9
Everything posted by Michael
Grumpy – To slightly change the subject.... I’ve been following your advice on big blocks in various posts (such as the 496 marine build-up), but prior to this thread I didn’t realize that you had a big-block Z! Do you have pictures/text about this car? Would you summarize the characteristics of the engine build that you chose? You’ve heard the story with mine – chassis is together, but engine is ailing, while I waffle as to what to do with it (for instance, whether to cough up >$2000 for aluminum heads, especially when AFR comes out with oval-port heads, or to mess with my 346236 castings). 632 cu in mountain motors are wonderful things, no doubt – but I would also be curious to see your views on “budget” offshoots of the 454 As for the roll cage story – I don’t have the benefit of practical experience, but the consensus among chassis builders with whom I have come in contact is that triangulated structures are vastly superior to quadrilaterals, and swing-out bars, such as door X-bars, might be OK for rollover protection purposes, but they don’t help much with chassis stiffening. My car has welded-in X-bars which tie to the frame rails in the bottom front (diagonals inside the wheel wells), the dash bar in the top front, and the roll bar in back. By no means necessarily the best solution, of course - but it certainly feel solid on jackstands. Pete Paraska has pictures of my car on his site - http://mywebpages.comcast.net/pparaska/MichaelOlsBBZ.htm
Pondering the examples of hybrid Healeys, MG's, etc. - and the more radical Z's on this forum, I'm intrigued by the next question - has anyone built a car completely from scratch (in the spirit of something like Bill Thomas's Cheetah of the 1960's)? I mean, your own frame, bodywork, windshield, doors, everything? Considering the extremes to which some members have gone to, this would be the next logical step....
Big block experts...... question for you
Michael replied to MYRON's topic in Gen I & II Chevy V8 Tech Board
I have a '78 454 from a Suburban. Sure enough, it has the "hi perf pass" casting. My impression is that ALL standard-deck 454 blocks from the 70's had that casting. It also has the oil-line bosses above the oil filter mount, but it's a 2-bolt block with cast crank. I don't know of any post-1973 454 with had a factory forged crank. Forged-crank 454's basically died with the LS5. Heads are 346236 - yours are probably the same. 113 cc oval port heads, but they're not "peanut port"; those are even smaller. Some people claim that with pocket porting and upgrade to 2.25"/1.88" valves, these heads can support 450 hp. That got me confused over the choice to get aftermarket heads, since 450 hp is exactly my goal for the Z. If you do put a BBC in your Z, keep us informed! Man do I have some information on that topic (the hard way....). -
I agree about the R/S matter. Plotting the “crank-slider” model of piston displacement, speed and acceleration vs. crank position, and varying the rod to stroke ratio, reveals how little the piston kinematics are affected by changes in rod length. And the one or two degree difference in rod angularity - yeah, I don't see how that could be significant, either. Importance of rod to stroke ratio is one of those debates that will never get settled, simply because we just don’t have a rigorous way to quantify exactly what happens – in terms of engine output or cylinder bore wear – for different R/S ratios for the exact same displacement and block architecture. That leaves wiggle room for some expert engine builders to legitimately claim one thing, and for others to claim the precise opposite.
Canfield 195 or AFR 195 SBC heads?
Michael replied to pparaska's topic in Gen I & II Chevy V8 Tech Board
Pete, Frankly, I find it somewhat difficult to understand how one could fret over spending an additional $300 on one set of heads vs. another, when >$30,000 was already spent on the project! Canfield might be the unsung hidden gem, and AFR the celebrated show horse, but if you buy the Canfield heads you would still wonder whether the AFRs might not have been better, whereas if you buy AFR, quite possibly you would not be concerned over the alternative. So if it’s just a matter of $300 price difference, spend the bucks! Once upon a time you gave me essentially the same advice.... -
Don't know if this got mentioned already or not, but there's a fellow in the Los Angeles area who did the Caddy 500 swap about 5-10 years ago. He showed his car every year at the Motorsport show in Orange County. I believe he's the same guy who recently set the top-speed record with a sorta-stock 2+2 Z at Bonneville. Anyway, back around 1998 I had a conversation with him. He claimed a 50/50 weight distribution, with aluminum intake but stock heads (if I recall correctly; also, I think he used a GM corporate TH-400, or maybe 700R4) and stock firewall location. The distributor location makes engine setback easier. He may have had a custom sump. I have a photo of his car (but nowhere to post it).
