GOTHALOSISM
Everything posted by GOTHALOSISM
  1. They sort of look like some centerlines or even welds but not too sure. Have the person take one off and see what it says on the back side. What kind of car is it on now?
  2. I have a 94 lt1 with the MAF sensor. I bought a custom Harness with a chipped ECU from a guy that had a 93 lt1. Is there a way to install the MAF sensor into the new "custom" harness or do I even have to use the sensor? I did search but got tired of reading the same info.
  3. If its a TBI most likely its out of a Camaro or a Trans Am. As to weight its pretty close to the stock weight of the L28. If it has alluminumn heads and other AL parts then it can actually weigh less than the stock motor. It is cheaper to get more HP out of a SBC than a L28 as well.
  4. Its possible if you have a bad ground or short somewhere in the wiring that it could be causing an open circut. I think my relay is toast so I'll probably upgrade to a crane ignition system.
  5. ^^^ do you happen to have any pics of the undercarrige?
  6. Looking for a ok/good Fiberglass hood or hood scoop (cowl induction type) Would prefer something on the west coast because of shipping reasons.
  7. I love the way the BRE one looks, just wish they were longer to go with the Wide body that people have.
  8. Double check your engine mounts to make sure you did not reverse the right and left ones.
  9. You can paint it pink and get it air brushed with "Hello Kitty" on it! Thnx Hoov for the spot!
  10. the 88 firebird radiator will work fine. Just make sure its clean before using it. Agreed on the 305 sucking though, try finding a 327 or even a 350 you'll thank us in the long run.
  11. Yes I have the book, its just I am out of country and a friend found the transmission and was asking me. I did not bring my book with me to look and see.
  12. Very nice looking engine, quick question how much did you shorten the driveshaft to fit the 700r4?
  13. Yeah just found that out, that one has 10 spline where as I need a 27 spline one... The search continues....
  14. I have access to a BW49 that came out of a 95 camaro 3.8L. As far as I can tell its the only 5 speed for 95. Is that usable on a 94 lt1 with out mods? Or would I have to get a different bell housing? I did a search and nothing came up for the BW49.
  15. If that falls through there is a guy in Vegas selling the rear hatch for $40 but not sure on shipping.
  16. can you do a blue with that green flake? Or start the tube on the sides with blue but fade to green. If you really add another color I think it will make it too "busy". You want to tie the pieces together not seperate them. Post some pics with what you decide.
  17. That be me over on Zcar, and thanks for the info! I will have about $1300 to spend in june on the rest of the setup I hope thats enough to get it running.
  18. You ever get a hold of Jack to see if he could snag one for you?
  19. Yeah I have some laying around. I never molded them in so its just rough looking.
  20. My drivers side i just bolted into the stock miata holes. I had to pound in one side to get it to fit correctly though. As far as the pasengers side it needs alot more work to fit.
  21. Very nice write up with pics thank you. Now i need to fix mine using your setup.
  22. ask Rod on sincityz he has a tripple setup. Ask him to look at it so you can see what to look for when you get around to shopping for your own.
