Leaderboard
Popular Content
Showing content with the highest reputation on 07/08/25 in all areas
240Z RESTORATION PARTS IN THE USAI I found this video by Larry Chen about the relative new source of 240Z restoration parts. Their inventory covers body parts,interior plastic panels, grills,etc. If any one have tried their parts, please let us know concerning fit,quality,price and customer service. Their Website pic shows a 240z salvage yard so they might also sell used 240z parts. the company name is Resurrected Classics in Auburn, Georgia.1 point
Lots of small fixes the past week: Replaced the glovebox light and made sure it was all working well. Replaced the hatch inner and outer seals. My installation was better, but the Resurrected Classics seal also fit far better, especially the inner. The precision kit felt like it need to be stretched just slightly, but the RC held in place on it's own before adding weatherstrip adhesive and clamping down. The RC seal was pre-cut to provide clearanc for the hinge seals. When I first opened it it seems a bit ugly or poorly done, but after checking fitment it seems to be very well trimmed for correct clearance. Also added new oem style hinge shims when I reinstalled the hatch. The striker on the bottom was adjusted as well. Will need much more work to get the fitment right since the passenger side has a much bigger panel gap despite shoving it over as much as I could, but at least now I can comfortably open and close the hatch without dragging down the seals. Added the rubber stoppers for the door handles to prevent vibration and finally reattached the escutcheon / finisher plastic in the door cups. Looks much tidier and less noisy. Next step here will be to really clean up the door panels from the tiny splatters that I never cleaned from the lizardskin. O2 sensor cable routing was far improved by going through the body harness grommet in the firewall. It's in a safer position away from the driveshaft now. No longer running down the console. Wideband controller grounding was also fixed after I blew a fuse then repeatedly had it blow. Driveshaft was rebalanced. Seems a weight had knocked loose at some point. Was vibrating really horribly on my drive back from SLC with my brother. Replaced the diff pinion seal with a spare I had while the driveshaft was out. New OSG limited slip may not arrive in time for me to rebuild so I wanted to not have that leak in the meantime. Finally added the barb to the turbo intake as a vacuum source for the catch can. Hopefully this resolves any future oil leaking and premature seal and gasket failures. Adjusted the brake pedal travel. The brakes were already a huge upgrade and now it feels even better. Couldn't get it to the FSM's required height, but the suggested pedal height seems excessively tall, so I'll call it good now that the pedal and clutch are even heights and the stoppers are adjusted to make them less noisy. New hardware for the brakes is on the way from T3 and I'm getting some local help to wire up the new electric fans. Futofab HD stub axles arrived yesterday. Very well packaged. The axles should be arriving today, along with the new spare tire from Z Car Garage that will fit in the original spare tire compartment while still working with my new big brakes. More pics and updates to come soon...1 point
Fourth of July 2025 Pearl Harbor Fireworks and Car Show- This Joint Military Forces Fourth of July Celebration was held at Pearl Harbor Naval Base. It consisted of Two County Western Bands , Big Fireworks display and Car Show. There were over Two Thousand People in attendance from 4PM -9Pm. My 240z won 1st Place Trophy in Classic Rod Catalogue, The Event ended with 15 minute Long Fireworks Display over Pearl Harbor. Next- Finishing Details on the 8.8 Conversion1 point
Thanks for the welcome back, this car has certainly had a rollercoaster of a fate over the last 10 or so years of ownership. Excited to build it into the best version of itself (for me). Thanks for the info, seems like Viking is a non-hype brand that offers shocks that do shock things, which I can appreciate. AE is slow on CS communications but that's understandable given the size of their operation. That said, for a ~$9K suspension kit, a bit more transparency and technical detail on their website would go a long way. If I can find a shock with more travel for the same dimensions or when I blow these out I'll swap. JRi's builder series and some of their GM line looks like it would bolt right in, only 0.3" longer extended length which seems negligible in terms of fitment (PN: 100-511-300). I agree, it seems incredibly unwise if that were the case but it wouldn't be the first time I'd seen it. I've seen similar suspension choices in GTAC (cars riding on bump stops) but that's usually done purposefully to keep the aero platform working optimally and not appropriate for a package like this. Considering the shock travel is a mere 3.6", its safe to assume this is an extremely low motion ratio design. It feels like a missed opportunity to fully leverage the bell crank inboard design (traditionally speaking) but perhaps packaging constraints of the S30 chassis left little room for alternatives. I'm hoping the bottoming out feature will be at the upper A-arm which would allow me to mount a 3D printed polyurethane bump stop on top of it. Going to email AE for an update on the wheel rates and now information motion ratios, thanks for the idea.1 point
Good post. I was frustrated for a long time with companies not sharing spring rates on these parts. FWIW, Viking is legit, lots of fast SCCA guys run those things with good results. IF those spring rates were chosen to prevent bottoming out of the shocks, that's pretty poor design. My guess is that the motion ratio of the bellcrank will be the limiting/bottoming out feature here, and that the conversion to pushrods has resulted in some high force multipliers. My guess would be Viking starting point is mounting in a "muscle car" front end, where the motion ratio is fairly low. I'll be interested to hear what the APEX guys say!1 point
Got the front wildwood brakes installed today! A couple small quirks along the way on my install: First side I installed the rotor on the adapter ring to the hub wrong and the caliper didn't line up. It has two separate mating surfaces, one for a 240z and one for the later 280z hubs. Since I've replaced my 280z hubs with the T3 hubs, I failed to realize they're essentially a universal hub for early and late models which is why they had an extra shim ring of about 10mm to account for where the 280z mounting surface is. I took the ring off, so technically I had to install them where the 240z ones are, unless I wanted to run my rotor ring AND the hub spacer shim that they came with. Avoiding too many unnecessary pieces so I redid that side to mount on the 240z mating surface of the adapter and we were fine. Problem 2 - because I ordered the 280z brake kit, the included hardware also assumes you're still using stock 280z hubs. It's on and worked on my short drive, but I noticed in the picture where they're installed that the bolts don't go all the way out to the mating surface for the wheels. Quite a few threads left unengaged. It's probably safe for the time being, since I thought about the forces on those specific bolts and it's not really in or out since they're perpendicular to the rotational force applied by the brakes. I also didn't feel like I had particularly few threads engaged as I was bolting the rotor to the hub. Probably safe for casual driving, but it's a high priority fix right now to get the correct length bolts from T3 or locally. Better safe than sorry! Other than that I'm really happy. Bled the system with my new Motul brake fluid, which should cope much better with the heat off the turbo vs the cheap generic O'Reilly fluid I had before.1 point
