Brakes, Wheels, Suspension and Chassis
For a street Z I think most people have found exactly this to be a great solution, but I'll add that the full length frame rails from Cap Metal Works are probably plenty thick to do the job. T3 and others sell them, but T3 asked for their own lighter version that's a thinner gauge. I'm thinking of them and some KF Vintage floor pans. I wish that stuff had been available before I painted. When I was putting my car together I was dumping money at so many things that I just accepted the flat sheet metal pans and so-so rails the past owner had welded in as "good enough" but it definitely contributes to the flimsy feeling on turns. -
Larry Chen interviews the owner of the Sema Show Aluminum 240z
calZ replied to toolman's topic in Body Kits & Paint
Jesse is great to deal with. I second Duffy's recommendation. -
DuffyMahoney replied to toolman's topic in Body Kits & Paint
Cool! -
primaz replied to toolman's topic in Body Kits & Paint
Thanks, I did get this reply directly from Star Road, so it does not appear they are ready to sell them yet but hopefully by the end of the year? We apologize for the delay. The number of parts to be manufactured has increased beyond our initial plans; we are currently producing the final components—specifically the front apron panel, rear apron panel, and side sills. We expect to complete them before the end of the year and will determine the pricing after displaying them at the Tokyo Auto Salon. ********************* 有限会社スターロード 井上 〒133−0051 東京都江戸川区北小岩8−23−1 TEL:03-5668-5675 FAX03-5668-5676 mail:info@starroad.co.jp http://www.starroad.co.jp -
Use a liason. I have bought direct from star road through Jesse. Also it's normally cheaper to do it this way. https://jessestreeter.com/ -
The Star Road website will not accept my email inquiry as all name, email, and messages have to be in "katakana" characters, meaning Japanese. I sent a message to their Instagram and Facebook and will see if I get a reply. Otherwise it seems I would need to write and speak in Japanese just to talk to them.... -
I will look to see if there is any direct contact but when I last looked their only US distributor gave me this reply, "Still no updates from Star Road on cost or delivery. Thank you, Shipping department " We appreciate your business and hope to continue serving you in the future! Disclaimer: If you are not 100% satisfied with the item(s) you received, please return it within 14 days of when you originally received your order. To be eligible for a return, your item must be in the same condition that you received - no signs of wear, scratches, or usage and in the original packaging. Jdm-car-parts.com offer items shipped free to you, but in case there's a return, you will be responsible for the cost of shipping the item back to us. If a full refund is requested, we will promptly refund the purchase price, excluding the original shipping and any applicable credit card fees. There are no refunds on items damaged in shipping. You must file a claim with the carrier. We cannot guarantee that we will receive your returned item - you are responsible for the item until it reaches us. When shipping a return, consider tracking and insuring your package. Please allow 1-2 weeks for returns to be processed. All return NOS items are subject to at least a 25% restocking fee. All NOS electric parts-sales are final. NO RETURN, NO EXCEPTION. ******************************************* jdm-car-parts.com 22626 Normandie Ave. Suite E Torrance, CA 90502 USA No walk-in store front available at this time. Tech Support: 310-308-8986 (This is NOT an order line) ******************************************* -
Just contact them directly. Use a liason, they will sell them to you. -
Unfortunately Star Road the North American firm that reps it still does not offer them; I have asked several times as I would be willing to purchase the doors and cowl. -
I have several 240Z's. On one I did a 9 point cage consisting of a custom hoop with diagonal bar to the front passenger area near the tunnel with bracing on the rear towers and bracing for the front towers. Then on my other more mild 240Z I did a heavy gauge "U" channel frame rails under and inside the car covering the factory fake rails that went to the rear towers and all the way to the front of the car. What was amazing was that my mild 240Z solved the chassis twisting and was stiffer that my 9 point cage 240Z. I also had a rear end crash where I was fully stopped and a Prius hit my mild Z at 60 mph and only the rear end had damage, the car from the rear struts to the front were totally fine and so was I! That saved my life and the car was fixed with no issues. I also love that you have to be a real Z geek to even know it is not stock as the rails are just a little taller than the stock rails that they cover up so it looks like the car came that way from factory. Thus I would say frame rails but NOT the ones available at all of the companies I have seen as they are not that thick. The ones I used were strong enough where just one "U" channel not in the car would not bend even when you stand on it. Also my mild Z with the rails was stiff enough that you could jack the car and have 3 wheels off the ground so it was way better than the cage. I am adding that same "U" channels to my more extreme 240Z with the 9 point as I am installing a 750-900 HP RB30 turbo and the car will be a reliable 200 + mph 240Z. -
Looking for fuel sender or tank VTS
darom replied to InlandZ's topic in S30 Series - 240z, 260z, 280z
Hi, I have a used 1976 fuel tank for sale: https://www.classiczcars.com/forums/topic/70030-280z-1976-parts-darom-part-2/#comment-685946 Would it work for you? The tank will need to be cleaned up by a radiator shop. Regards, Den
Who's Online 0 Members, 0 Anonymous, 575 Guests (See full list)
