    33351
    5167
    HideKuro
    HideKuro
  1. Today
  2. 06-18-2026 ATLAS Z UPDATE: Well, after having people tell me about the intake and issues I will have with the MAF meter, and then researching on it, I decided to just redo the intake from the MAF sensor forward. I ordered some 4" pipe, a coupling and clamps and dug in. I did a layout and then cut the hood to start the process of making additional room for a smooth long radius 90 in 4" along with a vortex air cleaner to give the MAF Meter what it needs. In just a couple hours tonight I got a good start on it.....but I will have to do a notch in the radiator support to get the pipe to where it isn't being forced up over it. I am still waiting on the Air cleaner, but the job is well under way PICS:
  3. Yesterday
  4. I would like to get a gas lid for my GTO and wondered what size to use on the rear quarter panel. Doesn't look like anyones been here in a while. thanks
  5. Thx for the comments. I have tested the switch and harness connection points and all is working as it should from what I can tell. I did install the honda wiper motor swap with relay so that might be causing part of the issue. However, the fact that the blue line goes to 12V when the button is pushed is still an enigma. I believe the wire should connect somewhere but it is not clear on my harness. I have replaced both the dash (used in great condition) and engine (new) harnesses along with the fuse panel to blade type so it could be a mismatch of parts that is creating the issue. For now, I intend to run the blue wire directly to the washer motor so I will at least have washer capability even if I have to manually activate the wipers.
  6. Last week
  7. The "rumor" about Silvermine comes straight from the Z Power Steering site, but it isn't necessarily wrong. I believe Silvermine uses an EZ-Steer kit to make their units. Those are designed for ATVs that weigh more than most Zs and experience a lot rougher roads than a car does. They likely don't have the factor of safety of an OEM automotive unit like the ZPS, but it's up to you if that matters. I have seen multiple people who run the Silvermine kit on track and have never seen a complaint, and the EZ-steer kits get used on street rods a lot. If there were an issue with the SM units, I would have expected to see some firsthand accounts of failure online, but I've never even heard secondhand of one having issues. Here's a discussion we had years ago about delay with these units. Interestingly, the only complaints were about force-sensing units. The GPS is also only necessary if your car is stock without an electronic speed signal. I'm not sure how your car is setup, but with a VSS signal, there would be no chance for lag. If you have an aftermarket ECU, you could even setup a custom assist curve if you wanted.
  8. It’s an 8 groove, I got the pulley kit from CVF. I would think a standard rotation wp would be more common for the SN95, I mean a lot of people mod and race it 🤷‍♂️
  9. Anyone wanting free FSM downloads for their S30, they're available free for all production years at: https://www.xenonzcar.com/s30/fsm.php This website also carries good reference data for other-year Z cars. @FJOVA, I took a quick look at the Body Electrical sections for several years; and could not find a definitive answer to your specific question....sorry. It may be worth posting up on ClassicZCars.com, as they have a big following of folks doing original restorations. Good luck with the rest of the project!! 👍
  10. Is that a 6 groove or 8 groove serpentine? I wish I could find a forward rotation pump the works with the SN95 Timing Chain cover. That would simplify the belt routing. I would love to lose the upper pulley/tensioner on my set-up. I'm always happy to simplify and lose weight. I'll reach out to the FlowKooler folks and see if they can provide a forward rotation pump for the SN95 timing chain cover.
  11. I got the correct rotation, just by luck. I bought the water pump last year, before I got the pulley kit, didn’t really understand the difference at the time. Got the belt/pulley kit and since no other accessories, standard rotation was what I needed 😅. 100% of old wiring is gone, using sniper for EFI, got a lights/blinker kit/harness and I’m making/piecing together everything else. I discovered deutsch connectors the other week and bought a kit. These are great for wiring switches and other small wiring. This is a switch for my Wilwood electronic parking brake. I’m not ready to full on wire the car yet, just evaluating what I have and making a big picture plan so when I’m ready it should be a lot easier.
  12. I weighed the Z with the sr20det in it and it came in at 2395. The car has changed significantly since then. I plan to corner weigh the car later this summer. I have a spreadsheet where i track parts i've installed and removed with best guess weights. I believe the car is probably around 2521lbs, give or take. I'm not sure how much my rollbar weighs (i guessed 100lbs). I would like add a full leather interior with lots of sound deadening at some point. I have been eyeing the star road aluminum body panels. My dream is to make this car the Singer of 240z for me.
  13. you ever weighed this? I always thought a Z with a k series would have a great balance.
