zgeezer
Everything posted by zgeezer
  1. I need one, maybe two, combination switches refurbished. Can you help me locate someone that will do this service? I've read that a Dave Irwin in Washington state will refurbish 240-280Z combination switches. I understand that he has posted here relating to wiring the Honda Civic wiper motor and over at Classic Z under the name similar to Z'SONDABRAIN . I know of a website "Datsun 240Z Upgrade" located at 6421 105th St NE in Marysville, Wa 98270. However no-one responds to emails sent to their website "contact us" address or USPS first class mail to the above address. I would prefer to purchase from someone who supports this site. Any help would be appreciated. z
  2. Back in 2002 a member "Brad" posted CAD or other file type with the dimensions of an aluminum panel to replace the stock plastic inset that contains a courtesy light, heater controls, and center vent. His panel had a number of variations including all gauge, radio, and heater control cutouts. Are there any old timers here that downloaded and buried that file for future reference and would be willing to share it with me. Failing the file, does any one have contacts with "Brad", the original poster. I belief the file contained the following information... logos perhaps. "Omniglass" "Brad" "240z Com". Z
  3. The retaining bolt bore centers for the Ford Windstar straight thermostat cover are very slightly narrower than the late Camaro pump. The solution is to run a 5/16th inch drill down both Ford bores. This opens up the Windstar retaining bolt bores just enough to allow the use of a stock GM 10mm thermostat cover bolts. The Ford thermostat appears to fit nicely. The Ford Windstar thermostat cover is a $9:00 item. An aftermarket GM straight cover will run about $50.00. That would be billit item with o rings as a seal. The Ford item uses a simple flat gasket. g
  4. The pivot points support the windshield wipers. They are located at each end of your windshield wiper transmission. Often, they are frozen or have considerable drag. They are easy to disassemble, derust, and regrease. The pivot is a steel shaft supported by two steel bushings set into the pot-metal housing that is tapped for 3 small bolts. Most pivots have lost their pivot point cap, which was designed to keep the steel to steel contract between the bushings and the shaft dry. You can disassemble and re-grease the pivot points without removing them from the flat rods that make up the windshield wiper transmission. Here's how: 1. Remove the wipers from the pivot points. 2. Remove the entire transmission assembly from the car. 3. Inspect the pivot point. You should see the shaft starts with a threaded portion leading to a splined shoulder and then a collar that is seated on a steel bushing. These parts usually are well rusted. 4. The collar is, in fact, a wire "C" clip. A rounded wire, not a typical flat "c" clip. If your pivot point has heavy rust or a layer of build up, you might not recognize the wire clip as a clip. It is seated in a recess cut into the shaft. 5. Spread this clip with a very small pointed hook. I used the smallest flat screwdriver I could find. Once the wire clip is spread it is easy to work it out of the recess and up the shaft. These are very easy to lose and I've never seen them for sale. Remove the clip and place it in a magnetic bowl or cup. 6. Screw a nut over the threaded portion of the pivot shaft. I used the cap nut that secures the wiper blade assembly to the pivot. 7. With the threads protected by the nut or cap nut, gently tap with a lead or other "soft" hammer. 8. Bear in mind that the body of the pivot is made of "pot metal". It can be broken when you drive the shaft out. Don't use a BFH.. 9. I supported the flat side of the pivot point on a small open vise. 10 If the shaft does not move after receiving a few taps of the small soft hammer, then soak it over night in a container of light oil. I used a pint of A/T fluid, but I think any commercial penetrating oil will work. 11. After removal, clean both the shaft and two steel bushings. I held the shaft in a small vice and scrubbed it with a piece of 1500 grit wet/dry sandpaper soaked in light oil. I cleaned the bushings by wrapping the same piece of 1500 grit wet/dry sandpaper soaked in light oil around a .32 caliber brass bore brush. The bushings were cleaned in the same fashion as cleaning the bore of a .22 or .32 caliber firearm. 12. Once the shaft and the bushings are clean, smooth, and dry, I packed the pivot housing bore with a heavy bearing grease used to pack wheel bearings of boat trailers. This grease is designed to repel water. [Actually, I think all grease repels water to a lesser or greater degree.]. I think you could use any quality heavy grease. 13 Drop the greased shaft into the greased pivot housing, place the cleaned and greased wire "c" clip over the shaft and work it down the shaft until it seats in the recess cut into the shaft. I used a deep well socket, I believe a 10 or 12 mm socket, to push the wire "c" clip squarely down the shaft. 14. The last step is to push onto the pivot point shaft, a plastic/rubber cap that is designed to slow or prevent water intrusion . These are available for a couple of bucks off the internet. Google 240z wiper pivot seals. Sorry for the lack of photos. G
