Thanks awd, madkaw. 1st start went great last week. She fired up instantly and ran it @ 1500-2000prm for about 20 minutes to break in the cam. Since then, made a few changes to the VE, AE, WUE settings and also ditched the unstable manual BC & enabled the EBC. Ran some data logs and it stays close to the AFR table I've set up, boosting to 15psi. Still a bunch of tuning to do but so far, it seems ok and pulls pretty dang hard without any detonation that I can hear.
True madkaw, it was nerve racking. I did need to make a bunch of changes to the GR tune before 1st start or, it really had no chance at starting. GR had all my motor specs and purchased all the MS components through them, but it almost seems like they left most, if not all of the settings they had for their test motor as the current tune. No big deal since I figured it all out before I turned the key but, worth mentioning if someone else goes down this road. Their assembled unit and wiring harness are very nice which made the install pretty painless.
I also converted from hydro lifters to solid during the MS install and need to do a quick write-up on that at some point. After installing the time-serts and solids, cranked it a bunch without the rockers and the lifter oil ports on the P90A head were moving a lot of oil past the smaller headed solid lifters. Found some copper metric washers to use which sealed the small oil ports almost completely. With the amount of oil getting past the lifters at cranking speed, I wasn't comfortable leaving it like that since I'm sure there would be a lot more blowby at higher RPM's, possibly starving the crank bearings, cam & bearings, etc. Also picked up some .160 lash pads which put the wipe pattern perfect with the Delta regrind. A little to the lifter side which creates a little more lift, which is good.
North-eastern NJ, Morris county madkaw.
Thanks for the replies guys. Now I need to find a Dyno and a tuner in NJ that knows MS because I'm sure I'm leaving a lot on the table since this is the 1st time I'm ever tuning, especially in the ignition table dept. If anyone knows of someone they trust in my area, please let me know.