  14. Some updates. We installed a larger clutch master that was very easy to install. It solved the gear release problem with the cd009. We redid the steering shaft and motor mounts. I didn’t like the way it was installed before. Will know if it’s better in about a week or two. Installed a new Garrett intercooler to replace the eBay special I had. We reduced the intercooler pipe size down to 2.5” to see if it will help with spool. Installing a 14psi spring in the wastegate actuator to help hold boost. Will dyno again soon. We also removed the spacer from the skunk2 intake and modified the entry angle. Replaced all the intercooler pipe couplers with the vibrant hd clamps. The old pipes kept blowing off. installed dapper led seven lights. So much brighter than the halogens I had. We installed the rest of the rear t3 suspension bits. we also installed a new t3 steering rack and crossmember, along with BRE mirrors.
  15. Love the way this is coming out. its been a challenging balance to thread between making everything neat and tidy and making sure I remember its a race car and needs to be functional. decided to polish the intake manifold and turbo, which looks great but upkeep is gonna be a challenge. exhaust is mostly done and welded. need to make a fancy tip for the back. wrapped the downpipe and mid pipe. need to pull the manifold and wrap that too. originally made a open dump wastegate but then changed it up to recirc it because we have a couple tracks with some noise restrictions. I'll order another v band and wastegate outlet so i can cap the exhaust and run it open if the track doesn't have a dB restriction. Fuel system is done. bulkheaded thru the floor. 3d printed some mounts and have it mounted along the floor. injectors are in. got most of the turbo lines made up. opted for the turbosmart oil pressure regulator for the turbo. i've never dealt with a turbo this small and man its a challenge to fit everything. drain is really tight. hits v band and clamp but think i may have the puzzle solved to make it work. fuel fill is welded up. went with stainless to mitigate the risk of corrosion with ethanol.
  16. Do you have a forward rotation water pump? Most are reverse rotation with serpentine belt. If you try to run a reverse rotation pump forward, you won't be circulating water through the engine. Also, I would start fresh with the wiring. Don't try to reuse the original fuse block or any of the under dash wiring.
  17. Sometimes the “original” works the best. Part for these cars are quite expensive and although there is a lot of information out there a lot is still missing or people just haven’t posted online, especially electrical. So please if you find things out that you had a hard time finding information about post it in one of the forums. I had trouble with my AFM (Air \Flow Meter) on my ’77 280z a while back and it was absolutely impossible to find information about the workings of them. Being from Europe also made it pretty hard as everybody just said to go on Ebay or another US supplier and buy a new one, not really an option for me. So I went on a big research spree and with some help of the Australian Z car and Land Rover forums I managed to find a suitable replacement AFM of a 90’s Ford Probe / Mazda 626. These where sold plenty over here and used parts for those are pretty cheap. In the end the 280z just uses a generic Bosch L-Tronic injection system and parts can, for the most part, be interchanged between brands and cars from that same era. I’m even running a few Porsche 944 parts. 🤣
  18. Try and see if you can find a wiring diagram online. Unfortunately I only have one of a 197 280z which I will upload just in case as I suspect not much has been changed regarding something like the washer motor over those years. Try and follow the wiring with a multi meter and see where the power stops once you press the button. Also try and check the fuses, one might be blown or has a bad connection. It might be a stupid tip but try and activate the washer with the ignition switch in different positions. I was once lead down a rabbit hole thinking my blinkers weren’t working while in fact I needed to turn the ignition switch all the way to the on position (accessory position didn’t work). N77ZCAR-WIRING.pdf
  19. 06-14-2026 ATLAS Z UPDATE: I started the day by cutting and prepping a new throttle to be welded up, keeping the angles for leverage, but removing and bends to make it straight. the one I did before did not work. It needs the bends to create leverage, and a spring mounted throttle foot pad to work correctly. the factory one is bent, so pie cuts were used to straighten it, then chopping and shortening it was required. It now heads to Wagner Fabrication to be welded up and then I will paint and install later. Then I Mounted my dual catch cans. I then mounted up my front blinkers and then went back to the catch cans....tying all the lines in, One line is black braided, and as you can see, I masked off a portion of it and painted it with silver engine block paint to help it match the others. Better than not at all! I also wiped down my forward metal dash piece and set it in then and then touched up some fittings in silver to get away from too much black. I then took my blinker surrounds that have been repaired and sitting in primer forever and sanded them up smooth with some 320 grit sandpaper, and painted them with gloss black rustoleum 2X, and then a few coats of Krylon clear. Also of note, I did cut and place a PCV valve in the breather line coming from the intake back to the catch can. So....a lot of little things today, to include tying it all up and cleand up under there. Definite steps forward today! PICS:
  20. Got fluid in and bled the brake lines. Smell leak at the line lock, tightened up and everything looks good. Been playing around with the wiring, seeing what I have and how I’m going to put it all together, got some ABS sheets and going to make up some panels to organize everything. Also got the alternator and bracket on and test fitted the sniper.
