My dash is out and I'm trying to get the car started to get it from my friends place to my home. No gauges or anything are installed, just the harness and relays.
I'll try to be as thorough as possible in explaining the situation:
Issue: Car has 13v power at fuse box and at key, if I turn key to on, or turn lights on, power drops to .2v ...Lights do not work, no starter clicking, no flashers or anything. It all used to work though.
Backstory:
It has a MSA fusebox installed by P/O. Unsure if installation is correct. two white/red wires are coming in and connecting to right side screw post. Two single (white and blue?) wires are connected from one side to the other on the fuse box.
It had a old cheap alarm installed. I removed this alarm, and re-connected the black/yellow wire that was spliced for it.
Its main ground wire had melted. I replaced the entire wire from end to end, following its connections.
The ignition/key has two black single wires coming off of it, are these for ground? I am unsure.
I am unsure if this is OEM or not, but these Yellow, Yellow/Red, Red/Blue, and Green, wires seem to run together, is this correct? I believe the yellow wires have something to do with the gauges?
Also, I have a few unknown issues that may be related or not:
I have this copper&plastic piece coming from the turn signal switch:
Thanks for your time.
If all else fails I'll be posting a Wanted thread for a 71 dash harness soon :/