  5. I've received my water pump and compared it to a pump off a LS3 crate motor. They are the same as to the radiator connections as both have driver's side horizontal piping. The Camaro pump is spaced about .75 inch forward. The original truck pump mounted very close to the engine block and the pump "snout" that supported the pulley and mechanical fan was spaced forward. The Camaro pump uses the same pulley as the LS3 crate engine, but the entire pump stands away from the engine block. Truck water pump spacers used to mount passenger car pumps give the same effect. I'll mount photos if I can figure out how to reduce a very large file down to something less than one megabyte in size. LS1tech forums state that the straight thermostat cover from 1998-2000 Ford Windstar 3.8 v6 will bolt to a later Gen III water pump. Don't know if the GEN III thermostat would fit; but one would think the Ford 'stat might work. Z
  6. It appears from posts on LS1tech.com that the water pump from a 2010 Camaro with the 6.2 l engine uses the same offset from the block as do the LM7 and LQ4 iron block truck engines. Moreover, the water "pipe" is horizontal and located low on the driver's side. http://www.ls1tech.com/forums/attachments/conversions-hybrids/267367d1291698554-lq4-into-3rd-gen-1972-nova-21.jpg and http://i228.photobucket.com/albums/ee208/modi_photos/WaterPump003x_zps6632715f.jpg . The advantage for me is the ability to convert to an LS1 alternator location and still use the truck 135 amp alternator and an straighter radiator hose route. While my local Chevrolet agency will sell this at retail for around $800 or my first born and first choice on my Redbone bitch's next litter, take out's are listed at McKindrick's Racing and Ebay. Apparently, it is only on the 6.2 L option of 2010 and up Camaros. LS 3 water pumps from other vehicles appear not to have the same offset and the water pipe is located on the passenger side of the pump pulley. I've order one for my swap and if it does not fit as advertised, I'll post the bad news here. G
  7. If all you want is to run the alternator in the F body position on a truck then simply buy a LS1 F body alternator bracket and mount it on your block. Your iron block should have a flat boss that you will drill and tap. You will need to cut a spacer to make up the difference between truck and passenger car crank/water pump pully. I used scrap AL flat plate. Advantage is that the longer 135 Amp truck alternator will clear the Z motor mounts.. The spacer would be .50 or .75 inches. This modification is covered somewhere on HybridZ. You do have to buy 2 longer shoulder bolts with allen heads to clear the serpentine belt. You, of course, remove and sell the truck p/s & alternator mount.
  8. Short story is I have a set of aftermarket s31 4 lug wheels [6.5 x 15 +38 offset] i wish to mount on my early s30. I have a set of 280z hubs and a non-turbo 4 lug 300zx. Both hubs have an offset different from my 240Z hubs. I understand that the non-turbo 300zx has a .75 inch offset over the stock 240z. However, the aftermarket wheels [Fittipaldi] I pulled of a non-turbo 300zx have "ET 38" cast into the hub. I understand ET38 is a +38mm [1.5 inches] offset. Is there any advantage to using the 300zx hubs or can I simply purchase wheel adaptors that are 1.5 inches thick? The plan would be to mount 205/215 x 65 x15 tires on these wheels. This is not a race car; but, it does have a mild 6 L GenIII truck engine. Are wheel adaptors that thick safe to drive? G
  9. My brother has fitted a 3.7 V6 into a '62 Falcon. It is a crowd: very tall and wide. He had to remove the strut towers and go with Mustang II front assembly. His biggest issue at the moment is sourcing a loom for engine management, transmission management, and electronic throttle. The after-market hasn't caught up with the popularity of this engine and the wrecking lots won't break one up for sale. Ford has NEVER made it easy on the DIY engine swapper: they just seem to package and market their engines with an eye toward discouraging anyone without excellent fabrication skills and a deep pocket from swapping them. The Windsor and flathead appear to be the only engine families that Ford stuck with for the long haul. Well, maybe the OHC fours (Turbo Mustang/Thunderbirds and such) had a good run. g
  10. I agree, it is an R200. My junk yard experience is that if you lock down one wheel, rotate the other, and count pinion/drive shaft rotations and multiply that number by 2 will give you a ball park figure. Your's is probably a 3:9. The only real way to determine ratio is to pull the cover, rotate the crown gear until the numbers appear: the small # will be the number of teeth on the pinion; the larger # is the tooth count for the crown gear. Do the math. G
  11. I look forward to reading about your progress. Have you considered changing out the 3.70 for a 3.54 or 3.36? Here's a a post and several replies off of ls1tech.com regarding 2:7?:1 r&p in comparison to 3:73 and such. Scroll down to about post #22-24 for time and e.t. comparisons. Look here.http://ls1tech.com/forums/gears-axles/3260-considering-going-3-73-gears-2-73s-crazy.html g
