- Past hour
I spend the last few days cleaning the electrical connections and timing the ignition again as it was out of spec. The car runs way better but the AFR gauge still shows 11,5 at idle. I'd like to bring that down (or up depending how you look at it) to 14,7 as the car stinks of gas. The previous owner mentioned that that was the reason it didn't pass inspection (auction company didn't mention that). I tried messing with the idle air mixture screw but that didn't help. When turning clockwise a bunch the car did start to run richer but when turning anti clockwise it didn't get past 11,5 AFR. I did notice the ignition coil is a 1,5 ohm unit with a total resistance of 2 ohm with the external resistor. I believe it needs to be closer to 1 ohm total so I'll probably replace the coil with a 0,5 ohm one. -
Mitchel0407 started following '77 280z running rich at idle
- Today
The Follow Up Road Test went fine. There was no CV Axle Grease leak and the Diffferential performed well. The Differential Gear Ratio was now 3:55 compared to the old r200 3:70 so my shift points were now more spread out. I think that 3:55 gear ratio for city driving by providing less gear shifting. Highway driving was better by running at less RPMs too. The Blue Angels-the Navy Stunt F16 planes were coming to participate in an Air Show at Kaneohe Marine Base. There also had a Car Show along with the Two Day Air Show. Although, the show was on the other side of my island , I decided to enter my 240z in the Car Show. The trip would take about one Hour but most of it was on freeway roads. The Freeway would take me over the mountain to the other side of my island. On the downward leg of the trip, I noticed that a lot of pedal effort was necessary to slow down, My conclusion was that a Bigger Brake Power booster would be needed. The OEM Brake Booster was 7" booster so the next size booster would be 1978 280z booster which is 8 !/2". The local auto places did not have a 280Z booster available so I ordered one from Z Depot. Next-Upgrading the Brake Power Booster with a 78 280Z Unit - Yesterday
Hi mate, Low profile alloy air cleaner top with a carbon fibre air cleaner with the collection point in front of the radiator. Flexible rubber joiner between the alloy top hat and the carbon fibre air cleaner. The alloy piece is only about 2.5 inches high. Just another idea for cold air induction. Regards David.
Was looking for an old post from you because of the Panasport wheels you had and remembered this great thread. Any good progress since last year?
Got rotors and calipers on. A few minor challenges making it fit for the 240Z, but very happy how it came out. -
Adam Sylvester at Datsun Rescue or Jenny at Junkyard Jenny's.
Ok, so update....thanks to those who warned me about these Edelbrock foam air cleaners. I started reading, one back fire and they will catch fire and turn into goo and run down into your carb/TBI !!!!! oh no! So, i looked online, because this filter was also hitting my hood. I found this company: Pro Series Screens - Intensity Racing Products I bought the mesh screen to work on my carb mouth. So glad you guys said something. WHEW! see pic, I got the low profile with the single hole.. 98 bucks....115 shipped. Saved my life.
- Last week
2jz gte ecu?? Continuity across crank and ground?
