- Past hour
240z Barn Find Registration help
jhm replied to Btz white z's topic in S30 Series - 240z, 260z, 280z
Sorry, I misunderstood the question. It's a much easier proposition if you're just looking to flip it, IMHO....particularly if you can attract out-of-state buyers. Every state has their own unique requirements for titling and registration, and prospective buyers will (should) know that going into the deal. You will typically have to sell it "below" market value without a title, so be sure to factor that into your decision on how to proceed. -
Btz white z replied to Btz white z's topic in S30 Series - 240z, 260z, 280z
Just looking to sell it, can I sell it without the title in place for someone's project car or do I need to obtain title for a transfer (is the main question). Thanks! - Today
Ugh...broken bolts in the block. What a pain. At least the motor was already out of the car! 👍 Making great progress -- keep the updates coming!! -
Part 8-The Roll Cage is now installed so the Roof Area is being prepared for the Gull Wing Door Build. A Major Obstacle that I foresee the Transmission Tunnel and Firewall may have to cut open because of the Huge Mercedes Motor and Transmission. But if they are willing to Eliminating the Tunnel and Widening the Firewall Opening, they should not be a Big Problem. -
03-16-2026 ATLAS Z UPDATE: My welder showed up today and welded up my cross bracing and a few spots on the trans tunnel where it touches the firewall. While here, he pushed on the outside of the windshield as I pulled the rope and got the windshield in. Tried to get the hatch window in, but it wasn't wanting to do it. So, I will have someone help me with that rear one later. I went ahead and installed my mesh cover for the turbo.....I had to go down a size to clear the engine. I got started on putting the door frames back in and getting the windows working right, more to do on that. PICS:
- Yesterday
Got timing cover painted. Spent almost half the day dealing with a bolt on the timing cover/water pump that had broken off in the block. Tried all types of extractors, ended up having to drill it out and re-tap it a size bigger. Got the oil pan off and installed new pump and pick up for the new baffled oil pan. Got the main seal on, set the timing cover on and called it a day. -
Congrats...that shell looks pretty dang straight! As much as I hate to admit this, you'll probably get quicker/more responses to that particular question via Social Media. I can recommend some pretty good Z-car pages on FB, if you like. I wouldn't usually recommend FB for technical questions/discussions....but for an administrative question on a re-title, it might yield some good results for you. Again, welcome to the forum; and please keep the updates coming as your project progresses. What are your plans/goals for the car? -
I can do App for Replacement or Transfer of Title with a new registration, looking for other experiences without a bill of sale, plate, registration etc. before walking in there. I did confirm not stolen or salvaged. -
Kennysgreen280zt replied to Btz white z's topic in S30 Series - 240z, 260z, 280z
I'd probably start asking questions at the DOL/DMV. Maybe see if you can figure out who was the last registered owner, or if there is a process to get a lost title/registration. -
Btz white z joined the community
Hello, new user here, I’ve got a 1972 240z barn find, VIN: HLS30-69341, no registration or plates, looking for any interest or suggestions on reregistering non op at the DMV without being the clear owner…will add pics
Progress on my insane VQ35HR 240Z project
G-Tech replied to markrolston@mac.com's topic in Nissan V6 Forum
That has got to be the best balance of Form and Function of a Datsun that i have EVER Seen!! Absolutely amazing!! -
Jboogsthethug replied to markrolston@mac.com's topic in Nissan V6 Forum
Dang, that looks so tight, turned out amazing! So they printed the part but then used that to make a mold I'm guessing? That's not the actual 3D printed part? -
markrolston@mac.com replied to markrolston@mac.com's topic in Nissan V6 Forum
if anyone's still tracking this build I have what might be a last update since the car is mostly done (lol is it ever done?). I finally cad-designed the front fenders and then had a local shop 3D print the parts, then took that to a bodyshop to integrate into the existing fender part and paint it. After that I overlayed the inside walls of it with carbon fiber for added stiffness and protection. I also cut the lower part of the rear fenders and put in a horizontal cf winglet to better extract air. Overall I think it looks great and the resulting new parts helps downforce a ton by extracting air from the wheel wells. - Last week
nathans30 joined the community
Appreciate the suggestion. Will take a look there; although I have to say our "350Z" sub-forum hasn't really seen much activity in the last few years, unfortunately. 🙁
03-14-2026 ATLAS Z UPDATE: Since the intake was off, I went ahead and tackled the project I have been putting off. Modifying the Atlas Industries alternator bracket setup to work on my project. the mounting plate is 1/2" thick, and the alternator just wouldn't clear the frame rail, so after trying to cut the aluminum bracket down, I gave up and traced out the bracket on a piece of 1/4" thick steel and cut it out and drilled the holes out. I then used my Dremel to counter sink the holes so I could use the bolts and everything that came with the kit. I painted the steel bracket with silver engine block paint and the bottom bracket I had to trim 1/4" off of it. Then I was able to install he alternator (brand new AC Delco, nice unit), and then on to the fun part.....belt alignment. Using a straight edge, I had to keep working little by little shaving aluminum off the provided spacer and then lightly grinding the back of the nylon pulley and it turned out great! Then I went ahead and installed the fittings to use a 8AN line for the crankcase breather on the intake between cylinder runners 3 and 4, and I found that by leaving it black it is hidden and you cant see it, so that worked out better than I had planned. once the intake was tightened