  12. Add me to the list. I need lens and rings. Please post prices when you are ready.
  13. Tony, a DeadHead? Who would''a guessed? He's dead right about those VW Micobuses and your legs. Even mounting a spare tire up front would be of no avail.
  14. I think Tony is on to something. Afterall centrifugal pumps work by spinning water or air out to the side. But, there are several modern modifications to the exhaust system that are guaranteed to cure both the resonance and fume issues our S30's are plagued with. Tony, would you look at this modification and give us some estimate ot the power and torque increases one might see on the dyno: Look here http://kalecoauto.com/index.php?main_page=product_info&cPath=11&products_id=41&zenid=9ehs7jle2c2pvk9sii32oiln83
  15. The problem is I can not find an oil seal that fits one of my hubs. Here are the parts I have. two pair of 240Z hubs.... scalloped, 4 x 114.5 lugs. one 280 hub....... round, 4.114.5 lug spacing, with cast number on hub flange "76". one unknown [but thought to be a 280z) hub with no number cast on the hub flange. Visually, hubs 1, 2, & 3 are the same offset.. that is the wheel mounting flange all measure the same height off a flat table. I have rebuilt Hub # 2 with inner and outer bearing and oil seals from the local parts house. The part numbers for bearings and seal are the same for 240, 260, and 280Z. This hub works. Hub #3, accepts the bearing [removed and pressed in the races]; but, the seal drops straight down and makes contact with the inner bearing. It can be removed simply by picking it out of the hub with a fingernail. This seal is the same part number as the seal I installed into hub #2. It fits properly into hubs #1. I am reasonably certain the inner bearing race is installed properly into hub #3. It was pressed in using a bearing race tool and a light hammer. According to my parts house the same bearings and seal service 240z, 260z, 280z and 300zx. Please any comments are welcome. I've picked up all these hubs scavenging my local jy over the last few years and I have no real idea just what vehicle they came off. Except for the 240z hubs. Do I have an "odd" hub or am I missing something really obvious. If necessary, I'll tear it all down and use the 240z hubs, but I'd prefer to save them for another project. Sorry about no photos, but I've been able to post for a number of years, after the last software switch. G G
  16. I bought a Harbor Freight large pressure blaster with deadman nozzle and used 30 grit dry sand from Home Depot. Blows sand all over kingdom come and then some. But, it removes bondo and leaves the body with a clean surface ready for primer... after body work of course. It does take time and sand will be in every crevice. But, other than time, the cost was less than $200.00. g
  17. This is really good stuff! Would run the math using stock s30 rotors and caliper with the 240sx caliper and the MM rear rotors? Thanks for the great read. g
  18. And, of course, Checker Flag axles or play with short Pathfinder axle and adapter. g
  19. Oh, I thought they all rode on the shaft. This would explain why the stock shaft I just removed required a lever to "pop", but didn't have a clip. I'll just have to probe that diff with a long finger and see what I find. Thanks for the tip. G
  20. Here's the set-up: 1. I have a 3:36 R200 with clsd and the additional clutches purchased from a Member. 2. The axles are CV from the same 300Z Turbo as the clsd. 3. MM early welded up cv adaptors. What I did: 4. I purchased set of cv axles out of a Nissan Pathfinder. 5. Disassembled the Pathfinder axles and Disassembled the 300Z cv axles. 