madkaw
    27
Everything posted by madkaw
  1. I believe it is a rare breed anymore that hangs out and walks and talks cars and also be someone you can count on.First off it is hard to get anyone you can count on. A person that rememebers that favor or that knows that you will always reciprocate a good deed.I have a good friend for 30 years now and the basis of our friendship is cars. He just lives across town, but It might as well be 100 miles away before we ever get together becuase our schedules are so full. I'm lucky to get time to step out in my garage that's 10 feet away between work and family stuff and spending time with my wife-who works full time. It's a different era! My son doesn't want anything to do with working on a car and that's fine, but I believe it is the younger part of your life that you get the time to hang out with car buddies-on a regular basis. Ahhhhh--for the good ol days again!!
  2. Pull off the valve cover and look at #4 valves. Especially the where the rocker rides on top of the valve, it might have turned sideways with a sticky valve!
  3. Well I've tried to set the timing back to 10 btdc and keeping the vacuum advance, but I still get detonation at the vacuum and mechanical overlap point-around 2800rpm. Though it doesn't last that long going thru the gears, and it is only prevelant at a slow acceleration rate, I'm pulling the plug on the vacuum advance until I get something better. one big reason is that I smelled coolant today inside my car, but couldn't find any source for the smell. Wasn't using the heat either. Looked around my heater core and everything looked dry. So paranoia set in--BLOWN HG. No white smoke, no visible leaks outside the engine, plugs looked alright. I took the cap of the radiator and started the car and saw some bubbles, but I think the thermostat just opened so maybe the rush of coolant caused the bubbles???? I just went back out there again after the motor cooled and simulated the same thing and bubbles right after the thermostat opened, but couldn't see anymore after that. Don't have the capabilty or time to do a leakdown right now-anything else I should check? Motor seems to run pretty smoothly though I have been messing with mixtures on the SU so it wasn't perfect. I'm kind of dislexic(and a bad speller) when it comes to certain things, but now that the weather has turned cooler and dryer the mixture probably leaned out right? So if I leaned out the SU's on top of that, have I gone to lean and would that enhance detonation? I'm gonna research this right now so don't flame me I want to take the car to the dragstrip this coming tuesday, but want to make sure there isn't anything wrong with the motor first.
  4. For that price I think would spend my money somewhere else. 1600$ just for the plenum-ouch! I would think that kind of money would allow you to modify those Mikuni intakes anyway you want and you would have something really different---BLING!!!!
  5. Looks like that MSD only changes the final amount of advance, which is helpful, but not what I'm looking to do. I think better results can be obtained by modifying the Nissan dizzy, but not as easy as turning a knob. Getting that vacuum advance to work with a power curve is the challenge. My car is awesome at 21 intial and 36 total, but I can't use the vacuum advance for economy. My next dyno run will be at the quarter mile at indianapolis, and I plan to run the car at the same timing setting as I did at zcon, then I am going to go for a pure power run with the vacuum advance plugged. Then I will work for something in between. I am kind of anxious to see the difference in the first two runs. My butt dyno says it will be considerable. I do have to keep in mind that i made a BIG float adjustment since the dyno run and I have gained at top-end for that effort. This is the most workable approach since Tony is hiding his top-secret dizzy somewhere is his toybox.
  6. I also wonder what he did with that dizzy if your running 8 initial and still getting 36 total! You might find some reshaping of the mechanical weights or springs or slots for the advance-you better hold on to that dizzy. I think I will try and find another e12-80 dizzy and experiment with it and keep my original stock.
  7. If you won't sell it, can you just take it apart and make an outline of the weights on a clean sheet of paper for a templet From what little I've read of dialing in the dizzy, the reshaping of the weights is much better at controlling the mechanical input then messing with springs. My car ran so great at 10 intial with full advance, now I just need to find the secret combination to get the full advance to come in at the right time. This is going to take some serious R&D and many trips to ORP raceway-darn! I will probably find a nice set-up and then I will be mounting the Mikunis--- to start all over again.
  8. I'm suprised that you could just "plug in" your advance when running 34 total, but I have no idea how much advance your dizzy vacuum pulls. What's you intial set at then. Bottom line is that if you can do that and not detonate and keep all that top advance and good mileage your doing great! I believe I have one of the early electronic dizzys, I will have to look to see how much vacuum advance it has. I think you are running higher compression, but you must have some overlap with that cam. Just curious-what kind of pressure do you get doing a compression test? If I didn't mention it earlier, this dizzy is all in at 2500rpm. The vacuum advance is 17 degrees. So at 2500 rpm at a cruise/slight loading(going thru the neighborhood at slow cruise thru the gears) I had 10+17+17= 44 which from what I have read is not out of the norm, but at that 2500 mark is where I would here a slight ping.