I started on my roll cage install!!!!
Michael replied to stony's topic in Brakes, Wheels, Suspension and Chassis
Thanks for the compliment, Mike! The guy who welded my roll cage was a rare find - and even he had some choice remarks when describing the difficulty of the job. As for books on roll cages, one standard reference among those currently in print is "Chassis Engineering", by Herb Adams. A company called Steve Smith Autosports had a series of guidebook-type publications on chassis and roll cage design, back in the 70's. They focused on NASCAR-type cars, back when they actually resembled "stock" cars. Those books are probably out of print, but try a web search on "Steve Smith Autosports". -
Street Legal, You’re making the big-block installation look easy! Looks beautiful! My ’78 used to have a big block – now it just has a big hole. I’d love to compare notes on all things BBC. Unfortunately, big block activity on this site is moderate at best. Brad Barkley started a site dedicated to Chevy big blocks, but sadly, that one isn’t much of a happening place, either. Perhaps the best venue is e-mail off-line?
I also used to be a student in the school of life. I would attend class regularly, take good notes, study for the exams and perform relatively well on them. But then – perhaps suddenly, perhaps gradually – came a transformation. Increasingly I found myself losing interest. It became more and more difficult to concentrate, to make my study time worthwhile. My grades slipped. I could no longer keep up. I was losing the respect of other life-students. So, in disgust, I dropped out. On the advice of professionals, I started wearing jackets with really long sleeves. Moved to a town where most residents thought that life was a cereal box. But being a life-school dropout proved to be unnervingly difficult. Shoulda’ stayed in school. Now I’m thinking about going to night-life school, and maybe getting a life GED. If that works out, the next logical step would be to consider going to life college. They tell me that in modern society, you can’t go far without a life bachelor’s degree from an accredited life institution. Going back to the school of life certainly won’t be easy, but now that I’m older and wiser, maybe life won’t be so bad. Now I’m looking forward to the life commencement – you know, when you graduate.
How much does these things weigh
Michael replied to Hitman47's topic in Gen I & II Chevy V8 Tech Board
Hitman47 - To somewhat change the subject, could you please provide some more information on the 540 BBC in your Bel Air? My '78 Z is set up for big block Chevy (long, long story) and I'm finally getting serious about dropping in an engine worthy of the frame; the 454 formerly in the car died last year. One plan is to get a 0.25" stroker crank for my 454 block, and get the AFR oval-port BBC heads, which supposedly are coming out this spring. But I am also considering stepping up to an aftermarket block. Budget considerations are rather elastic, but I'm eyeing something in the $5k-$8k range for the longblock (I already have all the peripherals). Forced induction is not in the plan. As for which year Z to buy, and what they weigh - I second the recommendation to go for a '72 or '73 240Z, if you can find one. But the more radical the modifications to the car, the less the original model matters. Unless you're in Southern California, the final choice mostly comes down to a matter of availability: if you can find a decent "rust-free" (big grin!) '70-'78 anything, buy it! -
Update on the bent strut situation - Denny and I looked at several sets of front struts from parts cars. All of them had the asymmetry that I mentioned in my first post in this thread, though one of the non-parts cars looked to be symmetric, from the symmetric spacing between the widest part of the tire and the nearest point on the spring coils. My impression is that the tolerances on the steering angle of the McPherson struts used on Z’s is in general shabby – far worse than what’s allowable in the specs. By the way, from what I have been able to discern, there is no built-in provision for such an asymmetry. The same range of steering angles is specified for both passenger and driver side. So I decided to reassemble the struts that I have, and to wait until a nicer pair comes along. Unfortunately parts cars (or any Z’s for that matter) are tough to find in the Midwest.