6. Reassembled the 300Z axles swapping the driver's side 300 cv axle to the passenger side 7. Reassembled the 300Z axle swapping in the shorter Pathfinder axle to the driver's side. Reassembly using Cir Clip: 8. I noted that neither of my CV axles had cir-clips attached to the input shaft that is splined and cut for cir-clips ("input" shaft is that portion fitted into the differential). Not a problem, as the Pathfinder input shaft did have a cir clip. I removed that cir- clip and installed it on my Turbo axle input shaft. The fit was loose, but did not "hang down". There were small light marks on the Pathfinder cir-clip that correspond to the splines on my 300 cv input shaft. The Problem: 9. The passenger side axle does not slid in and "click" as the cir-clip expands. It stops dead as the cir-clip begins to enter the spider gear. Light taps on the end of the axle with a dead hammer does not move the axle. If I remove the cir-clip the axle engages and moves all the way in. My First Resolution: 10. I thought the Pathfinder cir-clip was not compressing or was not compatible with this assortment of R200 parts. The Confusion: 11. Searching for Nissan cir-clips, I pulled the input shafts of two other long nose R200's in my garage. No cir-clips on any of the four. I then went to my favorite JY in search of 300Z. Found one 86 or so Turbo, R200 non-lsd. Pulled the passenger side axle..... NO CIR-CLIP. Ok, pulled the other side and, again, no cir-clip. There is no doubt that each of these input shafts are machined for a cir-clip of some sort. The spider gears they fit into are also machined with a corresponding groove. So now, my questions are: a. Did Nissan ship these cars without a cir-clip retaining the input shaft in the spider gear? b. What is the effect of running these axles w/o cir-clips and c. Where do I find cir-clips for this application? I might add that cir-clip or none, the input shafts still needed leverage to "pop" them out of the differential. G
  21. Thanks for the information. I took the JTR book to heart; I'm running the 10" 2+2 booster and larger 13/16 inch MC. I'll return to stock front calipers and slotted rotors [just for the bling], aftermarket PV and hope for the best. G
  22. My Z has the MM rear disc brake conversion using 240zx calipers and 300z non ventilated rotors. I have all the elements to install ventilated front discs and Toyota truck calipers. I do not have a functioning proportioning valve as I gutted the original. After reading all the posts describing this swap to be inherently unbalanced in that the Toyo calipers are too large in comparison with the 240zx rears, I'm thinking seriously about returning the front to stock specifications: stock rotors and calipers, and keeping the MM rear discs [hey, they look good and the drums have long since disappeared]. I think I should install another after market proportioning valve in my rear brake line. But I don't know if it is "necessary" or not from a safety standpoint. This is not a track car; but, I do wish to have predictable behavior for panic stops from a straight line. Does anyone have any experience with stock brakes using only the MM rear brake set up? I tend to ascribe to both "more is better" and "while I'm at it I might as well ........ ." views of life. This time I really want to do it right. Please comment. G
  23. The round one. Might have to spring for another set of new boots. G
  24. Upon reinstalling my CV axles after swapping the driver's side axle center bar over to the passsenger's side, I find that the axle, with circ clip will enter the differential and will partiallly engage the inner splines. I can turn the differential; but, the input shaft stops before the circ clip snaps. I think the circ clip is not compressing into it's groove. This is new, as in the past, the circ clip would snap in place with little effort. What is the proper way to install? I've tapped the end of the axle [with the dust shield in place] with .5 lb plastic dead blow hammer. With no luck. The angle of the axle is not straight as the rear suspension is at full droop and interference with the CV adaptor companion flange prevents a straight line "shove". Finally, can anyone here source new circ clips for input shafts for R200 LSD from an '87 300zxt? Thanks, G
  25. I'm sure any of those three will perform quite well. However, the later Mazda 1980 or so Rx7 have an oil cooler that will fit very nicely between the "horns' of 240z. It also has abuilt in thermostat. Quite often used as upgrade cooler into 944 porsches. Cheap too. Look here.http://www.pbase.com/slidevalve911rsr/for_sale_mazda_rx7_front_oil_cooler_used