  9. I would like to use the mechanical advance, but this e12-80 needs to be tuned to my engine. The e12-80 pulls too much advance at the wrong time for my application and causes detonation and does not optimize power. Why run 27 degrees total when you can run 35.I did look at the idea of slotting the pull rod, but I don't think there is enough rod to do that-but I'm still working at something to that fact. As far as being a long day at the dyno-if I have my ducks in a row and have several options to try during my dyno time, I can make effecient use of my time. 30 ounce, I think I am experiencing what you have now. I have suffered mpg for power, but I haven't really given up any drivability. The power is good everywhere and very smooth and predictable, just needs to be more effecient. I would like to cut the vacuum advance in half and see how close I can get to 36 degrees total without detonating. If I was able to make the vacuum advance somewhat adjustable it would give me several options at the dyno in a quick period of time. I would just be curious to see the numbers comparing what I ran at zcon(10 degree intial-27 total) compared to where i am now(21 initial-36 total approx.) Fuel injection is great, but for performance you need to be ready to spend$$$. I would like to go with a edis set-up and install a megasquirt and do the timing curve right, but for now it's going to be tweeking the e12-80.
  10. No proof on the richness, but my mpg is definetly taking a hit from losing the vacuum advance. I realize that the vacuum advance is there for other then WOT, more for cruise and high vacuum conditions. just trying to get the best of both worlds-WOT performance and fuel economy at cruise. I was thinking of cutting the vacuum advance in half to see how that effects everything, just not sure how I am going to go about that. I have Mikunis sitting on a shelf, so I'm not sure how my findings with the SU's will translate to them once they are installed. Trying to learn and improve my understanding-but I can't complain about the way this engine runs.
  11. Well I nhave been playing with the timing and I believe i left some HP on the table at Zcon. I guess when I set my timing before I went( 10 btc static), I didn't rev the engine enough to set total timing properly. I must have also reconnected the vacuum advance ASSuming that it would cut out at the higher rpm-so I was only running about 27-30 degrees at top end. After reading some more i took the advice and just plugged the vacuum advance and set intial to about 21 degrees and I am running a good 36+ at the top end. Good thing about this is overall hp gain and no detonation at 2500rpm(wasn't too bad). The bad is giving up some mpg and I can actually smell the difference. So it's time to develope a mechanism to limit my vacuum advance and at the same time maintain my total. Anybody have any options they have tried? I am thinking of somehow limiting the throw on the vacuum rod so I only get about half of the 17 degree advance. I guess it would also be cool to beable to keep a lower intial and full vacuum, but modify the mechanical for a higher advance. Right now I am not experiencing any detonation but not sure without some dyno that extra full advance would be doing anything. it seems the consensus here is 36 is a good number, and Braap thought 38 was optimum. 30 ounce, I wasn't setting mixture with the floats, just trying to keep fuel in the bowls which would effect mixture at top-end.
  12. Well I thought I would share this family picture, and you can see it involves two families. I can't tell you how much my daughter loves this car-----still! She has been very patient dealing with the quirks of an older car, but it has been a good car, better then expected for her. Sarah is always riding the wave of attention the Z gives her. Most guys she knows are jealous and in awe of the car. Now that I have painted my car she is wanting her car to look as pretty! I went to visit her the other day on campus and we thought that the pictures would be cool in front of her sorority. My wife and I have discussed giving her our Subaru Forestor as a daily driver next year, but the first thing she cared about was what was going to happen to her Z. I don't know if there is anything else I could have given her that she would have enjoyed as long as she has enjoyed the Z. I told her that the Z will always stay in the family, and it will always be her car----and dad's to play with.
  13. Please post up your finding with your wideband. I wish I had that tool to diagnose a similiar issue. My 2.4(40 over), higher compression with cam and dual exhaust seems to be running lean at top end with SM needles installed. The SU's run great and MPG is super, but I am like Jon and believe they run out of breath at top end. I also have some Mikuni's of the shelf just begging to be put on, but the SU's will have their day first.
  14. Did mine about 2-3 years ago and the prop valve was NOT plug and play. I found out then that I couldn't flare a brake line for my life. I also couldn't find the correct adapter. I wound up having the line made with the proper length and ends and had it sent to me. It was like 10$, but I had piece of mind that the flare was correct.
  15. I had about the same damage on my car from an earlier collision fron the previous owner. My car was basically rust free which gave me more options. I took my car to a frame guy and had the spot pulled out like yours, then i cut out the bad metal(not the whole frame rail), and replaced it for cosmetic reasons. If the metal is sound and you get it square, then bondo the dimple stuff and call it a day. Or cut out the bad stuff and replace.
  16. Thats's interesting, because I am chatting with frank on CZCC and he was the guy before me with his triple mikuni's. He bottomed out their scale at 9.3 or something and I don't remember any plumes of smoke. he did admit that his car is running stinky rich right now. I will have to ask him if i just missed the smoke
  17. I also have ORP less then 5 miles from my house with Friday night drags-30$ for unlimted runs on a premeir 1/4 mile track. I think that will be my dyno for now, and eventually maybe back to the other dyno. Honestly I have been very gentle with this car waiting for the engine to break in, but now i guess it's time to have some fun. I questioned if my diff would hold up also, because of strange noises, but now I have a spare incase something happens. I'll post-up if i make over there in the near future. By the way, I saw no black smoke on the dyno run-a little white smoke, but I expected that on a new engine. My next investment is a wideband set-up, I could use it for my car and my daughter's 81zxt.