The strut housings on two corners of my ’78 280Z’s suspension are misaligned relative to the spindle castings. That is, the projected angle between the strut centerline and the plane of the brake rotor is off by about 2 degrees from the specified angle (~14 degrees vs. ~12 degrees). The strut housings are not bent; they just meets the spindle castings at the wrong angle. This is at the driver’s-side front wheel, and the passenger’s side rear wheel. The result is an incorrect camber at those two locations. Neither the unibody nor the various suspension linkages are at fault. I have not been able to source used strut housing assemblies. So, I would like to correct the ones that I already have. To do that, my plan (actually, the original idea was Pete Paraska's) was to locally heat (with an oxy-acetylene torch) the strut housings right at their base, where they enter the casting. Then, to insert a pipe or breaker bar into the strut housing, and bend it back. The issue is, what happens to the temper of the steel, and how to restore it. And whether the bending procedure can be done successfully. No local shop wants to undertake this job; the mechanics in town feel that this idea is hopeless and that the only reasonable option is to scrap the faulty strut housings and find new ones. I am looking for suggestions. Is the above-mentioned approach reasonable? Any ideas as to who might be able to do it? I don’t have an oxy-acetylene torch, or the appropriate fixtures to hold the casting in place.
oops, first paragraph above - I meant displacement and velocity. late at night...
Dan, Some time ago, I derived an alternative and somewhat convoluted formulation of the piston motion equations, which give the answers identical to yours for the speed and velocity. The acceleration answer for some reason differs by a constant multiple of exactly 6, which is almost certainly an error on my part (when multiplied by 6 and plotted vs. crank angle, our answers coincide). So my point is, your formulas make sense, and you did not make an error in typing. For typical rod/stroke ratios, piston peak velocity indeed occurs at around 75 deg ATDC (and again at 285 deg); for example, for my engine (stroke of 4.00", rod of 6.135"). The MEAN piston velocity is 4000 ft/min, but the peak is around 6600 ft/m. Another typical result. For that combo, the piston peak acceleration comes out to ~87,000 ft/s^2. Peak acceleration at TDC is of course maximum. By the way, local maxima of piston acceleration occur at 135 deg and 225 deg ATDC (~47,400 ft/s^2). Another local extremum is at BDC. The acceleration curve has inflection points at around 60, 155, 205 and 300 deg ATDC. Playing with these curves illustrates an interesting point about the relevance (or rather, irrelevance) of rod/stroke ratio. Doubling the Chevy 454's stock 6.135" connecting rod length does reduce the piston peak acceleration, but only by about 12%! Also, for the fans of dynamic compression ratio - exactly the same formulas are used to compute DCR; get the intake valve closing angle, go to the corresponding point in the piston position curve, and compute the remaining swept volume.
How much did everyone spend on their V8 Conversion?
Michael replied to a topic in Gen I & II Chevy V8 Tech Board
My story - Car $600 Roll cage $2500 Cutting up the sheet metal (labor) $1500 Engine mounts, frame mods (labor) $500 Exhaust (mostly labor) $300 Misc. plumbing $200 Engine core $850 Transmission $750 Bellhousing $250 Clutch -related stuff $500 Flywheel $300 Intake, carb, headers $500 Radiator and fan $400 Driveshaft $100 Small parts (add up!) $500 Shipping cross-country $850 Seat and cover $200 Fuel cell $200 Cam kit $350 That's about $11K so far. At this point, the suspension is mostly stock, and the engine needs a complete rebuild. The car is in pieces - I might get it together later this decade. Then again, maybe not. A long time ago, before I began this mess, I thought that it would be the project of a lifetime. Looks like I was right! The main expenses were labor for the roll cage and sheet metal surgery. This was money well spent, considering the amount of professional work involved. As far as parts go, the transmission stuff was the most costly, but necessary to get this much torque (big block) to the ground - and I insisted on a manual gearbox. I'm planning on low-buck suspension mods (mostly cutting and bending stuff), but am budgeting about $6K on parts and machine work for the engine. And that's for a naturally-aspirated, 5500 rpm pump-gas stump-puller engine. Big block parts are expensive! A decent set of heads is about $2K, not including port work. Is it worth it in the long run? Surely, it is indefensible to claim anything to the contrary. But in the short term – well, if I were doing it over again, I’d buy a 2003 sports car and get it over with. Oh, but wait – there really aren’t any new cars worth buying, so maybe it IS worth it in the long run…. -