sharkys280 replied to sharkys280's topic in Toyota L6 Forum
Continuity was from the ecu to the plug that connects at the sensor, when the ecu was plugged into the harness. When the ecu was unplugged there was no continuity from the plug end at the ecu, to the plug end at the sensor. That led me to think the ecu was shorting to ground inside the ecu. I'll check out the video and test out the crank sensor, and its gap. I'm assuming their ok, as i am using a new crank gear, new crank sensor and new oil pump...but I know assuming is a dangerous game so I'll test it. Thanks for the link! -
NewZed replied to sharkys280's topic in Toyota L6 Forum
Barely know what you're working with but I did find a crankshaft position sensor online for the 2jz and see that it's a two wire unit. That means it's a variable reluctor system. There will be continuity across those two pins in the sensor harness to the sensor. There should be a resistance of a few hundred ohms, typically. It's not clear what you mean when you say you measured with the plug connected and got continuity. Can't tell which side of the plug you're measuring, to the sensor or to the ECU. Anyway, the signal to the ECU is generated when the metal teeth of the trigger wheel pass by the sensor. The sensor has to be within a certain distance from the sensor, that's very important. There's spec but it's usually a few thousandths. Pretty close. The basic testing is to measure resistance across the two pins to be sure the coil is intact and will work. Then set the air gap. Then test that a signal is being generated. https://www.jdmgarageuk.com/90919-05037.html Here's a pretty good video about the basics. . -
I'm a bit stuck and not sure the best direction to move with my swap, hoping someone can help me figure out where my problem is. I've got a 2jz ge that im swapping into a 280z, im going the nat route with an aristo gte ecu. I reworked the wire harness and got the the point of startup, but it only cranks and doesn't fire. I wired a check engine light and got a "1..2.." code. So I checked the crank position plug and was getting continuity from the two terminals on the plug. Thought maybe I wired it wrong, so unplugged the ecu and checked the plug again, no continuity. Then I checked the ecu and was getting continuity with pin 4, 5, 6 and 7. 4 is a ground, 5,6 are cam position, and 7 is crank. So I thought maybe the capacitor that sits on those pins was bad, went to an electronics store that gave me a capacitor that "should" work, then had a place remove the old and put in the new. After all that, Im still in the same place as I started. Crank, no fire, code "12". Any thoughts as to a next step, other than another ecu (which i did but on ebay, waiting for it to show)? Any help would be awesome!
Hello everyone, maybe somebody can help me. My 1977 280z is running rich at idle and the idle mixture on the AFM doesn't seem to help. I spend the last few days cleaning the electrical connections and timing the ignition again as it was out of spec. The car runs way better but the AFR gauge still shows 11,5 at idle. I'd like to bring that down (or up depending how you look at it) to 14,7 as the car stinks of gas. The previous owner mentioned that that was the reason it didn't pass inspection (auction company didn't mention that). I tried messing with the idle air mixture screw but that didn't help. When turning clockwise a bunch the car did start to run richer but when turning anti clockwise it didn't get past 11,5 AFR. Does anybody have any tips or things I should look at? The AFR does seem to be working alright as far as I can tell. I did notice the ignition coil is a 1,5 ohm unit with a total resistance of 2 ohm with the external resistor. I believe it needs to be closer to 1 ohm total so I'll probably replace the coil.
I disconnected my throttle cable and lubed it up, now it moves freely with no drag, in doing so, I re-arranged some of the items attached to the carb thus cleaning it up. A short amount of time to work on stuff today and I'm happy I was able to get it done. Also was able to tighten the spring for the secondary butterflies which is basically required to keep them working right. My thermostat probe adapter that goes into the top radiator hose also arrived and snapped a few pics.
IMSA GTU vintage racer build
Its already fixed. I have these unusual gnose wide body panels i think are fairly aero efficient. So really the only decisions are if I want to run a cowl induction hood vs. standard no vents. And tall rear 7" spoiler vs whale tail. Input is welcome. Leaning standard hood and big spoiler. Working on mounting these NOW. -
EastWaZ joined the community
1978 Datsun 280Z RB25 Restomod
EastWaZ replied to Jethoncho's topic in S30 Series - 240z, 260z, 280z
any updates? Would love to see where this went. -
I was over in Orlando today for work and found a Z shop and picked up a used rear diff and axel. Was supposed to be 2 axels, but they stripped one getting it off an old Z. I’ll probably get the other one off eBay. I’ll be sending the diff to Z1 and getting it rebuilt with a wavetrac lsd and some new gears. -
280Z2J started following 280z RH door down stopper
part number 80581-E4100 looking for a good little plastic block assembly that the RH door dovetail slides on when closing the door. Cant find any new ones
@jhm. I appreciate that, Ive been putting out feelers on a few Z car forums trying to locate one, I know its sort of an obscure and delicate piece but its worth a shot anyway
@GavinG, if you don't find one here; I would also check on ClassicZCars: https://www.classiczcars.com/
Agreed! It's looking great....can't wait to see what kind of wild bodywork you have planned for it.
GavinG joined the community
Im also looking for one!! if either of you guys know of where I can find one please let me know. Mine was broken before I even pulled the distributor out
Who's Online 3 Members, 0 Anonymous, 193 Guests (See full list)
