26
Everything posted by madkaw
Isn't disengaging the clutch taking the load of the turning components even though they are still turning the same speed? Just coasting there wouldn't be the torque the driveline? I will search this, but didn't I read that the halfshafts were all the same length regardless of r180 or r200. I was being told today that he thought there were two different lenghts of halfshafts. Someone want to clarify this????
I know there a ton of threads like this, because I have read a bunch trying to get some ideas. Here's the facts 9/71 chassis-L-24, bwt-5, 89 LSD Shortened and balanced main shaft, half shafts newer universals and also balanced Tires new, wheels new, brakes new(wildwoods), rear bearings new.Pinion angle 2 degrees and parallel Symptoms; whirling out of balance sound from 45/50--70mph coming from rear Changing gears at a constant speed affects the volume of the noise At 60mph 3rd gear noise is hard to hear-almost non existent,4th gear it is the loudest, 5th gear reduces noise , but is still apparent Disengaging clutch noise goes away Sounds like it is coming from the drivers rear Loading the tires by swirving back and forth doesn't seem to cahnge the noise at speed So if I didn't get the bearing in on that side just right(not enough torque let's say), wouldn't the loading of the tire change things and why would disengaging the gearbox affect that? Why or would gear selection make a difference? I'm thinking it's the diff and it's just has noisy gears. I ordered some high/impact redline and i'm going to change the gear oil-even though it's fresh oil. Guys-I need some ideas or input. I want to drive this thing 1000 miles in a week and i'm getting nervous
Oh yeah, I searched and went and aquired a magnetic protractor. I just finished removing my exhaust and driveshaft and measured. apparently when i made my own RT mount it was not quite right. I have intersecting lines on my angle, which is not good. My RT mount should have dropped the front of the diff more to get the right angle, so I will need to modify or shim some how. At least I found something-hopefully I found the right thing. The rear of the trans is -2 degrees and the diff is -4 degrees. So the only fix is to drop the front mount. I haven't seen anyone elses mounts installed, but I was concerned on how close the bolts got to the front brace. I have at least a half an inch to drop the diff, hopefully that will be enough.
One other thing,what do you use to measure level. My floors and rails are solid as are my rails, so I was going to use that.
i've been searching on this subject, but unclear about how to set up chassis. most discussions on this involve solid rears. So when I jack the car up, it is NOT crucial to set car on suspension since this is an IRS set-up-correct? I see no need to load rear suspension since the diff is suppoerted seperately-right? I don't see a reason to set the front on it's suspension either. So supporting by frame is good? So I set the car up on jacks LEVEL, and then make my protractor measurements. For those that have done this, where was the happy degree for these cars?
Lug nuts for Rota wheels-quality ones
madkaw replied to madkaw's topic in Brakes, Wheels, Suspension and Chassis
I didn't think the standard acorn would fit on the rotas. -
No one has an opinion here? I am using a allen socket type lug and they are not holding up well.I think they will strip out sooner then they should-sorry don't have a name brand, but they were probably cheapies. Anyone using the spline type and who makes them-Mcguard, Gorilla-are they holding up after taking the wheel off many times. How's the chrome holding up? -
I believe the problem is my LSD. If I grab the halfshafts near the diff side bearings I can get some up and down play-worse on the left side. Never changed diff side bearings-is this difficult?
A little background; My 9/71 is just getting finished it's resto mod. I have only 200 miles since the resto and things are pretty good. The car drives wonderful and the engine runs super. Pretty much everything is new or rebuilt on this car-new tires,wheels,brakes, rebuilt motor. My noise sounds like a tire out of balance or something that rotates is out of balance. The noise starts in about 50-55 and goes away towards 70. This is strictly a rotational noise, with no shimmy or shakes-nothing is felt while driving. The noise sounds like it is coming from the rear tire area, but it is hard to exactly pinpoint. I noticed that while driving in 4th gear at around 60, the noise is very prevelant, but if I shift to 5th gear and maintain the same speed, the noise about goes away to nothing(I have to struggle to hear anything at all). Go back to 4th gear and there it is. I realize that all things should remain constant at speed from the tranny back, but would the gear change invoke a torque change that would change something in the driveshaft angles to cause an out of balance(long shot-I know). It is fustrating to have this car run so good and drive so nice and to be paranoid about this noise. The main driveshaft was balanced when shortened for the btw5 swap. The half shafts had the u joints changed 5k ago. I have an RT mount on my LSD. Any ideas what to check? I had the tires balanced and rotated-no difference.