SuperDave, RPMS, BLKMGK and others got it exactly right! To paraphrase a famous aria in a famous opera: "Love is like an ill-behaved child; it never does what it is told. Look for it, and you will never find it; don't look, and there it is!" utvolman, you and I are in a similar position: small, backward town inhabited exclusively by married people. I'm 29, and everyone at work is the typical Midwestern upstanding husband-and-father. But that's typical in engineering. And it's also typical that good jobs are located in boring places. What is surprising, both in your case and in mine, is that being single carries more of a stigma than being divorced: "the divorced man was unlucky, or life threw him a curve, or he jumped into an ill-advised marriage when he was too young to know better; but the single guy - he's just a friggin' loser." It's also very true that women have an eerie sense for detecting lack of confidence and composure. If the guy is not at peace with himself, not confident with himself, how can he project the aura of confidence that women crave? "Nice guys finish last" not because they are "nice", but because they question themselves and seek intellectual justification for their behavior, while the "winners" just put their best foot forward. I used to think that going to the gym would help; that women are attracted to weightlifter-types. Experience showed that this assumption was completely false! However, the realization that women don't care about muscles was actually liberating, because then I started to think of exercise as a personal hobby, rather than a job to be done in order to achieve a particular end. Unfortunately, the process of finding and attracting female companionship tends to expose the most insidious weaknesses in a man's character. It's troublesome enough to make a guy want to just give up. But, as some other folks have remarked, perhaps that's precisely what needs to be done: paradoxically, the only way to succeed is to first give up.
At this point we can observe that the remaining justification for suggesting that long-stroke engines have inferior rev performance, is that subject to the ubiquitous "all else being equal", the long-stroke setup will have a higher moment of inertia, implying that it would take longer to spool up. However, there is a straightforward (but expensive) remedy: use lightened components; a lighter flywheel, lightened crank, compact harmonic damper. Considering the costs of getting back the horsepower lost when losing displacement to destroking, this is a reasonable option. When I first wrote this, I guessed that in a light car with a large engine, it is not inconceivable that in first gear the torque needed to spool up the engine is a large fraction of the torque to accelerate the mass of the car (with a given tire radius). A short calculation showed that this is completely false! Example (in S.I. units): 1000 kg car, 0.3m tire radius, accelerating in first gear at 8 m/s^2. Torque at the driveaxle is 2400 Nm. Assume that we begin at 1000 rpm and end at 5000 rpm, and that the ratio of crank rpm to axle rpm is 10:1, and assume constant acceleration (I know, that's a crude assumption, but it makes the math simple). Then the engine has to spool up from 1000 rpm to 5000 rpm in 1.57 seconds, giving an angular acceleration of 267 rad/s^2. Model the crank by two coaxial cylinders: one with 1.25" radius (the "main journals") weighing 40 lbs, and the other with 3" radius (the counterweights), also weighing 40 lbs. Converting to S.I. units and using the formula: moment of inertia = 0.5*mass*r^2 for a cylinder, the crank's moment of inertia is 0.062 kg*m^2. Also, since torque = moment of inertia times angular acceleration, the torque expended at the crank to spool up the crank itself is about 16 Nm, or 160 Nm at the driveaxle. This is a big crank in a light car accelerating rapidly. Even so, the crank spool-up absorbs <7% of the torque! Including the flywheel, the clutch and the harmonic damper of course raises this ratio, say by a factor of 2. Which perhaps explains why race cars tend to feature small-diameter multiple-plate clutches - another option to consider for a "rev-challenged" long-stroke engine. Regarding port sizing - Jim McFarland had some articles a few years ago, discussing "optimum" velocity of the intake charge. According to him, the mean speed of the flow before reaching the valve curtain area should be around 240 ft/s. Given an intake runner volume and geometry, we get a notional cross-sectional area of the intake port. McFarland pointed out the importance of comparing port cross-sectional area instead of volume. Big-block intake ports have much large volume than small-block intake ports, in part because of large area, but also because the runners are longer. From the cylinder displacement and a guess for volumetric efficiency – at a given rpm, we get a figure for the volume of requisite intake charge per intake stroke. From the cam profile one can back out a time interval during which a fictitious mean intake velocity would fill the aforementioned volume - again, at a given rpm - it's not the same as camshaft duration or a simple integral. It does not appear to be a simple calculation. Anyway, ideally, the port cross-sectional area times 240 ft/s, should equal cylinder volume times volumetric efficiency divided by the time interval. Deciding upon the rpm at which we want the best match would then size the port cross sectional area. All that remains is to slog through the calculations.