  21. Ditto for me....I'm in exactly the same situation as both of y'all; so I'm interested to see what kind of responses there are. One nugget of information I can share is that most of these EPS units are HEAVY; and additional bracing is typically needed on the stock steering column mounts/bracketry.
  22. I don't have experience with the EPS. I am interested. I do autocross with wide tire 275/35-15 on 15x10 wheels on all four corners. While moving, the effort to turn the steering wheel isn't terrible. I try not to turn the wheel while the car isn't moving because I feel that I might over stress the steering rack. The 280Z has a slower rack than the 240Z. For autocross, I would swap to am240Z rack. I measured the difference between the racks in a thread several years ago. Going from memory, the 280Z rack moves 1.59 inches per revolution of the steering wheel, and the 240Z rack moves 1.81 inches per revolution of the steering wheel. The faster rack would benefit more from the power steering, but is usable without as long as the vehicle is moving.
  23. Hey guys, looking for some honest feedback from anyone running an aftermarket electric power steering (EPS) kit on an S30. I have a 1976 280Z that I’m trying to figure out a solution for, which I used to daily drive, but I stopped once I put on quick-steer knuckles and wider track tires. The manual steering with these mods is just too heavy and lacks the precision and fine adjustment I'd like for the track. My goal is to add a US-available EPS kit so I can comfortably daily the car again, while still using it for 50% track and autocross duty. I’ve been looking at the main options available here in the US, but I can't decide which route to go: Option 1: Manual Dial / Potentiometer (Z Power Steering) This appears to use a knob under the dash to manually set a fixed level of assist. My worry here is the highway drive. S30s already get naturally light in the front end at speed. If I leave the manual dial turned up enough for local driving, is the highway cruise going to feel twitchy and annoying? Am I going to get completely annoyed having to constantly fiddle with a knob between street driving and autocross runs? Option 2: Automatic / GPS Speed-Sensitive (SilverMine Motors) This appears to use a GPS antenna to automatically give max assist at a standstill and taper it down assist at highway speeds. My big concern here is track reliability and lag. When you slam on the brakes right before a tight autocross hairpin, does the GPS signal lag keep the steering heavy, or does it suddenly surge and go super light mid-corner? I am also specifically looking for feedback from anyone with personal experience regarding the motor they use. There's a rumor floating around online that the SilverMine setup is actually using a cheap, under-powered electric steering motor designed for ATVs rather than a true automotive passenger car core. Is there any truth to that, or is it a solid automotive unit capable of handling track abuse? Newer Options: If anyone knows of any newer, more modern US-based EPS options on the market that I should look at instead, please let me know. If you are running any of these setups on a track or daily driver, what has your personal experience been? With my steering geometry, should I go manual dial or GPS auto-adjust? Appreciate any insights or warnings!
  24. 06-13-2026 ATLAS Z UPDATE. Today I finished screwing down the carbon fiber and installed the front flares. Pretty much all done. Later I will tape off both sides of each edge and lay in a coat of black pure silicone....then pull the tape off leaving straight lines and let it harden up. Then some paint correction and some clear and the body will be done! I gathered up some parts I am taking to get wrapped in dry carbon fiber (front bumper, cowl, and rear spoiler). PICS:
  25. The factory 2006 GM ECU, called a "P12". Jeremy Gonyou at Lime-Swap converted my engine harness into a stand alone setup and cracked my ECU and programmed it for the turbo. By using a factory setup I retain the variable valve timing and the wireless throttle. 60lb/hr Deka fuel injectors and with an 8 psi spring in my external wastegate.....around 350-400 hp at the crank. Very mild setup.........well over 300 at the wheel, which in these cars is sufficient.
  26. PART 16-Work on the Gull Wing Doors finally begin!! After all the reinforcement of the 260 body structure with a huge roll bar cage, the work on the Gull Wing Doors begin. Some people did realize that the Gull Wing Doors required such major structure modifcations. You are practically cuttting the vehicle in Half then installing a full function Gull Wing Door section. But the Time is still ticking away--only a little more than 4 Months away from SEMA SHOW in November. Also, Shipping Time would be about a m might have to Air Freight the 240Z to Las Vegas. As most Sema Show cars, it will a "Wild Race to Finish the Car" with "All Hands on the Deck"!!!
  27. You're probably not far off the mark at that number. Used LSD R180's regularly sell for $700-800; and it seems that R200's long-nose are not so easy to get anymore (IMHO). The real challenge may be finding the buyer that wants the entire lot of parts, especially both diffs. You might have better luck if you're willing to sell pieces individually. (Shipping costs could be a bear...consider looking at discount freight shippers like Blue Lane Freight through Fastenal.) Good luck with it...you've got some nice piece-parts there.
  • Who's Online   0 Members, 0 Anonymous, 491 Guests (See full list)