all down, it was time to finish the intercooler piping. The driver's side was VERY tight. I used two 90 degree sections and trial and error and cutting them down I was able to come up with a decent arrangement. so that piece, to be welded along with a frontal piece to weld a length on to eliminate some couplings were put together and I will take them to get them welded up then take all of the pipes to get powdercoated with the "polished aluminum" finish. I could get them polished.....but it would cost more......opinions? Lastly I put together the intake side, switching to a 4 inch coupling setup with the GM factory style MAF meter. it was 3.75 diameter, so I took some rubber strips that are adhesive on one side and ran a strip of it around the mating surface, and then I was able to tighten the hose perfect on it. I did have to use the 4 inch to 3 inch reducer on the end, as the engine has pieces sticking out that won't allow for 4" pe, etc. I have a 3" screen arriving soon which will be on the front and it should look pretty good. I will have to get inventive to add polished/chromed to it to get rid of too much black. maybe a very thin polished aluminum piece that wraps around it and can be fastened underneath? Anyway, here are some pics:
nixkarz joined the community
03-13-2026 ATLAS Z UPDATE. A week or two ago, I got with Joshua who runs JP fiber shop and advertises on most of the Z car pages a lot. He is located in the Dominican Republic and makes fiberglass and carbon fiber parts. He made my fiberglass smooth cowl piece. He began a project for me. To make a roof, partial quarters, doors and partial front fenders out of carbon fiber, but just a thin sin.....one that could be trimmed and bonded over existing steel. The idea I have is to make it look like a "Paneled" paint job. Since my 260Z is part american hot rod, part street rod, part sports car, and part Japanese classic, I have used ideas from each genre in this build. To achieve the paneled look, I have had John cut-in, 1 inch around the border of each panel, to include the front fender to door gap areas, and these outlines will be in the factory Nissan #305 light metallic blue, as the cut outs for the door handles and locks, parking lights on the front and rear corners, etc will also show the color "underneath". The body line is the cut off point for the side pieces. The front fenders will remain blue on the tops, with a black windshield frame and top, but a fiber panel is also going on the top. The job is almost completed and then he will mail it to me. I will bond it with the SEM 50 second panel bond epoxy. It is a love it or hate it deal. I fully expect most will hate it/think it looks stupid.....so there's no need to tell me, but I know you will. It is unique....the car becomes "art". here are some pics of the process of making hte panels and a few pics of random cars to show the paneled paint jobs that inspired this. I will be adding my gloss black flares OVER the carbon panels and a black roundel on each door with the number 7 cut out. Click below for video: Main Video 1.mp4
Looking for info on a lt4 swap. Any info or pics, builds etc. I'm running apex touring suspension front and back. Will the dry sump oil pan clear etc? What kind of fab work to mount it etc. I've Google my heart out and can't find nothing other than a couple pics of the top view of the ones I've seen
Check this out for chassis stiffening ideas. You're already ahead of the game, going with a full cage. https://imgur.com/a/chassis-stiffening-inspiration-R27sh
Thanks for the reply! Occasional tracking at best, mostly weekend street use, hence saving money with the pro torturing suspension. Roll cage already installed, figured may as well benefit from the stability and a little more weight. Chassis reinforcement is one of my main concerns. Think I need to do a lot more. I’ll def check out VA Engineering, thanks!
seals84 joined the community
What will be the main purpose of the car for you? What do you want the car to be? Seeing as you will be installing a roll gage, iMSA widebody kit and an LS big block for I suspect power and torque, you will mainly track the car and won’t be driving on the road. I like your choice of Apex over T3 but that’s my personal preference. But why the Pro Touring and not the Track Attack kit? Also don’t forget the basics of the build like chassis reinforcement, safety features and fuel delivery. These chassis are over 50 years old so if you plan to track and abuse them make sure the basics are good, rust free and reinforced. A good roll cage will do a lot together with the frame sleeves and some bolt on parts but things like seem welding the chassis will also help a lot. VA Engineering over here in the Netherlands has some great pictures on their Instagram of their cages and seem welds. The transform the S30 Z’s into period correct rally cars and yes they do get used like a rally car should.
churchData2015 joined the community
THANK YOU Sir. I am really enjoying this car.
Hi all! New to the forum. Early stages of my first Z build, hoping to get some feedback before my mistakes get too out of control 🤣. ‘73 240z powder coated chassis with roll cage. Has the frame rail sleeves. Will be doing more reinforcing. L76 6.0. Planning on replacing most everything but the crank. TR6060 and Ford 8.8. Full Apex Touring Pro front and rear. Apex steering rack and axles. Akebono brakes. BRP front sump oil pan. Leaning toward iMSA widebody kit. Corvette accessory setup, vintage A/C and electric steering assist. Want to be open to procharger in the future. Any advice on what I should be looking out for, or changes? Open to anything! Thanks in advance!
- Earlier
Heavyball joined the community
Jumping in here, I am also currently swapping my L28 to front sump and had a few questions. What oil pan are you using? I found a maxima diesel front sump pan. For drilling the dip stick tube, did you go through the oil passage the rear oil pickup uses? I extended the oil pickup tube rather than drilling the front one out, and I'm concerned the dip stick with interfere with the oil flow. Thanks!
Who's Online 2 Members, 0 Anonymous, 966 Guests (See full list)