Just out of curiosity, what's inside the CFD code that runs "very fast" on a PC? If it's a panel method (vortex and source distribution, with flow-tangency boundary condition on each panel - and possibly vortex particles ejected at specific points in each time step, to simulate the "wake"), I would have to be skeptical. For an example of a state-of-the-art family of inviscid codes (tuned to mimic viscous effects), check out www.consultingaviation.com, or send them e-mail at cascd@mindspring.com – but please, don't mention my name. An erroneous answer is WORSE than a wild guess. A “ballpark” estimate can be worse than having absolutely no clue whatsoever – if the ball is in the wrong ballpark. And aerodynamics "improvements" based on specious analysis are likely to be worse than doing nothing at all. There's a reason that most cars have significant positive lift, and it's not because the OEMs are lazy or stupid. A real CFD analysis would be based on a full 3-D unsteady Navier-Stokes analysis. A full "direct numerical simulation" is currently not possible even with the best of computers and the best, most-motivated minds in industry and academia working on the problem, so we're back to the problem of turbulence modeling. I honestly have no idea what to suggest – what model to use. That doesn't mean that the problem can't be solved, of course - but it does justify tremendous skepticism whenever some one proposes a “solution”.
I was amazed how tight that Barracuda's engine bay is! The inner fenders extend so far inboard, that even the stock (or stock-appearing) exhaust is a tight fit - and that does not look like a wide engine. How did people ever shove a 426 Hemi in there? If a Crysler big block can be made to fit into the Barracuda, for sure it will fit in the Z.
Comparing a completely bare 240Z shell to a completely bare 280Z shell (no sound deadener, no glass, no rubber, no doors/hatch/etc., and of course no mechanicals - nothing that doesn't unbolt or scrape off or unplug – the difference is or the order of 50 lbs. The 280 has longer and stronger frame rails, frame reinforcements fore and aft for the bumper shocks, and slight differences in the transmission tunnel, the door hinge mounts, the radiator lower crossmember, the spare tire well, the framing just aft of the mustache bar mounts, and probably in other places in minor amounts. There is some speculation that the floor boards and some other sheet metal components on the 280Z shell are heavier gauge than on the 240, though I have never seen conclusive evidence one way or the other. Cutting up the shell to save weight is not necessarily impractical or extreme, but it will require some courage and finesse. I have done this, with mixed results.
The idea of a rigorous test of the Z in a wind tunnel comes up from time to time.... I think that this would be nice, but prohibitively expensive. It’s not just a matter of renting tunnel time. You would have to build and instrument the model, figure out how to spin the wheels (pretty important), how to run the ground belt (very important), how to attach the various removable components (air dams, side skirts, spoilers,…). Figure maybe $300,000 for a decent model, $1M for a short test and maybe $10M for a serious test with multiple entries (pressure-sensitive paint, probe-rake traverse and maybe particle image velocimetry). These are only guesses, of course – but more likely than not, they’re on the low end. NASCAR, F1, etc. perform minor tweaks of proven designs year after year – and spend more. Just imagine the costs of starting from scratch. Big difference! Of course, reasonable qualitative information can be obtained from MUCH cheaper and simpler experiments. Not to toot my own horn, but that’s what I tried to do in my water tunnel flow visualization tests. But these tests are rather useless for vehicle design. At best, they elucidate general trends. As for belly pans and underbody tunnels, the short answer is that these devices have good potential, but only when many, many other factors are just right. It’s a very “peaky” design. As Terry and others point out, blocking off the flow in the front with a good air dam, altering the hood lip and front grill, and following up with a good hatch lid spoiler are a better compromise solution, because it works over a broad range of scenarios, even if it’s not the “ultimate” in performance.
