Leaderboard
Popular Content
Showing content with the highest reputation on 01/13/19 in all areas
  1. "the nipple won't stop bleeding" doesn't make sense. What do you mean? Maybe you could rephrase the question. It does sound painful though...
    1 point
  2. Got a new batch of flanges all done. Some of the costs went up marginally unfortunately. Now $205 Shipped and request you pay via friends/family to cut down on my fees. Jig rental cost down to $20 from $30 however. Total $225 with Jig rental, plus you ship jig to next user.
    1 point
  3. RE: "Ramps Safer than Jackstands" As someone who has watched stamped-steel ramps rated at 3X the total weight of the vehicle driven upon them spontaneously collapse... "Not on my life ever again!" I will NEVER use a ramp of stamped-steel ever again, as well as those three-legged jack stands that look like they were made from muffler tubing split a 120 degrees. I have a solid wood set of ramps I use, and an injection moulded plastic set that I use. Once the car is up on the ramps SOMETHING blocks it there, and SOMETHING is under the frame. *** As for pulling the pan...it's all above, nothing insurmountable...usually biggest issue is the Nissan Applied gaskets are like a subatomic bond with the block and pan and splitting them apart can be a chore even with a special Nazi-Era Scraper that you can whang in there with a rawhide mallet to separate the surfaces. I tend to spray up into and onto the inner block surfaces with brake cleaner to prevent oil from rolling down into the gasket area while mounting and sealing. I use the brake cleaner into each of the bolt holes to prevent oil up inside from coming out and making a leak path in the sealant. Finally, I use studs on the reassembly, all sunk in and sealed (to prevent the oil path mentioned above.) The use of studs allows me to make them long enough to accommodate 1/2" 'sandwich plates' similar to that used on later L28's and L28ET's to spread the clamping function of the pan bolts (nuts) without deforming the pan rails. They are made from 1/2"x1/8" or strap steel I get at Home Depot's metal rack. I make the rails straight, put the clamping sandwich strips on there, and use Flanged Nuts to squeeze it all together. There are two studs that are longer than the rest situated diagonally opposite corners...I put the pan with sealant on it up until I can get a flange nut started on one, then the one in the back... This lets the pan sit without touching the flanges for a final inspection and maybe alcohol wipe before pushing it up to sealant contact and finger tightening those two nuts. After that, you can quickly do the rest of the nuts. With a piece of 1/2 square keystock set in your vice you can put your pan over it and beat those concave bolt holes down flat again...and using the above clamping sandwich strips with flanged nuts will keep you from ever having to do it again! I also have a bitchen $300+ breakaway torque screwdriver (that someone else paid for) I can use to tighten the bolts exactly where they need to be... I prefer Loctite 598 as sealant alone, or as gasket dressing. If you have a gasket you really need the sandwich strips and a flat flange. With Loctite 598 you can lay your proper bead for sealing, snug the nuts to get initial compression, let it set up overnight/24 hours to cure and then retorque to proper number the next day to get some compression on the 'gasket' you just made with the 598. Loctite 598 and Permatex Ultra Black are EXACTLY the same substance, BOTH made by Henkel and simply marketed in different markets with different brands. This comes straight from Henkel Technical Support Engineering. We use it on our oil sumps which are immersed in hot oil 24/7/365 and rarely are expected to be opened for inspection before 5 years of continuous running. It is more tolerant of surface debris / contamination than prior RTV's. Our testing indicated between metal blocks, a bead will have at least a 40X espansion rate in close fitting pieces...meaning a 2mm bead will spread to 80mm wide EASILY when compressed. A 2mm bead is ALL you need if you have less than 1mm distortion. By putting a 2mm bead on the pan and then tightening to metal-to-metal, the bead will EASILY compress to cover the entire mounting flange area, even in the warped areas...effectively permanently sealing the gaps. *** Even when I don't replace the bolts with studs... those two diagonal studs and flange nuts are installed it helps hold the pan coming off as well! They're like 1" long....I cap them with a piece of vacuum tubing after install so the exposed threads are not gummed up with road grime. If you get realllllly fancy and have longer studs that stick out at least 1/4" beyond the face of the flange nut...those vinyl vacuum caps that are available in Red, Blue, Yellow, Black make for a bitchen detail all around the pan surface as a nice contrast... You know.... "While you're in there..."
    1 point