  18. I appreciate all the replies guys. This is my first dealings with a dyno run and deciphering a dyno graph-so all of you probably know more then me. As to certain aspects of the run;the engine was running rich at the time of the run. The foward SU piston needle was set too far up into the piston creating a rich condition. Rich enough to soot the plugs-so I figure that is what you are seeing with the low AFR. Needle was reset-plugs looked perfect. The carb floats were set to stock specs at the time of the run, but either my measurements were wrong or the stock specs didn't cut it for this engine. After returning home from ZCON, I adjusted the floats by more then a 1/8" on the tab, and the plugs still look perfect and the engine wasn't as flat on top end-noticable improvement. As far as the flat toque curve, I'm not sure what the deal is there, but this engine runs like that curve as far as having a very solid torque band across the rpm range. I am impressed how this motor will pull from any rpm. Weebeezeed, I am 15 minutes from greenwood. I will not be making any drastic changes based on this dyno run, but it did pick-up my richness problem, and it did show my leaness issue at the top end, so there is something to go by. I would like to find a point with my carburation that I atleast see some richness on the plugs, that i am making significant changes. As far as the 'set-em, forget-em" theroy, how is that possible. If I just went by the plugs and MPG and wasn't worried about anything else, I would have been happy with this dyno run. Now I have made a huge float adjustment(definetly not spec) and it runs better and still isn't rich. Bruce Palmer was the one to suggest float adjustment. Maybe the it is more then that, maybe the fuel pump is not maintaining the correct setting. An interesting note; the Z before me that had triples on his engine was also showing a very rich condition and making less HP then me. Could it been the suffocating heat that day-95+ degrees and humid?
  19. Sam, you will have to update this thread if you get around to using this device to tune. I'm going to get one this week-end and try it out.
  20. Maybe that's what I'm seeing on the graph, I'm running out of air-but guys have seen more hp with SU's. I'm guessing those SU's have been punched out a little to flow more. My timing might have cost me some hp also, since I believe it was set conservative. With dual 2" pipes this engine might need to breath a little more thru the carbs-I see the mikunis having their day soon What kind of compression are you running and what motor?
  21. That's certainly an option, but I can't believe the SM's give out at 160hp. I guess I will tweek some more and see what happens.
  22. I guess I should have just asked,"hey dudes-howdoa make my car go faster-dudes", and this would have gotten more responses!
  23. Well I got my car together just in time to drive down to Zcon. The engine was running really well with about 1000 miles on it. I got outstanding MPG with my SU's (26-28mpg) with my 3.7 LSD. I hadn't even taken the engine beyond 5krpm's till this point. They had a dyno at track days so i thought-what the hell-I'll give it a whirl. My timing was set conservative at 10 btdc at idle and 35 degrees all in with my zx dizzy. I am running SU's with SM needles. Other specs: 2.4 40 over with eyebrowed cylinder bores Assembly balanced, new pistons,stock lower end Compression running 195 across all 6 cylinders Head is early e-88,, shaved .10 ,semi closed chamber with larger stainless valves,unshrounded to ring on headgasket Schneider stage 2= 480 lift,270,270 Headers 6-3-2 duals 2" all the way back with crossover As you will notice with the graph I was slightly rich until I started into the power band, then she just fell on her face at 5100 and ran out of gas-basically. The richness issue was the foward SU piston needle beeing to far up-in the piston(figured that out later). The leaness was from improper setting of the float levels(I summized) After getting back from Zcon I when in there and tweeked the floats(big tweek) and noticed a more willing engine to rev, but I believe there is still quite a bit there.I pulled the plugs after the tweeking and the plugs looked about perfect. I was expecting to see more carbon as I made such a large adjustment, but they looked the same as before I adjusted. Do I tweek the floats until she doesn't run well anymore or the plugs change color, or is there something else I can do to fatten her up on the top. I have a set of tripple Mikuni's 40mm sitting on my shelf, but I am holding off putting them on until I have reached the limit on the SU's I have on there. I would like to do a fair comparison of the two set-ups and pick the best for overall satisfaction. I have access to a dyno here locally, but I want to do some butt dyno work before I cough up the 100$ per hour for a real dyno. Maybe after fattening up the fuel I can work on more timing, but the fear of running lean will keep me where I am at now.
  24. Chris, I think the only issue is the MC booster studs spacing. The earlier 70-72 used the smaller booster unit and the spacing between the clutch and brake MC booster was narrower then the later years using the bigger booster-thus the clutch rod won't line up with the pedal. I learned this the hard way and have a excellent pedal box for a 73 on up that I can't use now. So it depends what your chassis was set up for-bigger or smaller booster.