off topic about pathfinder tranny and also aerodynamics
Michael replied to blueovalz's topic in Miscellaneous Tech
Terry, Like your friend mentioned – what you saw was the footprint of a shock wave on the wing upper surface. I wish I got to this thread sooner; but at the present point, my post will just be review. In going over the front of the airfoil, the air accelerates to speeds significantly greater than the speed relative to the airplane itself. If the airplane is flying at, say 550 mph (well below Mach 1.0), there will probably be small regions over the wing upper surface where locally the flow is supersonic. Further aft on the wing, the pressure conditions are such that supersonic flow can no longer be sustained. Nature's solution is to introduce a shock wave, which stands like a "curtain" vertically over the wing. It abruptly terminates the region of supersonic flow, beyond which the flow is again subsonic. Almost all modern commercial jetliners cruise fast enough for there to be regions of supersonic flow over the wing. The speed at which this region gets to be so big that overall aerodynamic efficiency is reduced to unacceptable levels is the natural "speed limit" at which the airplane is operated. At somewhat higher speeds, the drag rises to a point where the engines' thrust is no longer sufficient to overcome the drag; that is the absolute speed limit of the airplane in steady level flight. Airlines will operate their planes at speeds somewhat below this absolute limit, in order to be below the point of diminishing return, to keep fuel costs down. For example, the Boeing 777 is rated at a maximum speed at cruise altitude of around 600 mph (probably more, I don't have the exact details), but you will never see a regular commercial flight faster than around 570 mph true air speed. The speed at which a region of supersonic flow first forms (called the critical Mach number) depends on many factors, such as the thickness of the wing and the lift coefficient at which it's flying. Jetliners are very efficient. They cruise at low lift coefficients and have thin wings. The root part of the wing is pretty thick, though - which is why I occasionally see the shock over the wing near the root portion, but not further outboard. In contrast, the upside-down wings of race cars sometimes operate at huge lift coefficients, so their critical Mach number is lower. Nevertheless, even an Indy car doing 240 mph is going too slow for shocks to appear, although more benign effects of air compressibility are still present at speeds in that range. Even with some very clever airplane design approaches, the drag penalty of trying to fly faster than the critical Mach number is so great, that it makes no commercial sense to do so. This is precisely why the speed of commercial jetliners has not changed much from 1969, when the Boeing 747 was introduced. They all cruise at around Mach 0.8 or so. It's really the critical Mach number, and not the magic Mach 1.0, that determines how fast conventional airplanes can fly. The Concorde flies much faster, of course, but it's so woefully inefficient that even at 10x the ticket price of a regular airplane, it still loses money. Boeing is now working on a new jetliner called the "Sonic Cruiser", designed to cruise at Mach 0.98. In my personal opinion, this airplane has no commercial future. Boeing is pursuing this design to keep their engineers busy. Anyway, the aforementioned footprint of the shock on the wing upper surface is due to a change in index of refraction in the air, which produces regions of contrasting illumination. More precisely, what you're seeing is the second derivative of the index of refraction (in the streamwise direction), which itself varies with the second derivative of the air density. Aerodynamicists call this the "shadowgraph effect". At speeds comparable to the speed of sound, significant changes in the thermodynamic variables of the air (density, pressure, temperature, etc.) are caused by changes in air velocity. Gradual changes are not visible. Violent changes, such as in a shock wave, are very visible, because the second derivate of density or temperature inside a shock is huge. Shocks are very thin, so their shadowgraphs are easy to see. Moist air has greater changes in index of refraction for the same change in temperature. This is why when the air is humid, the shadowgraph effect is stronger, and the shock more visible. By the way, the reason that this shock wave is vertical is that locally the flow is nearly parallel to the wing surface. In contrast, the bow shock of a supersonic airplane (under most conditions) is sloped with an angle equal to the arcsine of the inverse of the Mach number. It is caused by an entirely different mechanism. -
I want to second the call for “school first, finances second, hobbies third” – but keep in mind that your $40K will not necessarily make you a millionaire, even if you have decades and decades to wait, and “invest wisely”. Look at what happened in the stock market in the past 2 years. And don’t rush into buying that house, either. Houses have a nasty habit of declining in price, just after you buy them…. If you’re a mechanic, don’t hesitate to buy a cheapo stock 240Z. Drive it, maintain it, get used to it – then modify it. The point, I think, can be stated thus: planning ahead won’t necessarily get you ahead. But not planning ahead will almost certainly get you hosed. That’s not a resounding endorsement of delaying that big plunge into the world of V8 Z’s, but it does agree with experience.