Wilwood brakes bledding techniques
madkaw replied to J240ZTurbo's topic in Brakes, Wheels, Suspension and Chassis
Never touched the bottom bleeders-just the top ones, inside and out -
Well i thought I had tamed the wild beast, but I had to do some additional work. The resonance at 2500 was still really loud, so I ordered some resonators and slapped them in-quite easy infact. Now I getting to the place I want to be. I think the car sounds amazing. The resonance is now doable with just some slight crackling around that magic number 2500. I am still in the break-in period on the engine, so 4000 is about all i'm doing for now. I could cruise around all day at 3200 because it sounds so sweet. 3200 in 5th will be about 75-80mph so highway speeds will be a pleasure. It sounds very beafy at low end and starts to scream as I climb the rpms. I will try to make a recording if I can capture the sound well enough. If I had some exhaust tip resonators I imagine it would be perfect for me, but it will get me to Zcon in style for now.
AAAHHHHHHH!!!!!! That's better. Got the magna flows installed and definetly a better sound. I can't say anything about cruise noise levels, but I hope it will be tolerable. The magna flows took the "crackle" sound out to make things more mellow. Let me know what you think. http://s2.photobucket.com/albums/y9/_mad_kaw_/?action=view¤t=MVI_2290.mp4
I believe i have a 73 rear light panel and the access panels are NOT flat. Please send pics of what you have.Color is not an issue sfinnerty@indy.rr.com
I have a hood, hatch, drivers door and of course fiberglass fenders. I'm in indianapolis-don't know how far that is for you. The hood has some dings, but not rusty. The hatch has minor defects and some rust-but no rust bucket. Driver's door is very nice. I'd have to shoot some pics if you are interested.
pm'd you
) I kind of let this thread go by the wayside, but progress has been made. I finally got to hear my exhaust run last week and all I can say is--TOO LOUD guess I should have figured that 12$ glasspacks wouldn't do much, but combine that with headers and it's too much for this old man. The magna flow mufflers have already been ordered and delivered and hopefully will tame the wild beast. I will get out of the highway and have a little fun with the 'race car" before I change the mufflers over Enjoy some pics and sound video http://s2.photobucket.com/albums/y9/_mad_kaw_/z%20exhaust/?action=view¤t=Zcar001.flv
I am missing 3 cables from my heater panel. Top right and lower 2 cables and CLIPS. please e-mail me at sfinnerty@indy.rr.com ---paypal ready I guess all I need is the clips if anyone has them
Did you watch the video, how does your exhaust compare to mine as far as volume? Do you have a header on your car? Do you have any resonators on the pipes?
Yeh I'd like to hear it revved up myself but that motor doesn't have 1 hour on it yet. I need to drive it around and break it in. Yes that is just 12$ glasspacks, might as well be just straight pipes.
Sorry I just kind of threw that link on a post with no description because it was so late. I finally have my car running and got around to putting a video together of the exhaust. It sounds cool,but too loud for this old man, so I have my magnaflows on on order(back order actually) and hopefully will have time to installthem in time for Zcon.I haven't had an oppurtunity to drive the car down the road yet,but hope it runs as mean as it sounds
I have just learned recently that true duals coming off of a header with a pair of glasspacks is NOT enough noise suppression. My car is so freakin loud that i am ordering different mufflers ASAP. I would have not guessed that it would have been this loud, but the glasspacks do nothing, so I am basically running dual straight pipes. I am going to fit the biggest magnaflow mufflers i can fit under there(which won't be very big) and hopes that this will be sufficient. If that isn't enough, then i will add resonators upstream. And I thought my crossover pipe would help with the noise-yeh right. The only reason i say magnaflow is that the one I put on my daughter's car-- zxt and it sounds awesome with her 3" exhaust.