My (admittedly biased!) views on Ohio.... I moved to Ohio in the spring of 2000, due to a compulsory job change (Wright-Patterson AFB). Were it not for that, I would never have moved here. My reasons? 1. weather: 90’s in the summer, way way below freezing in the winter. Long summer, long winter, no transitional seasons, always humid. I have lived in Michigan, Northern Virginia, Los Angeles, and New York City; all of these places have better weather, in my opinion. 2. taxes: not as high as New York or California, but certainly higher than average. State income tax is moderate, but local income taxes really hurt you. Townships don’t have local income tax, but most still have “school district tax”. Property taxes, as a percentage of house value, are outrageous, because the tax base is poor. Sales tax is 6-6.5% 3. suburban sprawl: there is plenty of rural land out here, but you have to drive >20 miles from even the smaller cities (like Dayton) to get out into the countryside, because of low-density housing construction ringing the cities. And, because so much land is available for new construction, existing property values are capped. In the towns, there are covenants and homeowners associations that would constrain activities such as a major Z-building operation; this is similar to what one finds along the coasts, except that there the communities are more affluent. 4. mentality: population turnover is low. Variety? Not that I have been able to observe.... This is a conservative, “heartland” type of area, which pulls no punches in promoting a particular kind of lifestyle. 5. police and cars: traffic cops are ubiquitous. Much worse than in Virginia, in my opinion. There is no safety inspection for cars, but there is a smog check that varies county-by-county. Cars older than 25 years are exempt. Unfortunately, the used car market is scarce, especially for foreign cars. Months go by before I see a Z on the road. On the other hand, if you are a young family trying to raise children, this might be a decent place for you. Ohio is “family-friendly” to the point of obsession. If I had to live in Ohio but had my choice as to which area, I would pick the northeast corner. It offers the most cultural opportunities, the best property appreciation, and the least conservative mentality. The southeast corner – “the hills” – is known for being the most economically backward. Property values in Ohio are NOT on the rise, except in Cleveland, Columbus and Cincinnati. The smaller cities in Ohio (Toledo, Dayton, and on down) are experiencing long-term real estate depreciation, relative to inflation. The reason? Ohio just doesn’t have the job base. After every census, Ohio loses another congressman. The bigger cities are doing better, as they have been able to transition to high-tech/the service sector. But the smaller cities, with their decaying industrial infrastructure, are in trouble. Also, as far as I have seen, Ohio’s agriculture is in trouble too: the farms tend to be small (not too many >1000 acre farms), which suggests that they would have trouble competing in modern agribusiness.
The 7-degree thing is true. It’s an empirical fact, and not the result of fancy calculation. Separation of the boundary layer is a response to an adverse pressure gradient. If you do the math, trying to solve for an attached flow, you would find that for sufficiently high adverse pressure gradient, the attached-flow solution is no longer possible. Basically, it’s like trying to drive uphill – if the slope gets too high, eventually you lose traction and roll back downhill. It so happens that 7 degrees corresponds to a particular pressure gradient, which is the threshold at which a conventional diffuser can no longer maintain attached flow. By the way, that’s for turbulent boundary layers. Laminar boundary layers (not practical for street cars) are even MORE sensitive to adverse pressure gradients. Think of it this way: the turbulent boundary layer is like an off-road 4x4 truck with studded tires trying to go uphill, while a laminar boundary layer is like an economy car with narrow, hard-compound tires. The economy car experiences less friction, which means that IF it can make it uphill, it will have less drag. The 4x4 truck has much higher drag, but it can make it up a much steeper hill. The reason that some diffuser designs can exceed 7 degree upslope without separation is “spanwise relief”, A.K.A. 3-D effects. The pressure gradient is locally relieved to keep the flow attached. How is this done? Good question.... It definitely goes on a case-by-case basis. I don’t have a good answer for that one.
